Problème de carte graphique minecraft
j'ai mis Windows 8.1 Pro sur mon Ordinateur qui était windows 7 familial premium.
Dès que j'ai voulu jouer voici le message de minecraft en 1.9.4:
---- Minecraft Crash Report ----
// You're mean.
Time: 27/05/16 19:12
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:247)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at bcd.ap(SourceFile:601)
at bcd.an(SourceFile:437)
at bcd.a(SourceFile:384)
at net.minecraft.client.main.Main.main(SourceFile:124)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Thread: Client thread
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.9.4
Operating System: Windows 8.1 (x86) version 6.3
Java Version: 1.8.0_91, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 85730056 bytes (81 MB) / 150351872 bytes (143 MB) up to 1060372480 bytes (1011 MB)
JVM Flags: 6 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx1G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.9.4
LWJGL: 2.9.4
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Using VBOs: No
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Packs:
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
CPU: bcd$7@1b84841
Et voici maintenant le message quand je joue en 1.0
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 27/05/16 19:13
Minecraft: Minecraft 1.0.0
OS: Windows 8.1 (x86) version 6.3
Java: 1.8.0_91, Oracle Corporation
VM: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
LWJGL: 2.9.0
[failed to get system properties (java.lang.RuntimeException: No OpenGL context found in the current thread.)]
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:244)
at net.minecraft.client.Minecraft.a(SourceFile:237)
at net.minecraft.client.Minecraft.run(SourceFile:644)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT 83c65cd5 ----------
Je réponderais dès que possible ou [résolu] quand on m'aura aidé
RedKill2710
  1. Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
    Tes pilotes de carte graphiques ne sont pas à jours !
    1. Salut,
      tes pilotes de carte graphiques ne sont pas à jour, va sur le site de la marque de ta carte graphique (nvidia, amd, intel) et installe ce qui est nécessaire.
      1. Cette solution était la meilleur car ma carte graphique est une AMD qui date de 2002 donc difficile a trouver la mise a jour, mais réussi quand même.
        Merci !
