Problème Java ?
je viens de trouver ça sur mon bureau , je ne sais pas ce que je dois en faire ... Merci de bien vouloir m'aider , à bientôt !
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x78aa1ed7, pid=1992, tid=2712
# JRE version: Java(TM) SE Runtime Environment (7.0_51-b13) (build 1.7.0_51-b13)
# Java VM: Java HotSpot(TM) Client VM (24.51-b03 mixed mode windows-x86 )
# Problematic frame:
# C [msvcr100.dll+0x1ed7]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# https://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x48f3d000): JavaThread "AWT-Windows" daemon [_thread_in_native, id=2712, stack(0x49290000,0x492e0000)]
siginfo: ExceptionCode=0xc0000005, writing address 0x4a037740
Registers:
EAX=0x48f84248, EBX=0x00000180, ECX=0x00000060, EDX=0x00000000
ESP=0x492df728, EBP=0x492df730, ESI=0x48f840c8, EDI=0x4a037740
EIP=0x78aa1ed7, EFLAGS=0x00010212
Top of Stack: (sp=0x492df728)
0x492df728: 48f7c978 00000000 4a0e62e0 6d0abf9d
0x492df738: 4a037740 48f840c8 00000180 00000000
0x492df748: 499a7348 48f227d8 492df788 4a037740
0x492df758: 6d0a2b3e 00000000 6d0a8090 492df8c8
0x492df768: 00000356 48f74ce0 000001e0 48e65a20
0x492df778: 00000000 00000001 000b8ba4 000b8ba0
0x492df788: 492df798 4fd98943 0000003e 00000001
0x492df798: 492df7cc 4fd770d5 00000001 00000356
Instructions: (pc=0x78aa1ed7)
0x78aa1eb7: e6 0f 3b fe 5e 5f 75 05 e9 35 eb 00 00 f7 c7 03
0x78aa1ec7: 00 00 00 75 14 c1 e9 02 83 e2 03 83 f9 08 72 29
0x78aa1ed7: f3 a5 ff 24 95 f0 1f aa 78 8b c7 ba 03 00 00 00
0x78aa1ee7: 83 e9 04 72 0c 83 e0 03 03 c8 ff 24 85 04 1f aa
Register to memory mapping:
EAX=0x48f84248 is an unknown value
EBX=0x00000180 is an unknown value
ECX=0x00000060 is an unknown value
EDX=0x00000000 is an unknown value
ESP=0x492df728 is pointing into the stack for thread: 0x48f3d000
EBP=0x492df730 is pointing into the stack for thread: 0x48f3d000
ESI=0x48f840c8 is an unknown value
EDI=0x4a037740 is an unknown value
Stack: [0x49290000,0x492e0000], sp=0x492df728, free space=317k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j sun.awt.windows.WToolkit.eventLoop()V+0
j sun.awt.windows.WToolkit.run()V+49
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x4d917400 JavaThread "Keep-Alive-Timer" daemon [_thread_blocked, id=148, stack(0x4f7e0000,0x4f830000)]
0x4d53dc00 JavaThread "File IO Thread" daemon [_thread_in_vm, id=1812, stack(0x4e530000,0x4e580000)]
0x4de7ec00 JavaThread "Server thread" daemon [_thread_blocked, id=2940, stack(0x4e880000,0x4e8d0000)]
0x4ff53400 JavaThread "Snooper Timer" daemon [_thread_blocked, id=2212, stack(0x4b0d0000,0x4b120000)]
0x49975400 JavaThread "Minecraft main thread" daemon [_thread_in_native, id=1116, stack(0x4aa00000,0x4aa50000)]
0x4993b800 JavaThread "Timer hack thread" daemon [_thread_blocked, id=2208, stack(0x49b60000,0x49bb0000)]
0x4994d400 JavaThread "Snooper Timer" daemon [_thread_blocked, id=3564, stack(0x4a1b0000,0x4a200000)]
