Minecraft forge ne se lance pas
Bonjour, mon minecraft se lance mes crache tout de suite après les crache sont :
---- Minecraft Crash Report ----
// Hi. I'm Minecraft, and I'm a crashaholic.
Time: 2/12/20 8:36 PM
Description: Initializing game
java.lang.NoSuchMethodError: net.minecraftforge.fml.common.ObfuscationReflectionHelper.getPrivateValue(Ljava/lang/Class;Ljava/lang/Object;Ljava/lang/String;)Ljava/lang/Object;
at mod.lucky.client.ClientProxy.preRegister(ClientProxy.java:34)
at mod.lucky.client.ClientProxy.<init>(ClientProxy.java:21)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:422)
at java.lang.Class.newInstance(Class.java:442)
at net.minecraftforge.fml.common.ProxyInjector.inject(ProxyInjector.java:85)
at net.minecraftforge.fml.common.FMLModContainer.constructMod(FMLModContainer.java:598)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at com.google.common.eventbus.Subscriber.invokeSubscriberMethod(Subscriber.java:91)
at com.google.common.eventbus.Subscriber$SynchronizedSubscriber.invokeSubscriberMethod(Subscriber.java:150)
at com.google.common.eventbus.Subscriber$1.run(Subscriber.java:76)
at com.google.common.util.concurrent.MoreExecutors$DirectExecutor.execute(MoreExecutors.java:399)
at com.google.common.eventbus.Subscriber.dispatchEvent(Subscriber.java:71)
at com.google.common.eventbus.Dispatcher$PerThreadQueuedDispatcher.dispatch(Dispatcher.java:116)
at com.google.common.eventbus.EventBus.post(EventBus.java:217)
at net.minecraftforge.fml.common.LoadController.sendEventToModContainer(LoadController.java:218)
at net.minecraftforge.fml.common.LoadController.propogateStateMessage(LoadController.java:196)
at net.minecraftforge.fml.common.LoadController.distributeStateMessage(LoadController.java:135)
at net.minecraftforge.fml.common.Loader.loadMods(Loader.java:593)
at net.minecraftforge.fml.client.FMLClientHandler.beginMinecraftLoading(FMLClientHandler.java:232)
at net.minecraft.client.Minecraft.func_71384_a(Minecraft.java:466)
at net.minecraft.client.Minecraft.func_99999_d(Minecraft.java:377)
at net.minecraft.client.main.Main.main(SourceFile:123)
at net.minecraft.launchwrapper.Launch.launch(Launch.java:135)
at net.minecraft.launchwrapper.Launch.main(Launch.java:28)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Thread: Client thread
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.12.2
Operating System: Windows 10 (amd64) version 10.0
Java Version: 1.8.0_51, Oracle Corporation
Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 253143520 bytes (241 MB) / 402653184 bytes (384 MB) up to 2147483648 bytes (2048 MB)
JVM Flags: 8 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx2G -XX:+UnlockExperimentalVMOptions -XX:+UseG1GC -XX:G1NewSizePercent=20 -XX:G1ReservePercent=20 -XX:MaxGCPauseMillis=50 -XX:G1HeapRegionSize=32M
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
FML: MCP 9.42 Powered by Forge 14.23.5.2768 6 mods loaded, 6 mods active
States: 'U' = Unloaded 'L' = Loaded 'C' = Constructed 'H' = Pre-initialized 'I' = Initialized 'J' = Post-initialized 'A' = Available 'D' = Disabled 'E' = Errored
| State | ID | Version | Source | Signature |
| UC | minecraft | 1.12.2 | minecraft.jar | None |
| UC | mcp | 9.42 | minecraft.jar | None |
| UC | FML | 8.0.99.99 | forge-1.12.2-14.23.5.2768.jar | e3c3d50c7c986df74c645c0ac54639741c90a557 |
| UC | forge | 14.23.5.2768 | forge-1.12.2-14.23.5.2768.jar | e3c3d50c7c986df74c645c0ac54639741c90a557 |
| UC | aquaticluckyblock | 1.0.0 | Fish+Lucky+Block+-+Core+Mod+1.0.7.jar | None |
| U | lucky | 7.6.0 | luckyblock-1.12.2-7.6.0.zip | None |
Loaded coremods (and transformers):
GL info: ' Vendor: 'Intel' Version: '4.6.0 - Build 26.20.100.7463' Renderer: 'Intel(R) Iris(R) Plus Graphics'
Launched Version: 1.12.2-forge1.12.2-14.23.5.2768
LWJGL: 2.9.4
OpenGL: Intel(R) Iris(R) Plus Graphics GL version 4.6.0 - Build 26.20.100.7463, Intel
GL Caps: Using GL 1.3 multitexturing.
Using GL 1.3 texture combiners.
Using framebuffer objects because OpenGL 3.0 is supported and separate blending is supported.
Shaders are available because OpenGL 2.1 is supported.
VBOs are available because OpenGL 1.5 is supported.
Using VBOs: Yes
Is Modded: Definitely; Client brand changed to 'fml,forge'
Type: Client (map_client.txt)
Resource Packs:
Current Language: Français (France)
Profiler Position: N/A (disabled)
CPU: 8x Intel(R) Core(TM) i7-1065G7 CPU @ 1.30GHz
Configuration: Windows / Firefox 72.0
  1. Bonjour, il semblerait qu'un mod Lucky Block que vous avez mis soit la cause du crash.
