Fonction "echo" dans shell
Bonjour à tous
Je suis entrain de mettre en place un script automatisé, je bute sur un fichier ou du moins sur une commande. Le script est sensé copier le contenu d'un fichier par la fonction "echo". le seule soucis c'est que le script m'enlève les guillemets et me donne donc des erreurs.
Le but est de copier ce qu'il ya entre les "echo" dans le fichier profpd-conf-test.
echo "#
# /etc/proftpd/proftpd.conf -- This is a basic ProFTPD configuration file.
# To really apply changes reload proftpd after modifications.
# Includes DSO modules
Include /etc/proftpd/modules.conf
# Set off to disable IPv6 support which is annoying on IPv4 only boxes.
UseIPv6				"off"
ServerName			"Debian"
ServerType			"standalone"
DeferWelcome			"off"
DefaultRoot ~
IdentLookups off
ServerIdent on "FTP Server ready."
MultilineRFC2228		on
DefaultServer			on
ShowSymlinks			on
TimeoutNoTransfer		600
TimeoutStalled			600
TimeoutIdle			1200
DisplayLogin                    welcome.msg
DisplayFirstChdir               .message
ListOptions                	"-l"
DenyFilter			\*.*/
# Port 21 is the standard FTP port.
Port				21
# In some cases you have to specify passive ports range to by-pass
# firewall limitations. Ephemeral ports can be used for that, but
# feel free to use a more narrow range.
# PassivePorts                    49152 65534
# To prevent DoS attacks, set the maximum number of child processes
# to 30.  If you need to allow more than 30 concurrent connections
# at once, simply increase this value.  Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances			30
# Set the user and group that the server normally runs at.
User				proftpd
Group				nogroup
# Umask 022 is a good standard umask to prevent new files and dirs
# (second parm) from being group and world writable.
Umask				022  022
# Normally, we want files to be overwriteable.
AllowOverwrite			on
# Uncomment this if you are using NIS or LDAP to retrieve passwords:
# PersistentPasswd		off
# Be warned: use of this directive impacts CPU average load!
# Uncomment this if you like to see progress and transfer rate with ftpwho
# in downloads. That is not needed for uploads rates.
# UseSendFile			off
TransferLog /var/log/proftpd/xferlog
SystemLog   /var/log/proftpd/proftpd.log
<IfModule mod_tls.c>
TLSEngine off
</IfModule>
<IfModule mod_quota.c>
QuotaEngine on
</IfModule>
<IfModule mod_ratio.c>
Ratios on
</IfModule>
# Delay engine reduces impact of the so-called Timing Attack described in
# http://security.lss.hr/index.php?page=details&ID=LSS-2004-10-02
# It is on by default.
<IfModule mod_delay.c>
DelayEngine on
</IfModule>
<IfModule mod_ctrls.c>
ControlsEngine        on
ControlsMaxClients    2
ControlsLog           /var/log/proftpd/controls.log
ControlsInterval      5
ControlsSocket        /var/run/proftpd/proftpd.sock
</IfModule>
<IfModule mod_ctrls_admin.c>
AdminControlsEngine on
</IfModule>
# A basic anonymous configuration, no upload directories.
# <Anonymous ~ftp>
#   User				ftp
#   Group				nogroup
#   # We want clients to be able to login with "anonymous" as well as "ftp"
#   UserAlias			anonymous ftp
#   # Cosmetic changes, all files belongs to ftp user
#   DirFakeUser	on ftp
#   DirFakeGroup on ftp
#   RequireValidShell		off
#   # Limit the maximum number of anonymous logins
#   MaxClients			10
#   # We want 'welcome.msg' displayed at login, and '.message' displayed
#   # in each newly chdired directory.
#   DisplayLogin			welcome.msg
#   DisplayFirstChdir		.message
#   # Limit WRITE everywhere in the anonymous chroot
#   <Directory *>
#     <Limit WRITE>
#       DenyAll
#     </Limit>
#   </Directory>
#   # Uncomment this if you're brave.
#   # <Directory incoming>
#   #   # Umask 022 is a good standard umask to prevent new files and dirs
#   #   # (second parm) from being group and world writable.
#   #   Umask				022  022
#   #            <Limit READ WRITE>
#   #            DenyAll
#   #            </Limit>
#   #            <Limit STOR>
#   #            AllowAll
#   #            </Limit>
#   # </Directory>
# </Anonymous>">>  /etc/proftpd/proftpd.conf-test
donc le script qui est copié dans /etc/proftpd/proftpd.conf-test, n'a rien à voir avec celui là. Auriez vous une idée ,mmerci
Configuration: Windows Vista
Firefox 2.0.0.12
    Remplace les guillemets entrant et fermant par des quotes simples :
    echo 'Bla bla "blo" bla bla "blu" bla bla'
    1. Merci
      en publiant la discussion y avait d'autres discussions la dessus . En tout cas ça marche.