0x49869c00 JavaThread "D3D Screen Updater" daemon [_thread_in_native, id=2952, stack(0x49f50000,0x49fa0000)]
0x003c9400 JavaThread "DestroyJavaVM" [_thread_blocked, id=3848, stack(0x009c0000,0x00a10000)]
0x49046400 JavaThread "AWT-EventQueue-0" [_thread_in_native, id=996, stack(0x496f0000,0x49740000)]
0x4902fc00 JavaThread "TimerQueue" daemon [_thread_blocked, id=1912, stack(0x49650000,0x496a0000)]
0x48fd9800 JavaThread "SwingWorker-pool-1-thread-1" daemon [_thread_blocked, id=1384, stack(0x496a0000,0x496f0000)]
=>0x48f3d000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=2712, stack(0x49290000,0x492e0000)]
0x48f34400 JavaThread "AWT-Shutdown" [_thread_blocked, id=3648, stack(0x49240000,0x49290000)]
0x48f49400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=3504, stack(0x491f0000,0x49240000)]
0x48e74000 JavaThread "Service Thread" daemon [_thread_blocked, id=2352, stack(0x49150000,0x491a0000)]
0x48e66000 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=2548, stack(0x49100000,0x49150000)]
0x48e64800 JavaThread "Attach Listener" daemon [_thread_blocked, id=4092, stack(0x490b0000,0x49100000)]
0x48e63400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4040, stack(0x49060000,0x490b0000)]
0x02ba3000 JavaThread "Finalizer" daemon [_thread_blocked, id=1516, stack(0x48e10000,0x48e60000)]
0x02b9e000 JavaThread "Reference Handler" daemon [_thread_blocked, id=3608, stack(0x48dc0000,0x48e10000)]
Other Threads:
0x02b9c400 VMThread [stack: 0x48d70000,0x48dc0000] [id=3284]
0x48e87c00 WatcherThread [stack: 0x491a0000,0x491f0000] [id=1100]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 158656K, used 56794K [0x02bb0000, 0x0d7d0000, 0x18100000)
eden space 141056K, 40% used [0x02bb0000, 0x06326be0, 0x0b570000)
from space 17600K, 0% used [0x0b570000, 0x0b570000, 0x0c6a0000)
to space 17600K, 0% used [0x0c6a0000, 0x0c6a0000, 0x0d7d0000)
tenured generation total 352384K, used 129679K [0x18100000, 0x2d920000, 0x42bb0000)
the space 352384K, 36% used [0x18100000, 0x1ffa3f00, 0x1ffa4000, 0x2d920000)
compacting perm gen total 16896K, used 16782K [0x42bb0000, 0x43c30000, 0x46bb0000)
the space 16896K, 99% used [0x42bb0000, 0x43c13a10, 0x43c13c00, 0x43c30000)
No shared spaces configured.
Card table byte_map: [0x489b0000,0x48be0000] byte_map_base: 0x4899a280
Polling page: 0x003f0000
Code Cache [0x00a30000, 0x013b8000, 0x02a30000)
total_blobs=4846 nmethods=4447 adapters=330 free_code_cache=23032Kb largest_free_block=23583744
Compilation events (10 events):
Event: 2952.570 Thread 0x48e66000 4470 nz::a (5 bytes)
Event: 2952.570 Thread 0x48e66000 nmethod 4470 0x013b0e08 code [0x013b0f00, 0x013b0f80]
Event: 2958.929 Thread 0x48e66000 4471 tj::a (37 bytes)
Event: 2958.929 Thread 0x48e66000 nmethod 4471 0x013b0fc8 code [0x013b10f0, 0x013b11e0]
Event: 2967.164 Thread 0x48e66000 4472 bap::a (66 bytes)
Event: 2967.165 Thread 0x48e66000 nmethod 4472 0x013b12c8 code [0x013b1420, 0x013b1634]
