Comment rajouter un script sous gimp?
je souhaite rajouter un script sous gimp 2.0
J'ai trouvé l'endroit
C://Programs Files/Gimp/Config/scripts
J'ai donc éssayé d'y mettre le copiant collant dans un fichier bloc note
voici ce que j'y ai placé
Je me doute que la première partie avec les ";" devant ne dois pas etre placé
; planet-render1-1.scm
; (C) 2005-2007 Aurore D. "Rore", aurore.d@gmail.com
; This program is free software; you can redistribute it and/or modify
; it under the terms of the GNU General Public License as published by
; the Free Software Foundation; either version 2 of the License, or
; (at your option) any later version.
; This program is distributed in the hope that it will be useful,
; but WITHOUT ANY WARRANTY; without even the implied warranty of
; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
; GNU General Public License for more details.
;; You should have received a copy of the GNU General Public License
; along with this program; if not, write to the Free Software
; Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
; Creates a planet.
; You'll find this script in the "Xtns >Script-Fu >Misc >Planet Render" menu
(define (script-fu-planet-render planetSize planetColor sunAngle sunTilt)
(let*
; 1/10th of the planet size
(tenth (/ planetSize 10) )
; image size 10% wider than the planet on each side
(imgSize (+ planetSize (* tenth 2)) )
(theImage (car (gimp-image-new imgSize imgSize RGB) ))
(layerbase (car (gimp-layer-new theImage imgSize imgSize 0 "planet base" 100 NORMAL) ) )
(layeratmosph (car (gimp-layer-new theImage imgSize imgSize 0 "planet atmosphere" 100 NORMAL) ) )
(layershadow (car (gimp-layer-new theImage imgSize imgSize 0 "planet shadow" 100 NORMAL) ) )
(layerglow (car (gimp-layer-new theImage imgSize imgSize 0 "planet glow" 100 NORMAL) ) )
(angleRad (/ (* sunAngle *pi*) 180))
(transX (* (sin angleRad) -1))
(transY (cos angleRad))
(gimp-context-push)
(gimp-image-undo-disable theImage)
(gimp-layer-add-alpha layerbase )
(gimp-layer-add-alpha layeratmosph )
(gimp-layer-add-alpha layershadow )
(gimp-layer-add-alpha layerglow )
(gimp-image-add-layer theImage layerglow 0)
(gimp-image-add-layer theImage layerbase 0)
(gimp-image-add-layer theImage layeratmosph 0)
(gimp-image-add-layer theImage layershadow 0)
(gimp-selection-all theImage)
(gimp-edit-clear layerbase)
(gimp-edit-clear layeratmosph)
(gimp-edit-clear layershadow)
(gimp-edit-clear layerglow)
(gimp-selection-none theImage)
(gimp-ellipse-select theImage tenth tenth planetSize planetSize 2 1 0 0 )
(gimp-context-set-foreground planetColor)
; fill selection with the planet color
(gimp-edit-bucket-fill layerbase 0 0 100 0 FALSE 0 0 )
(gimp-edit-bucket-fill layeratmosph 0 0 100 0 FALSE 0 0 )
; shrink and blur for the shadow
(gimp-selection-feather theImage (* 1.5 tenth) )
(gimp-context-set-background '(0 0 0) )
(gimp-edit-bucket-fill layershadow 1 0 100 0 FALSE 0 0 );;
; add the light around the planet for the atmosphere
(gimp-selection-layer-alpha layeratmosph)
(gimp-selection-shrink theImage tenth)
(gimp-selection-feather theImage (* 2 tenth))
(gimp-layer-set-preserve-trans layeratmosph 1)
(gimp-selection-invert theImage)
(gimp-context-set-background '(255 255 255) )
(gimp-edit-bucket-fill layeratmosph 1 5 90 0 FALSE 0 0 )
(gimp-context-set-foreground '(0 0 0) )
(gimp-selection-shrink theImage (/ tenth 3))
(gimp-selection-feather theImage tenth)
(gimp-edit-bucket-fill layeratmosph 1 0 85 0 FALSE 0 0 )
(gimp-layer-set-mode layeratmosph 4)
;move,resize the shadow layer
(gimp-layer-scale layershadow (* (+ 1.5 (/ sunTilt 10)) imgSize) (* (+ 1.5 (/ sunTilt 10)) imgSize) 1 )
(gimp-layer-translate layershadow (* (* transX tenth) (+ 3 sunTilt) ) (* (* transY tenth) (+ 3 sunTilt) ) )
; and now the glow...
