Problème de thème wordpress impossible de voir le site
j'ai déjà posté sur le forum wordpress, mais bon
J'ai un gros problème j'ai voulu modifier un théme, mais j'ai tout fait bugguer. Voilà ce qui s'affiche lorsque l'on va sur le site :
Parse error: syntax error, unexpected '}', expecting ')' in /var/www/vhosts/pharos-asso.fr/httpdocs/wp-content/themes/magazino/functions.php on line 704
Si quelqu'un a le fonction php original du thème magzino wordpress...
voilà ce qui est dans le fonctionphp :
<?php
* Sets up the theme and provides some helper functions. Some helper functions
* are used in the theme as custom template tags. Others are attached to action and
* filter hooks in WordPress to change core functionality.
* For more information on hooks, actions, and filters, see https://codex.wordpress.org/Plugin_API
if ( ! function_exists( 'magazino_setup' ) ):
* Sets up theme defaults and registers support for various WordPress features.
function magazino_setup() {
* Make theme available for translation
* Translations can be filed in the /languages/ directory
load_theme_textdomain( 'magazino', get_template_directory() . '/languages' );
* Add default posts and comments RSS feed links to head
add_theme_support( 'automatic-feed-links' );
* This theme uses wp_nav_menu() in one location.
register_nav_menus( array(
'primary' => __( 'Primary Menu', 'magazino' ),
add_theme_support('post-thumbnails');
// This theme styles the visual editor with editor-style.css to match the theme style.
add_editor_style();
// custom backgrounds
$magazino_custom_background = array(
'default-color' => 'e5e5e5',
'default-image' => '',
'wp-head-callback' => '_custom_background_cb'
add_theme_support('custom-background', $magazino_custom_background );
// adding post format support
add_theme_support( 'post-formats',
array(
'aside', /* Typically styled without a title. Similar to a Facebook note update */
'gallery', /* A gallery of images. Post will likely contain a gallery shortcode and will have image attachments */
'link', /* A link to another site. Themes may wish to use the first <a href=ÓÓ> tag in the post content as the external link for that post. An alternative approach could be if the post consists only of a URL, then that will be the URL and the title (post_title) will be the name attached to the anchor for it */
'image', /* A single image. The first <img /> tag in the post could be considered the image. Alternatively, if the post consists only of a URL, that will be the image URL and the title of the post (post_title) will be the title attribute for the image */
'quote', /* A quotation. Probably will contain a blockquote holding the quote content. Alternatively, the quote may be just the content, with the source/author being the title */
'status', /*A short status update, similar to a Twitter status update */
'video', /* A single video. The first <video /> tag or object/embed in the post content could be considered the video. Alternatively, if the post consists only of a URL, that will be the video URL. May also contain the video as an attachment to the post, if video support is enabled on the blog (like via a plugin) */
'audio', /* An audio file. Could be used for Podcasting */
'chat' /* A chat transcript */
endif;
add_action( 'after_setup_theme', 'magazino_setup' );
* Set the content width based on the theme's design and stylesheet.
if ( ! function_exists( 'magazino_content_width' ) ) :
function magazino_content_width() {
global $content_width;
if (!isset($content_width))
$content_width = 550; /* pixels */
endif;
add_action( 'after_setup_theme', 'magazino_content_width' );
* Title filter
if ( ! function_exists( 'magazino_filter_wp_title' ) ) :
function magazino_filter_wp_title( $old_title, $sep, $sep_location ) {
$site_name = get_bloginfo( 'name' );
$site_description = get_bloginfo( 'description' );
// add padding to the sep
$ssep = ' ' . $sep . ' ';
if ( $site_description && ( is_home() || is_front_page() ) ) {
return $site_name . ' | ' . $site_description;
} else {
// find the type of index page this is
if( is_category() ) $insert = $ssep . __( 'Category', 'magazino' );
elseif( is_tag() ) $insert = $ssep . __( 'Tag', 'magazino' );
elseif( is_author() ) $insert = $ssep . __( 'Author', 'magazino' );
elseif( is_year() || is_month() || is_day() ) $insert = $ssep . __( 'Archives', 'magazino' );
else $insert = NULL;
// get the page number we're on (index)
if( get_query_var( 'paged' ) )
$num = $ssep . __( 'Page ', 'magazino' ) . get_query_var( 'paged' );
// get the page number we're on (multipage post)
elseif( get_query_var( 'page' ) )
$num = $ssep . __( 'Page ', 'magazino' ) . get_query_var( 'page' );
// else
else $num = NULL;
// concoct and return new title
return $site_name . $insert . $old_title . $num;
endif;
// call our custom wp_title filter, with normal (10) priority, and 3 args
add_filter( 'wp_title', 'magazino_filter_wp_title', 10, 3 );
* These are settings for the Theme Customizer in the admin panel.