Event: 2982.757 Thread 0x48e66000 4473 ala::g (38 bytes)
Event: 2982.757 Thread 0x48e66000 nmethod 4473 0x013b1808 code [0x013b1950, 0x013b1a4c]
Event: 2987.735 Thread 0x48e66000 4474 ix::b (181 bytes)
Event: 2987.736 Thread 0x48e66000 nmethod 4474 0x013b1ac8 code [0x013b1c70, 0x013b1f94]
GC Heap History (10 events):
Event: 2893.425 GC heap before
{Heap before GC invocations=104 (full 4):
def new generation total 158656K, used 156943K [0x02bb0000, 0x0d7d0000, 0x18100000)
eden space 141056K, 100% used [0x02bb0000, 0x0b570000, 0x0b570000)
from space 17600K, 90% used [0x0b570000, 0x0c4f3cb8, 0x0c6a0000)
tenured generation total 352384K, used 161266K [0x18100000, 0x2d920000, 0x42bb0000)
the space 352384K, 45% used [0x18100000, 0x21e7ca58, 0x21e7cc00, 0x2d920000)
the space 16896K, 99% used [0x42bb0000, 0x43c13950, 0x43c13a00, 0x43c30000)
Event: 2893.485 GC heap after
Heap after GC invocations=105 (full 4):
def new generation total 158656K, used 3203K [0x02bb0000, 0x0d7d0000, 0x18100000)
eden space 141056K, 0% used [0x02bb0000, 0x02bb0000, 0x0b570000)
from space 17600K, 18% used [0x0c6a0000, 0x0c9c0c70, 0x0d7d0000)
to space 17600K, 0% used [0x0b570000, 0x0b570000, 0x0c6a0000)
tenured generation total 352384K, used 176178K [0x18100000, 0x2d920000, 0x42bb0000)
the space 352384K, 49% used [0x18100000, 0x22d0c9f0, 0x22d0ca00, 0x2d920000)
Event: 2920.984 GC heap before
{Heap before GC invocations=105 (full 4):
def new generation total 158656K, used 144259K [0x02bb0000, 0x0d7d0000, 0x18100000)
the space 16896K, 99% used [0x42bb0000, 0x43c13960, 0x43c13a00, 0x43c30000)
Event: 2921.017 GC heap after
Heap after GC invocations=106 (full 4):
def new generation total 158656K, used 7776K [0x02bb0000, 0x0d7d0000, 0x18100000)
from space 17600K, 44% used [0x0b570000, 0x0bd08108, 0x0c6a0000)
Event: 2955.050 GC heap before
{Heap before GC invocations=106 (full 4):
def new generation total 158656K, used 158656K [0x02bb0000, 0x0d7d0000, 0x18100000)
from space 17600K, 100% used [0x0b570000, 0x0c6a0000, 0x0c6a0000)
tenured generation total 352384K, used 184182K [0x18100000, 0x2d920000, 0x42bb0000)
the space 352384K, 52% used [0x18100000, 0x234dd840, 0x234dda00, 0x2d920000)
Event: 2955.108 GC heap after
Heap after GC invocations=107 (full 4):
def new generation total 158656K, used 8490K [0x02bb0000, 0x0d7d0000, 0x18100000)
from space 17600K, 48% used [0x0c6a0000, 0x0ceeaa78, 0x0d7d0000)
Event: 2981.902 GC heap before
{Heap before GC invocations=107 (full 4):
def new generation total 158656K, used 149546K [0x02bb0000, 0x0d7d0000, 0x18100000)
Event: 2981.960 GC heap after
Heap after GC invocations=108 (full 4):
def new generation total 158656K, used 8700K [0x02bb0000, 0x0d7d0000, 0x18100000)
from space 17600K, 49% used [0x0b570000, 0x0bdef040, 0x0c6a0000)
Event: 2986.863 GC heap before
{Heap before GC invocations=108 (full 4):
def new generation total 158656K, used 85699K [0x02bb0000, 0x0d7d0000, 0x18100000)
