Virus : help !
J'ai attrapé des virus qui ont infecté c:\winnt\system32 et C:\WINNT\security\Database\users\ qui ont été detectés par Bitdefender mais par par Norton. Bit defender n'a pas pu les désinfecter. Puis-je supprimer les fichiers infectés ou quelque à-t-il une autre solution ?
Voici le rapport complet :
C:\WINNT\security\Database\users\empavms.exe=>(Upx) infected: Trojan.HideWindows.A
C:\WINNT\security\Database\users\empavms.exe=>(Upx) unable to disinfect
C:\WINNT\security\Database\users\java.dll infected: IRC-Worm.Randon.I
C:\WINNT\security\Database\users\java.dll unable to disinfect
C:\WINNT\security\Database\users\moo.dll infected: Backdoor.IRC.Mimic.A
C:\WINNT\security\Database\users\moo.dll unable to disinfect
C:\WINNT\security\Database\users\newuser.bat infected: IRC-Worm.Randon.I (BAT)
C:\WINNT\security\Database\users\newuser.bat unable to disinfect
C:\WINNT\security\Database\users\regedit.dll infected: IRC-Worm.Randon.I
C:\WINNT\security\Database\users\regedit.dll unable to disinfect
C:\WINNT\security\Database\users\sipg.ocx infected: IRC-Worm.Randon.I
C:\WINNT\security\Database\users\sipg.ocx unable to disinfect
C:\WINNT\security\Database\users\sysconfig.ocx infected: IRC-Worm.Randon.I
C:\WINNT\security\Database\users\sysconfig.ocx unable to disinfect
C:\WINNT\security\Database\users\temp infected: IRC-Worm.Randon.I
C:\WINNT\security\Database\users\temp unable to disinfect
C:\WINNT\security\Database\users\wind.dll infected: IRC-Worm.Randon.I
C:\WINNT\security\Database\users\wind.dll unable to disinfect
C:\WINNT\system32\ntcfg.exe=>(Instyler)=>%appfolder%\java.dll infected: IRC-Worm.Randon.I
C:\WINNT\system32\ntcfg.exe=>(Instyler)=>%appfolder%\wind.dll infected: IRC-Worm.Randon.I
C:\WINNT\system32\ntcfg.exe=>(Instyler)=>%appfolder%\newuser.bat infected: IRC-Worm.Randon.I (BAT)
C:\WINNT\system32\ntcfg.exe=>(Instyler)=>%appfolder%\sipg.ocx infected: IRC-Worm.Randon.I
C:\WINNT\system32\ntcfg.exe=>(Instyler)=>%appfolder%\regedit.dll infected: IRC-Worm.Randon.I
C:\WINNT\system32\ntcfg.exe=>(Instyler)=>%appfolder%\sysconfig.ocx infected: IRC-Worm.Randon.I
C:\WINNT\system32\ntcfg.exe=>(Instyler)=>%appfolder%\moo.dll infected: Backdoor.IRC.Mimic.A
C:\WINNT\system32\ntcfg.exe=>(Instyler)=>%appfolder%\empavms.exe=>(Upx) infected: Trojan.HideWindows.A
24 réponses
Problème d'infection complexe touchant C:\WINNT\system32 et C:\WINNT\security\Database\users, détectée par Bitdefender mais non désinfectée, impliquant Trojan.HideWindows.A et IRC-Worm.Randon.I et suscitant des questions sur la suppression ou d'autres solutions. Les symptômes listent des fichiers infectés tels que empavms.exe, java.dll ou newuser.bat, avec des tentatives de désinfection échouées; les conseils privilégient la mise en quarantaine et la suppression éventuelle de se2win32.exe. Des intervenants recommandent aussi des mesures plus larges: installer des correctifs Windows, activer un pare-feu et recourir à des outils anti-trojan comme Tauscan, tout en évitant la suppression de DLL critiques sans remplacement. En cas de persistance, certains recommandent d’examiner des éléments comme se2win32.exe et ntcfg.exe et d’envisager une réinstallation propre si les infections ne peuvent être efficacement éradiquées.
  1. Norton n'a rien vu et il est bien mis à jour. J'ai regardé sur la base de données de virus de symantec et aucun de ces noms n'apparait.
    Je vais essayer l'antivirus que tu m'a conseillé. Si ça marche pas, que dois-je faire ?