(gimp-selection-layer-alpha layerbase)
(gimp-selection-grow theImage (/ tenth 4))
(gimp-selection-feather theImage tenth )
(gimp-context-set-background planetColor )
(gimp-edit-bucket-fill layerglow 1 0 100 0 FALSE 0 0 )
(gimp-edit-bucket-fill layerglow 1 7 100 0 FALSE 0 0 )
; mask a part of the glow
(let ((glowmask (car (gimp-layer-create-mask layerglow 0))))
(gimp-image-add-layer-mask theImage layerglow glowmask)
(gimp-selection-layer-alpha layershadow)
(gimp-edit-bucket-fill glowmask 0 0 100 0 FALSE 0 0 )
(gimp-selection-all theImage) ;; stuff to remove ugly thin white border
(gimp-fuzzy-select layerbase (/ imgSize 2) (/ imgSize 2) 15 1 1 0 0 0) ;;
(gimp-edit-cut layershadow)
(gimp-layer-resize-to-image-size layershadow)
(gimp-image-clean-all theImage)
(gimp-image-undo-enable theImage)
(gimp-display-new theImage)
(gimp-context-pop)
(script-fu-register "script-fu-planet-render"
_"_Planet render..."
"Creates a planet.(Color, size and sun orientation can be set)"
"Aurore D. (Rore)"
"aurore.d@gmail.com"
"October 2005"
SF-ADJUSTMENT "Planet size (pixels)" '(400 40 2000 1 10 0 1)
SF-COLOR "Planet color" '(10 70 100)
SF-ADJUSTMENT _"Sun orientation (degrees) " '(0 0 360 1 10 1 0)
SF-ADJUSTMENT _"Sun Tilt " '(1 0 5 1 10 1 0) )
(script-fu-menu-register "script-fu-planet-render"
_"<Toolbox>/Xtns/Script-Fu/Misc")
Firefox 2.0.0.5
voilà concrétement quel partie exactement dois je placer et comment je fais pour la mettre dans gimp et qu'elle soit reconnu?
Merci d'avance
  1. Moi je sais, mais vu la date du post, je suppose que florent5528 et neomax n'en a peut être plus besoin , mais pour tous ceux qui passeriaent sur ce topic:
    il faut copier le script puis ouvrir bloc note dans « tous les programmes »>accessoires, et le coller.
    Enregistrez sous ce titre : planet-render1-1.scm dans program files/gimpX.X/share/gimp/X.X/scripts.
    Maintenant ouvrez Gimp et allez dans Exts> script-fu> divers>planet render.
    bien sur , j'ai mis des x à la place des chiffres de votre Gimp à vous ;)
    voili voilou
    1. Comment ouvre t-on Exts dans Gimp?
    2. @wilburnLorsque tu ouvre Gimp, il ya la boite à outil qui s'affiche. Tu trouve Exts tout en haut de cette boite à outil entre fichier et aide.
      Bien sur une fois que tu l'as trouvé pour l'ouvrir il faut cliquer dessus ^^.
    3. Bonjour,
      Je n'ai pas le filtre déformation interactive. Comment me le procurer ? et l'installer dans gimp.
      J'ai la dernière version gimp, et la pack mode. (une erreur de manipulation a enlever ce filtre)
      Merci de vos réponses
  2. J'ai exactement le meme probleme pour le meme script donc si c'était possible j'aimerai bien que quelqu'un reponde svp
    1. bonjours
      j aimerais savoir commenty on peut avoir script fu sur jimp avc windows pour faire des efect sabre laser
      1. Et bien en effet mon poste est ancien mais je vous remercie pour la réponse electronath.
        Cela fonctionne et m'a bien aidé
        1. bonjour,
          je suis désolée pour l'effet de sabre j'avoue que je ne connais pas de script-fu.. je fais par mes propre moyen en jouant sur la transparence du calque.
          @ florent 5528 je suis contente de t'avoir aider ^^.
