Notice: Undefined offset: 11
J'ai une erreur dans mon code PHP suivant:
<table class="border">
<thead>
<tr>
<th>ODM</th>
<th>SECTEUR</th>
<th>TA</th>
<th>URGENCE</th>
<th>CLOT</th>
<?php
$sql0=$bdd->query("SELECT DISTINCT Matricule FROM pointages WHERE Date_Pointage = '$date'");
$row0=$sql0->fetchAll();
$j = 0;
$table1 = array();
$table=array();
foreach($row0 as $numero0)
$matricule=$numero0['Matricule'];
$table1[$j] = $matricule;
$sql5=$bdd->query("SELECT Nom, Prenom FROM matricules WHERE Matricule ='$matricule'");
$row5=$sql5->fetchAll();
$j++;
foreach($row5 as $mat)
<th> <div><?php echo $mat['Nom'].' '.$mat['Prenom'];?></div></th>
<?php
<th> TOTAL GENRAL</th>
</tr>
</thead>
<tbody>
<tr>
<?php
$i=0;
$sql1=$bdd->query("SELECT DISTINCT Num_OS_Client FROM pointages_fact WHERE Num_Pointage IN (SELECT Numero FROM pointages WHERE Date_Pointage ='$date')");
$row1=$sql1->fetchALL();
$table2=array();
foreach($row1 as $numero1)
$ordre=$numero1['Num_OS_Client'];
$sql2=$bdd->query("SELECT Ordre_Client, Libelle, Secteur, Metier, Urgence, Date_Clot_Tech FROM ordres_mic WHERE Ordre_Client='$ordre'");
$row2=$sql2->fetchAll();
foreach($row2 as $donnees)
<?php
$a = $donnees['Ordre_Client'];
$b = $donnees['Libelle'];
$ab = $a.' - '.$b;
$c = $donnees['Secteur'];
$d = $donnees['Metier'];
$e = $donnees['Urgence'];
if($donnees['Date_Clot_Tech'] == '0000-00-00')
$f = "NON";
$table[$i]= $ab.'||'.$c.'||'.$d.'||'.$e.'||'.$f;
else
$f = "OUI";
$i++;
for($z =0; $z<=$i; $z++)
$ich =$table[$z];
$explo = explode('||', $ich);
$odm = $explo[0];
$secteur = $explo[1];
$metier = $explo[2];
$urgence = $explo[3];
$clot = $explo[4];
<td><?php echo $odm;?></td>
<td><?php echo $secteur;?></td>
<td><?php echo $metier;?></td>
<td><?php echo $urgence;?></td>
<td><?php echo $clot;?></td>
<?php
$lol = explode(' - ', $odm);
$lo = $lol[0];
$sum=0;
$y=0;
while($y<=$j)
$mat = $table1[$y];
$sql3=$bdd->query("SELECT Fact_H, Num_OS_Client FROM pointages_fact WHERE Num_Pointage IN (Select Numero FROM pointages WHERE Date_Pointage='$date' AND Matricule='$mat')");
$row3=$sql3->fetchAll();
foreach($row3 as $numero3)
$heure=$numero3['Fact_H'];
$sum = $sum + $heure;
$os=$numero3['Num_OS_Client'];
$sql5=$bdd->query("SELECT Matricule FROM pointages WHERE (Numero IN(Select Num_Pointage FROM pointages_fact WHERE Num_OS_Client = '$lo')) AND Date_Pointage='$date'");
$row5=$sql5->fetch();
$matricule2=$row5['Matricule'];
if($mat == $matricule2)
<td><?phpecho $heure;?></td>
<?php
else
<td> </td>
<?php
$y++;
<td><?php echo $sum;?></td>
<?php
</tr>
</tbody>
</table>
Plus précisement à cette ligne :
$mat = $table1[$y];
quand j'execute ça m'affiche une erreur(cf titre du message) ;
Est ce que quelqu'un aurait une solution à mon problème svp?
  1. Salut,
    Alors si j'ai bien lu ton code et si je me goure pas, lorsque tu fais le premier foreach, ta variable $j est incrémentée une fois supplémentaire lors de la dernière boucle. Donc cette variable est égale à ton nombre d'enregistrement + 1.
    Pour résoudre ton problème, tu peux remplacer la ligne
    while($y<=$j)
    par
    while($y<$j)
    ou
    while($y<=$j-1)
    Dis moi si ça fonctionne.
    1. Merci ça fonctionne très bien