    1. Salut
      tu peux essayer ça http://www.secuser.com/outils/antivirus.htm aussi quoique avec f-prot sa devrait etre bon .....)
      et pour les troyens puisque il semble y en avoir un dans la liste passe spybot qui ce trouve aussi sur le cite de sebsauvage
      _________________________
      \_...:::-~  Peter Pan ~-:::..._/
      1. ça y est, j'ai fait un scan avec F-Pro antivirus ; ça me donne 2 fichiers infectés seulement avec le fichier suspect que j'ai supprimé.
        par contre, ça me donne pas le même nom de virus, là, c'est IRC/Backdarter.E qui a infecté C:\WINNT\security\database/user.
        mais ça me dit pas si ça les a désinfecté ou pas...
          j'ai les mêmes problèmes avec le virus : IRC-randon.I
          comment as-tu fait pour enlever les fichiers infectés???
          j'ai aussi les virus suivant :
          Virtool.HiddenRun.B
          messages après scan de bitdefender :
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>empavms.exe=>(Upx) Infectés avec Trojan.HideWindows.A
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>empavms.exe=>(Upx) Désinfection impossible – Essayant deuxième action
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>java.dll Infectés avec IRC-Worm.Randon.I
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>java.dll Désinfection impossible – Essayant deuxième action
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>java.dll Déplacement impossible
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>newuser.bat Infectés avec IRC-Worm.Randon.I (BAT)
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>newuser.bat Désinfection impossible – Essayant deuxième action
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>newuser.bat Déplacement impossible
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>regedit.dll Infectés avec IRC-Worm.Randon.I
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>regedit.dll Désinfection impossible – Essayant deuxième action
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>regedit.dll Déplacement impossible
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>sipg.ocx Infectés avec IRC-Worm.Randon.I
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>sipg.ocx Désinfection impossible – Essayant deuxième action
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>sipg.ocx Déplacement impossible
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>sysconfig.ocx Infectés avec IRC-Worm.Randon.I
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>sysconfig.ocx Désinfection impossible – Essayant deuxième action
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>sysconfig.ocx Déplacement impossible
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>temp Infectés avec IRC-Worm.Randon.I
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>temp Désinfection impossible – Essayant deuxième action
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>temp Déplacement impossible
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>hid.exe Infectés avec Virtool.HiddenRun.B
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>hid.exe Désinfection impossible – Essayant deuxième action
          C:\WINNT\system32\se2win32.exe=>(RAR Sfx)=>hid.exe Déplacement impossible
          faut-il que je delette le fichier se2win32.exe??
          faut-il ré-installer ce fichier??
          merci d'avance
          1. Ola,
            à mon tour je suis infecté par
            Backdoor.IRC.Tastyred, Trojan dropper et Backdoor.Roxy.B
            Si un sauveteur m'enttend merci de me secourir.
            Kij
            1. Bonjour a tous je suis infecteté aussi par irc-worm.random mais aussi par vitool.hidenrun.B etc.... g norton 2004 win update a jour mais ne trouve aucun patch pour soigner ma bebette... si vous avez la solution : suis en 2000pro
              A plus!
                Salut.
                1 - les "virus" détectés sous les noms de "backdoor.xxxx" (contracté souvent en "bkdr") ou de "trojan.xxxx" ou de "troj.xxxx" ne sont pas vraiment des virus mais des chevaux de troie (lire absolument => http://www.commentcamarche.net/virus/trojan.php3) dont les antivirus traditionnels ont presque toujours du mal à se débarrasser
                2 - un logiciel facile, gratos et efficace pour les virer est SpybotS&d, avec notamment une version française, disponible ici http://sebsauvage.net/logiciels/spybotsd.html ou bien aussi TheCleaner http://www.moosoft.com/thecleaner/download.php
                3 - l'installation d'un firewall (http://www.commentcamarche.net/lan/firewall.php3) est indispensable pour éviter ce genre de souci à l'avenir ; large choix ici => http://www.firewall-net.com/fr/
                4 - pour les autres virus/vers essayer F-Prot cité plus haut ou un antivirus gratuit en ligne, par ex. http://www.secuser.com/outils/antivirus.htm
                A+
                -=O(_BmV_)O=-  L'amour comme épée,
                      ||       ||       l'humour comme bouclier.
                1. salut!!
                  je te conseille de télécharger le service pack 4 de microsoft, qui te permettra normalement d'être moins embété avec les virus, notamment le W32 blaster. Pour les chevaux de troi, le meilleur moyen est de prendre un firewall.. si tu as internet security de norton, tu n'auras plus de pb.
