Probleme de compilation
Bonjour, je veux compiler ce programme :
#include <stdio.h>
#include <errno.h>
#include <string.h>
#include <signal.h>
#include <unistd.h>
#include <fcntl.h>
#include <netdb.h>
#include <getopt.h>
#include <netinet/in.h>
#include <sys/socket.h>
#define DEBUG 1
#define TRACKING 0
#define PACKET_SIZE 1024
#define MAX(a,b) (a<b?b:a)
#define FSET(a,b,c) (FD_ISSET(a,c)?a:b)
#define NFSET(a,b,c) (FD_ISSET(a,c)?b:a)
int writen(int fd, char *ptr, int n);
int readn(int fd, char *ptr, int n);
int forward(int fin, int fout);
unsigned short server_port = 12345;
char *target_name = "target";
unsigned short target_port = 80;
struct sockaddr_in serverSock, clientSock, targetSock;
int fserver, ftarget, fcurrent;
void usage ( void ) {
printf ( "Usage: tunnel [OPTION]\n"
"open a tunnel \n\n"
" -? \t this help\n"
" -l port\t local port to listen ( default 12345 )\n"
" -t host\t target hostname ( default target )\n"
" -p port\t target port ( default 80 )\n");
int main(int argc, char *argv[])
int ret, len, c;
struct hostent *targetHostEnt; /* description du host serveur */
unsigned long hostAddr; /* addr du serveur */
fd_set fdsr;
long flags;
while ( ( c = getopt(argc,argv,"?l:p:t:") ) != -1 ) {
switch ( c ) {
case 'l' : server_port = atoi(optarg); break;
case 'p' : target_port = atoi(optarg); break;
case 't' : target_name = strdup(optarg); break;
case '?' :
default :
usage();
return 0;
if (DEBUG) printf("%s:%d\n",target_name,target_port);
fserver = socket(AF_INET, SOCK_STREAM, 0);
if (fserver < 0) {
perror("socket");
return -1;
} else if ( DEBUG ) {
if (DEBUG) printf("server : %d\n",fserver);
serverSock.sin_family = AF_INET;
serverSock.sin_addr.s_addr = INADDR_ANY;
serverSock.sin_port = htons(server_port);
if (bind(fserver, (struct sockaddr *) &serverSock, sizeof(struct sockaddr_in))
< 0) {
perror("bind");
return -1;
if (listen(fserver, 0) < 0) {
perror("listen");
return -1;
for (;;) {
FD_ZERO(&fdsr);
FD_SET(fserver, &fdsr);
ret = select(fserver + 1, &fdsr, 0, 0, 0);
if (ret <= 0) {
close(fserver);
fcurrent = accept(fserver, (struct sockaddr *) &clientSock, &len);
fcntl(fcurrent, F_GETFL, &flags);
flags |= O_NONBLOCK;
fcntl(fcurrent, F_SETFL, &flags);
if (DEBUG) {
if (DEBUG) printf("current : %d\n", fcurrent);
bzero(&targetSock, sizeof(targetSock));
hostAddr = inet_addr(target_name);
if ((long) hostAddr != (long) -1)
bcopy(&hostAddr, &targetSock.sin_addr, sizeof(hostAddr));
else { /* si on a donne un nom */
targetHostEnt = gethostbyname(target_name);
if (targetHostEnt == NULL) {
if (DEBUG) printf("ca chie gethost\n");
exit(0);
bcopy(targetHostEnt->h_addr, &targetSock.sin_addr,targetHostEnt->h_length);
targetSock.sin_port = htons(target_port); /* host to network port */
targetSock.sin_family = AF_INET; /* AF_*** : INET=internet */
if ((ftarget = socket(AF_INET, SOCK_STREAM, 0)) < 0) {
if (DEBUG) printf("ca chie creation socket client\n");
exit(0);
if (connect (ftarget, (struct sockaddr *) &targetSock,sizeof(targetSock))<0) {
if (DEBUG) printf("ca chie demande de connection %s\n", target_name);
exit(0);
if (DEBUG) {
if (DEBUG) printf("target : %d\n", ftarget);
fcntl(ftarget, F_GETFL, &flags);
fcntl(ftarget, F_SETFL, &flags);
do {
FD_ZERO(&fdsr);
FD_SET(fcurrent, &fdsr);
FD_SET(ftarget, &fdsr);
if (DEBUG) printf("?");
ret = select(MAX(fcurrent, ftarget) + 1, &fdsr, 0, 0, 0);
if (ret <= 0) {
if (DEBUG) printf("on ferme\n");
close(ftarget);
close(fcurrent);
break;
len = 0;
if ( FD_ISSET(fcurrent,&fdsr) )
len = forward(fcurrent, ftarget);
if ( FD_ISSET(ftarget,&fdsr) )
len = forward(ftarget, fcurrent);
} while (len);
close(fcurrent);
close(ftarget);
return 0;
int nl, nw;
nl = n;
while ( nl > 0 ) {
nw = write(fd, ptr, nl);
if ( nw <= 0 )
return nw; /*error*/
nl -= nw;
ptr += nw;
return (n-nl);
int readn(int fd, char *ptr, int n){
int nl, nr;
nl = n;
while ( nl > 0 ) {
nr = read(fd,ptr,nl);
if (nr < 0 ) {
if ( nr == -1 ) {
*ptr = 0x00;
return (n-nl);
return nr; /*error*/
} else {
if ( nr == 0 )
break;
nl -= nr;
ptr += nr;
*ptr = 0x00;
return (n-nl);
int len;
char buffer[PACKET_SIZE + 1];
if (DEBUG) printf ( "%d -> %d\n",fin,fout);
do {
len = readn(fin, buffer, PACKET_SIZE);
buffer[len] = 0x00;
if (TRACKING) printf("-%d->%s<--\n",len,buffer);
writen(fout, buffer, len);
} while (len == PACKET_SIZE);
return len;
Il me met l'erreur suivant :
gpsd.c:1: error: stray '\357' in program
gpsd.c:1: error: stray '\273' in program
gpsd.c:1: error: stray '\277' in program
gpsd.c:1: error: syntax error at '#' token
gpsd.c:1: error: syntax error before '<' token
make: *** [obj/gpsd.o] Fehler 1
K'ai vraiment pas compris pourquoi
Quelqu'un pourra m'aide ?
C* -----> Either exist as you are or be as you look <---- C*
Configuration: Linux
Firefox 1.0.7
    etrange. On a l'impression qu'il y a des caractères invisible avant ton premier #
    ou aor ton compilo est mal installer
    1. g peut etre un makefile chelou di moi toi tu compile sous linux ou windows et tu compiles avec gcc -o prog prog.c ?
        je compile sous windows, Donc ça compile pas (pas les même include).
        Par contre, j'ai des messages d'erreurs habituel.
        j'ai jamais vu ça ! et en plus le #include <... ne semble pas lui plaire.
        je te conseillerai d'enregistrer la source avec un autre éditeur.
        1. Franchement bien je n'aurai pas pense que c a cause de lediteur