eden space 141056K, 54% used [0x02bb0000, 0x076e1f60, 0x0b570000)
the space 16896K, 99% used [0x42bb0000, 0x43c139d0, 0x43c13a00, 0x43c30000)
Event: 2987.248 GC heap after
Heap after GC invocations=109 (full 5):
def new generation total 158656K, used 0K [0x02bb0000, 0x0d7d0000, 0x18100000)
Deoptimization events (0 events):
No events
Internal exceptions (10 events):
Event: 2988.021 Thread 0x49975400 Threw 0x03472dd0 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jni.cpp:717
Event: 2988.021 Thread 0x49975400 Threw 0x03472f68 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jni.cpp:717
Event: 2988.021 Thread 0x49975400 Threw 0x034730d0 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jni.cpp:717
Event: 2988.021 Thread 0x49abe800 Threw 0x05d0d618 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:2965
Event: 2988.021 Thread 0x49abfc00 Threw 0x05d0fc50 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jvm.cpp:2965
Event: 2988.146 Thread 0x49975400 Threw 0x034739b0 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jni.cpp:717
Event: 2988.146 Thread 0x49975400 Threw 0x03473b48 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jni.cpp:717
Event: 2988.146 Thread 0x49975400 Threw 0x03473cb0 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jni.cpp:717
Event: 2988.146 Thread 0x49975400 Threw 0x03473eb0 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jni.cpp:717
Event: 2988.146 Thread 0x49975400 Threw 0x03474018 at C:\re\jdk7u51\527\hotspot\src\share\vm\prims\jni.cpp:717
Events (10 events):
Event: 2987.249 Executing VM operation: GenCollectFull done
Event: 2987.267 Thread 0x4a9d0400 Thread added: 0x4a9d0400
Event: 2987.760 Thread 0x4d917400 Thread added: 0x4d917400
Event: 2987.760 Executing VM operation: RevokeBias
Event: 2987.760 Executing VM operation: RevokeBias done
Event: 2987.764 Thread 0x4a9d0400 Thread exited: 0x4a9d0400
Event: 2988.021 Thread 0x49abe800 Thread exited: 0x49abe800
Event: 2988.021 Executing VM operation: RevokeBias
Event: 2988.038 Executing VM operation: RevokeBias done
Event: 2988.038 Thread 0x49abfc00 Thread exited: 0x49abfc00
Dynamic libraries:
0x00400000 - 0x0042f000 C:\Program Files\Java\jre7\bin\javaw.exe
0x7c910000 - 0x7c9c9000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c906000 C:\WINDOWS\system32\kernel32.dll
0x77da0000 - 0x77e4c000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e50000 - 0x77ee3000 C:\WINDOWS\system32\RPCRT4.dll
0x77fc0000 - 0x77fd1000 C:\WINDOWS\system32\Secur32.dll
0x7e390000 - 0x7e421000 C:\WINDOWS\system32\USER32.dll
0x77ef0000 - 0x77f39000 C:\WINDOWS\system32\GDI32.dll
0x77390000 - 0x77493000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\COMCTL32.dll
0x77be0000 - 0x77c38000 C:\WINDOWS\system32\msvcrt.dll
0x77f40000 - 0x77fb6000 C:\WINDOWS\system32\SHLWAPI.dll
0x76320000 - 0x7633d000 C:\WINDOWS\system32\IMM32.DLL
0x78aa0000 - 0x78b5f000 C:\Program Files\Java\jre7\bin\msvcr100.dll