                  Pour enlever tous les cheavaux de troie, je te conseille les produits suivants :
                  - Anti-Trojan : version d'essai largement suffisante, il t'indique quels sont les ports vulnérables sur ton pc
                  http://www.diamondcs.com.au/
                  http://updates.a-2.org/a2freesetup.exe
                  - Tauscan : version d'essai très efficace aussi
                  http://www.agnitum.com/download/tauscan.html
                  - trojan remover :
                  http://www.simplysup.com/tremover/download.html
                  Une fois les virus enlevés et le firewall installé, tu n'auras plus de pb
                  je te conseille aussi de désinstaller tous les logiciels publicitaires qui sont des spyware.. pour cela, system mechanics est pas
                  bonne chance
                  1. mon ordi est infesté par downloader.jh
                    bit defender ne peut ni le déplacer ni le desinfecter
                    trojan remover ne le reconnais pas
                    je ne sais plus quoi faire
                    tibo
                    1. salut tibo
                      peux tu me dire si tu as trouve une solution pour ton infection avec
                      trojan downloader jh
                      j'arrive pas è l'enlever
                      tu serais sympa de me donner des conseils si tu as réussi
                      merci d'avance
                      salutations
                      marc
                  2. salut atous g un petit probleme g une page internet qui sapel amateur freegayspace qui vien quand je veut me connecter et aprer je ne peut plus avoir de page internet pouver vous maider merci
                    1. salut ninnin
                      J'ai exactement le meme probleme ke toi et ca fai 1 mois ke ca dure. Esque tu est arrivé a réssoudre le problème. Si oui merci de me repondre rapidement. Merci d avance
                  3. salut tt le mde g un pb avc trojan downloadder jh
                    si qq'un c comment l'eradiquer merci de m'aider
                    salutations
                    1. Contributeur sécurité
                      salut
                      Faite scan en ligne et coller le rapport ici sur le post
                      utiliser l'antivirus en ligne suivant :
                      http://www.ravantivirus.com/scan/
                      Cliquer sur "To continue without subscribing click here" et attendre quelques minutes.
                      Lorsque "Ready" est affiché dans "status", cocher la case "Autoclean" puis cliquer sur "Scan my PC"
                      A la fin de l'analyse, copier/coller le rapport ici.
                      la chasse et le balltrap ma vrai passion
                      voir site perso dans profil
                      1. SALUT merci pour ton aide g pas reussi a copier coller mais
                        l'anti virus a trouve un trojan win 32/dialer.fb
                        bitdefender me trouve un trojan downloader jh
                        concernet le meme fichier
                        c à d
                        c:documents and setting /local settings:teporary/internet files/
                        content.IE5/KFFRUGHX/CAX(1).cab>ole32ws.d
                        merci d'avance de m'aider
                        repond moi svp
                        salutations
                    2. Contributeur sécurité
                      salut
                      a faire hors connection
                      tu click sur demarrer/panneaux de configuration/option internet
                      une fenetre s ouvre tu click sur supprime les fichiers
                      une nouvelle petite fenetre s ouvre tu coche effacer tous le contenu hors connection et click ok
                      1. Ca sert a rien ca ne supprime pas le virus ...
                        Resultat je me balade toujours avec des fenetre de mec se sodomisant ...
                        Une solution s'il vous plait !
                        1. Bonjour, je suis débutant en informatique et en internet et j'ai choppé 2 virus Virtool et trojan...
                          J'ai bitdefender rien y fait!!!!
                          J'ai utilisé Spybot et c'est tjs parail
                          est ce que quelqu'un peut m'aider merci
                            salut
                            si c est bit defender qui te les a signaler il peut les virer
                            vas dans le dossier ou il les signale et suppr ou vas voir dans le dossier infected de bit defender ouvre le la il vas a nouveau detecter tu click sur ok et il les vires
                            1. bonjour à tous
                              Je suis moi auusi un débtutant sur internet et j'ai aussi contracté virtool, backdoor et autres méchancetés citées plus haut.
                              j'ai essayé les "trucs" proposés (spybot, spyhunter, zone alarm, f-prot, trjsetup) et rien à faire, quand je relance Bitdefender, il me trouve toujours les mêmes virus et affiche "impossible de désinfecter, de supprilmer ou de déplacer)
                              je ne sais pas où est le dossier infected de bit defender dont parle balltrap (je suis un poireau en fait)
                              Vais je devoir formater mon PC comme me le suggère un collègue de travail, ou bien ya -t-il encore un espoir?
                              Merci d'avance de votre aide
                              • 1
                              • 2