if ( ! function_exists( 'magazino_theme_customizer' ) ) :
function magazino_theme_customizer( $wp_customize ) {
$wp_customize->remove_section( 'title_tagline');
$wp_customize->remove_section( 'static_front_page' );
/* color scheme option */
$wp_customize->add_setting( 'magazino_color_settings', array (
'default' => '#9dbb41',
$wp_customize->add_control( new WP_Customize_Color_Control( $wp_customize, 'magazino_color_settings', array(
'label' => __( 'Theme Color Scheme', 'magazino' ),
'section' => 'colors',
'settings' => 'magazino_color_settings',
/* logo option */
$wp_customize->add_section( 'magazino_logo_section' , array(
'title' => __( 'Site Logo', 'magazino' ),
'priority' => 31,
'description' => __( 'Upload a logo to replace the default site name in the header', 'magazino' ),
$wp_customize->add_setting( 'magazino_logo' );
$wp_customize->add_control( new WP_Customize_Image_Control( $wp_customize, 'magazino_logo', array(
'label' => __( 'Choose your logo (ideal width is 100-300px and ideal height is 40-100px)', 'magazino' ),
'section' => 'magazino_logo_section',
'settings' => 'magazino_logo',
/* social media option */
$wp_customize->add_section( 'magazino_social_section' , array(
'title' => __( 'Social Media Icons', 'magazino' ),
'priority' => 32,
'description' => __( 'Optional facebook icon in the navigation bar', 'magazino' ),
$wp_customize->add_setting( 'magazino_facebook' );
$wp_customize->add_control( new WP_Customize_Control( $wp_customize, 'magazino_facebook', array(
'label' => __( 'Enter your facebook url', 'magazino' ),
'section' => 'magazino_social_section',
'settings' => 'magazino_facebook',
$wp_customize->add_setting( 'magazino_twitter' );
$wp_customize->add_control( new WP_Customize_Control( $wp_customize, 'magazino_twitter', array(
'label' => __( 'Enter your twitter url', 'magazino' ),
'settings' => 'magazino_twitter',
$wp_customize->add_setting( 'magazino_google' );
$wp_customize->add_control( new WP_Customize_Control( $wp_customize, 'magazino_google', array(
'label' => __( 'Enter your google+ url', 'magazino' ),
'settings' => 'magazino_google',
$wp_customize->add_setting( 'magazino_pinterest' );
$wp_customize->add_control( new WP_Customize_Control( $wp_customize, 'magazino_pinterest', array(
'label' => __( 'Enter your pinterest url', 'magazino' ),
'settings' => 'magazino_pinterest',
$wp_customize->add_setting( 'magazino_linkedin' );
$wp_customize->add_control( new WP_Customize_Control( $wp_customize, 'magazino_linkedin', array(
'label' => __( 'Enter your linkedin url', 'magazino' ),
'settings' => 'magazino_linkedin',
$wp_customize->add_setting( 'magazino_youtube' );
$wp_customize->add_control( new WP_Customize_Control( $wp_customize, 'magazino_youtube', array(
'label' => __( 'Enter your youtube url', 'magazino' ),
'settings' => 'magazino_youtube',
$wp_customize->add_setting( 'magazino_tumblr' );
$wp_customize->add_control( new WP_Customize_Control( $wp_customize, 'magazino_tumblr', array(
'label' => __( 'Enter your Tumblr url', 'magazino' ),
'settings' => 'magazino_tumblr',
$wp_customize->add_setting( 'magazino_instagram' );
$wp_customize->add_control( new WP_Customize_Control( $wp_customize, 'magazino_instagram', array(
'label' => __( 'Enter your Instagram url', 'magazino' ),
'settings' => 'magazino_instagram',
$wp_customize->add_setting( 'magazino_flickr' );
$wp_customize->add_control( new WP_Customize_Control( $wp_customize, 'magazino_flickr', array(
'label' => __( 'Enter your Flickr url', 'magazino' ),
'settings' => 'magazino_flickr',
$wp_customize->add_setting( 'magazino_vimeo' );
$wp_customize->add_control( new WP_Customize_Control( $wp_customize, 'magazino_vimeo', array(
'label' => __( 'Enter your Vimeo url', 'magazino' ),
'settings' => 'magazino_vimeo',
/* slider options */
$wp_customize->add_section( 'magazino_slider_section' , array(
'title' => __( 'Slider Options', 'magazino' ),
'priority' => 33,
'description' => __( 'Adjust the behavior of the image slider.', 'magazino' ),
$wp_customize->add_setting( 'magazino_slider_effect', array(
'default' => 'scrollHorz',