0x6e770000 - 0x6eaf0000 C:\Program Files\Java\jre7\bin\client\jvm.dll
0x71a10000 - 0x71a1a000 C:\WINDOWS\system32\WSOCK32.dll
0x719f0000 - 0x71a07000 C:\WINDOWS\system32\WS2_32.dll
0x719e0000 - 0x719e8000 C:\WINDOWS\system32\WS2HELP.dll
0x76ae0000 - 0x76b0f000 C:\WINDOWS\system32\WINMM.dll
0x76ba0000 - 0x76bab000 C:\WINDOWS\system32\PSAPI.DLL
0x6e6c0000 - 0x6e6cc000 C:\Program Files\Java\jre7\bin\verify.dll
0x6d480000 - 0x6d4a0000 C:\Program Files\Java\jre7\bin\java.dll
0x6e750000 - 0x6e763000 C:\Program Files\Java\jre7\bin\zip.dll
0x6d000000 - 0x6d143000 C:\Program Files\Java\jre7\bin\awt.dll
0x770e0000 - 0x7716b000 C:\WINDOWS\system32\OLEAUT32.dll
0x774a0000 - 0x775de000 C:\WINDOWS\system32\ole32.dll
0x5b090000 - 0x5b0c8000 C:\WINDOWS\system32\uxtheme.dll
0x49330000 - 0x494b4000 C:\Program Files\NVIDIA Corporation\nview\nview.dll
0x7c9d0000 - 0x7d1f5000 C:\WINDOWS\system32\SHELL32.dll
0x77bd0000 - 0x77bd8000 C:\WINDOWS\system32\VERSION.dll
0x77650000 - 0x77671000 C:\WINDOWS\system32\NTMARTA.DLL
0x71b50000 - 0x71b63000 C:\WINDOWS\system32\SAMLIB.dll
0x76f10000 - 0x76f3d000 C:\WINDOWS\system32\WLDAP32.dll
0x49580000 - 0x495cf000 C:\Program Files\NVIDIA Corporation\nview\NVWRSFR.DLL
0x74690000 - 0x746dc000 C:\WINDOWS\system32\MSCTF.dll
0x75140000 - 0x7516e000 C:\WINDOWS\system32\msctfime.ime
0x4fcf0000 - 0x4fe96000 C:\WINDOWS\system32\d3d9.dll
0x6de60000 - 0x6de66000 C:\WINDOWS\system32\d3d8thk.dll
0x6d270000 - 0x6d2a9000 C:\Program Files\Java\jre7\bin\fontmanager.dll
0x6e4b0000 - 0x6e4c4000 C:\Program Files\Java\jre7\bin\net.dll
0x6e4d0000 - 0x6e4df000 C:\Program Files\Java\jre7\bin\nio.dll
0x71990000 - 0x719d0000 C:\WINDOWS\System32\mswsock.dll
0x76ed0000 - 0x76ef7000 C:\WINDOWS\system32\DNSAPI.dll
0x76d10000 - 0x76d29000 C:\WINDOWS\system32\iphlpapi.dll
0x76f60000 - 0x76f68000 C:\WINDOWS\System32\winrnr.dll
0x68000000 - 0x68036000 C:\WINDOWS\system32\rsaenh.dll
0x76f70000 - 0x76f76000 C:\WINDOWS\system32\rasadhlp.dll
0x76960000 - 0x76a16000 C:\WINDOWS\system32\USERENV.dll
0x6fee0000 - 0x6ff35000 C:\WINDOWS\system32\netapi32.dll
0x62e40000 - 0x62e99000 C:\WINDOWS\system32\hnetcfg.dll
0x719d0000 - 0x719d8000 C:\WINDOWS\System32\wshtcpip.dll
0x6e640000 - 0x6e660000 C:\Program Files\Java\jre7\bin\sunec.dll
0x6e670000 - 0x6e6a0000 C:\Program Files\Java\jre7\bin\t2k.dll
0x76f80000 - 0x76fff000 C:\WINDOWS\system32\CLBCATQ.DLL
0x77000000 - 0x770d4000 C:\WINDOWS\system32\COMRes.dll
0x49e90000 - 0x49ea1000 C:\WINDOWS\system32\nvwddi.dll
0x6e660000 - 0x6e669000 C:\Program Files\Java\jre7\bin\sunmscapi.dll
0x779e0000 - 0x77a79000 C:\WINDOWS\system32\CRYPT32.dll
0x77a80000 - 0x77a92000 C:\WINDOWS\system32\MSASN1.dll
0x49df0000 - 0x49e5b000 C:\Documents and Settings\Propriétaire\Application Data\.minecraft\bin\natives\lwjgl.dll
0x5f070000 - 0x5f13c000 C:\WINDOWS\system32\OPENGL32.dll
0x6cef0000 - 0x6cf11000 C:\WINDOWS\system32\GLU32.dll
0x736b0000 - 0x736fb000 C:\WINDOWS\system32\DDRAW.dll
0x73b10000 - 0x73b16000 C:\WINDOWS\system32\DCIMAN32.dll
0x6d560000 - 0x6d566000 C:\Program Files\Java\jre7\bin\jawt.dll
0x69500000 - 0x6a770000 C:\WINDOWS\system32\nvoglnt.dll
0x73e60000 - 0x73ebc000 C:\WINDOWS\system32\dsound.dll
0x76be0000 - 0x76c0e000 C:\WINDOWS\system32\WINTRUST.dll
0x76c40000 - 0x76c69000 C:\WINDOWS\system32\IMAGEHLP.dll
0x72c70000 - 0x72c79000 C:\WINDOWS\system32\wdmaud.drv
0x72c60000 - 0x72c68000 C:\WINDOWS\system32\msacm32.drv
0x77bb0000 - 0x77bc5000 C:\WINDOWS\system32\MSACM32.dll
0x77ba0000 - 0x77ba7000 C:\WINDOWS\system32\midimap.dll
0x73e30000 - 0x73e34000 C:\WINDOWS\system32\KsUser.dll
0x6e410000 - 0x6e41a000 C:\Program Files\Java\jre7\bin\management.dll
0x5d3f0000 - 0x5d491000 C:\WINDOWS\system32\dbghelp.dll
VM Arguments:
jvm_args: -Xms512m -Xmx1024m
java_command: C:\Documents and Settings\Propriétaire\Bureau\Minecraft (1).exe
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;c:\Python22;C:\Program Files\Internet Explorer;C:\WINDOWS\system32\WindowsPowerShell\v1.0;C:\Program Files\Java\jre7\bin
USERNAME=Propriétaire
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 15 Model 2 Stepping 9, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 1 (1 cores per cpu, 1 threads per core) family 15 model 2 stepping 9, cmov, cx8, fxsr, mmx, sse, sse2, tsc
Memory: 4k page, physical 2096432k(321040k free), swap 4038296k(2267156k free)
vm_info: Java HotSpot(TM) Client VM (24.51-b03) for windows-x86 JRE (1.7.0_51-b13), built on Dec 18 2013 19:09:58 by "java_re" with unknown MS VC++:1600
time: Sat Apr 12 11:04:05 2014
elapsed time: 2989 seconds
9 réponses
  1. j'ajoute ... j'ai eu mes petits fils aujourd'hui ... :)
    1. Si tu utilise vmware desinstale et va sur java.fr télécharge le et installe le puis tu réinstalle vmware si ses un pc physique réinstalle juste java pour voir si sa marche si sa ne fonctionne toujour pas fais une restoration du systeme a une date antérieure.
      1. Merci Lionel pour cette réponse . Je n'ai pas assez de temps aujourd'hui pour faire tout ça , d'autant que je ne sais pas ce qu'est vmware et que je dois faire beaucoup de recherches pour essayer de comprendre ! je vais avoir le temps demain , donc je te ferai un mot ensuite pour te dire si j'ai réussi . Donc ... à bientôt ! :)
        1. ok de rien on et une communauté pour s'entre aider
      2. bonjour,
        je ne vois pas vmware sur mon panneau de configuration , je ne l'utilise peut être pas . je vais faire une restauration du système à une date antérieure , je te dis ensuite . Est ce que je mets le dossier hs_err_pid1992 à la poubelle s'il se trouve toujours sur le bureau ?
        Merci de ton aide , bonne journée !
        1. voilà , la restauration est faite , j'ai toujours le dossier hs_err ... sur le bureau , j'attends ta réponse avant de jeter . Tout semble fonctionner , mais cette erreur ne m'empêchait pas d'utiliser mon ordi , alors ... ???
      3. bonjour
        tu ne verra jamais vmware dans le panneau de configuration car ses un logiciel de virtualisation pour Windows.
        dans le dossier hs_err_pid1992 il y a quoi si il est vide supprime le et dit moi si ton pc marche toujours si il y a quelque chose regarde les fichier texte s'il y en a et donne moi plus d'info su ta configuration de ton pc et ta version de java
        1. Bonjour
          quel que soit le problème avec java j'ai pris l'habitude de supprimer toutes les versions dans panneau de configuration ajout/supprimer programme puis de retélécharger java depuis le site Oracle pour avoir la dernière version.
          http://www.java.com/fr/download/
          Et si pas de problème je passe vérifier la version sur cette page de temps en temps:
          http://www.java.com/fr/download/installed.jsp
          1. comment depuis adobe ses pas oracle qui le fait
            1. Bonjour
              Yes, corrigé merci.
              En fait je fais pareil pour les produits adobe: flash player, adobe reader, Shochwave player que je prend sur le site adobe.
              http://www.adobe.com/fr/
            2. a quoi sert Shochwave player car dans google chrome ses flash player.
              et mon probleme et dans adobe encore car depuis quelque temp il ne veux pas mettre mes parametre pour mon blu-ray
            3. bonsoir Lionel , je suis désolée d'avoir été si longue à répondre , j'ai eu quelques soucis d'ordre privé ...
              j'ai déjà mis le contenu du dossier hs_err_pid1992 au début de la conversation , avec ma demande , remonte , tu vas le voir ...
              Je ne l'ai pas jeté encore , je peux utiliser normalement mon ordi , sauf quelques fois , le shockwave player se bloque , je ne sais pas si les 2 problèmes sont liés . Je suis une grand mère , et ce n'est pas si facile pour moi ! :)
              Merci de ton aide , bonne semaine !
          2. bonsoir
            crée un point de restauration et supprime le dossier si tu vois une défaillance dans ton ordinateur restaure le et dit moi le problème avec shockwave player la ou il se bloque.
            1. bonjour , je viens de faire le point de restauration , j'ai jeté le dossier en question , tout semble normal . Pour shockwave flash player , il se bloque quand je suis sur mon jeu préféré : farmtown et que je vais sur les fermes de mes voisins très chargées , avec des cultures en 9 couches , des arbres ou fleurs par dessus ... mais aussi il se fige ailleurs et j'ai un panneau qui me dit qu'il est bloqué , que ce soit sur firefox ou sur google chrome ; alors j'attends que monsieur le shockwave veuille bien se débloquer ! :) quelques fois , il se bloque aussi sur ma boite mail ! Je comprends pour farmtown , mais pour ma boîte mail ?
          3. tu utilise windows xp ,vista ,7 ,8 ,8.1 --> tu tape winver dans exécuter est ta version est en haut ecrie en gros
            tu devrais suprimer tout adobe de ton pc est le reinstaller par le site adobe.fr.
            donne des nouvelle apres avoir fait cela.
            1. ah ! merci Lionel ! je vais m'occuper de ça dès que possible ... j'ai un autre souci avec le pc portable de mon mari qui a pris des virus , je regarde le mode sans échec sur comment ça marche , je ferai un nouveau message dès que j'arrive à comprendre un peu le problème , je te mettrais le lien ici . Là , je vais avoir besoin d'aide " grave " !!! :)
            2. avec un cd Ubuntu tu redémarre et tu récupére tes fichier ensuite tu réinstalle Windows en formatent le disque dur
            3. Bonjour Lionel ,
              Je me doutais bien que je n'arriverais pas à nettoyer le pc de mon mari ! Merci de tes bons conseils , je vais voir de ce pas ce qu'est un cd Ubuntu , je suppose que je vais devoir en acheter un puisque je ne sais pas ce que c'est , je ne dois pas posséder ça ! Par contre , je sais formater . Donc , merci beaucoup , je vais pouvoir conserver les fichiers de mon mari , c'est important pour lui ! :) Je te tiendrai au courant ! A bientôt !