'capability' => 'edit_theme_options',
$wp_customize->add_control( 'effect_select_box', array(
'settings' => 'magazino_slider_effect',
'label' => __( 'Select Effect:', 'magazino' ),
'section' => 'magazino_slider_section',
'type' => 'select',
'choices' => array(
'scrollHorz' => 'Horizontal (Default)',
'scrollVert' => 'Vertical',
'tileSlide' => 'Tile Slide',
'tileBlind' => 'Blinds',
$wp_customize->add_setting( 'magazino_slider_timeout' );
$wp_customize->add_control( new WP_Customize_Control( $wp_customize, 'magazino_slider_timeout', array(
'label' => __( 'Autoplay Speed in Seconds (0 for Manual)', 'magazino' ),
'settings' => 'magazino_slider_timeout',
$wp_customize->add_setting( 'magazino_slider_pager' );
$wp_customize->add_control('enable_pager', array(
'settings' => 'magazino_slider_pager',
'label' => __('Enable pager', 'magazino'),
'type' => 'checkbox',
endif;
add_action('customize_register', 'magazino_theme_customizer');
* Apply Color Scheme
if ( ! function_exists( 'magazino_apply_color' ) ) :
function magazino_apply_color() {
if ( get_theme_mod('magazino_color_settings') ) {
<style>
a, a:visited,
#site-title a,
nav[role=navigation] .menu ul li a:hover,
nav[role=navigation] .menu ul li.current-menu-item a,
.nav ul li.current_page_item a,
nav[role=navigation] .menu ul li.current_page_item a,
#sidebar .widget-title,
.slides .slide-title,
.commentlist .vcard cite.fn a,
.commentlist .comment-meta a:hover,
.post_content ul li:before,
.post_content ol li:before,
.colortxt,
.commentlist .bypostauthor > article > footer > .vcard cite.fn,
.cycle-pager span.cycle-pager-active {
color: <?php echo get_theme_mod('magazino_color_settings'); ?>;
#container,
#sidebar {
border-top: 2px solid <?php echo get_theme_mod('magazino_color_settings'); ?>;
#search-box-wrap,
#social-media a,
#search-icon,
.go-button a,
.go-button a:visited,
.grnbar,
.pagination a:hover,
.pagination .current,
#respond #submit {
background-color: <?php echo get_theme_mod('magazino_color_settings'); ?>;
.post_content pre {
border-left-color: <?php echo get_theme_mod('magazino_color_settings'); ?>;
</style>
<?php
endif;
add_action( 'wp_head', 'magazino_apply_color' );
* Filter the RSS Feed Site Title
if ( ! function_exists( 'magazino_blogname_rss' ) ) :
function magazino_blogname_rss( $val, $show ) {
if( 'name' == $show )
$out = '';
else
$out = $val;
return $out;
endif;
add_filter('bloginfo_rss', 'magazino_blogname_rss', 10, 2);
* Get our wp_nav_menu() fallback, wp_page_menu(), to show a home link.
if ( ! function_exists( 'magazino_main_nav' ) ) :
function magazino_main_nav() {
// display the wp3 menu if available
wp_nav_menu(
array(
'menu' => '', /* menu name */
'theme_location' => 'primary', /* where in the theme it's assigned */
'container_class' => 'menu', /* container class */
'fallback_cb' => 'magazino_main_nav_fallback' /* menu fallback */
endif;
if ( ! function_exists( 'magazino_main_nav_fallback' ) ) :
function magazino_main_nav_fallback() { wp_page_menu( 'show_home=Home&menu_class=menu' ); }
endif;
if ( ! function_exists( 'magazino_enqueue_comment_reply' ) ) :
function magazino_enqueue_comment_reply() {
if ( is_singular() && comments_open() && get_option( 'thread_comments' ) ) {
wp_enqueue_script( 'comment-reply' );
endif;
add_action( 'comment_form_before', 'magazino_enqueue_comment_reply' );
if ( ! function_exists( 'magazino_page_menu_args' ) ) :
function magazino_page_menu_args( $args ) {
$args['show_home'] = true;
return $args;
endif;
add_filter( 'wp_page_menu_args', 'magazino_page_menu_args' );
* Register widgetized area and update sidebar with default widgets
if ( ! function_exists( 'magazino_widgets_init' ) ) :
function magazino_widgets_init() {
register_sidebar( array(
'name' => __( 'Footer Sidebar', 'magazino' ),
'id' => 'sidebar-1',
'before_widget' => '<aside id="%1$s" class="widget %2$s">',
'after_widget' => "</aside>",
'before_title' => '<div class="widget-title">',
'after_title' => '</div>',
endif;
add_action( 'widgets_init', 'magazino_widgets_init' );
if ( ! function_exists( 'magazino_content_nav' ) ):
* Display navigation to next/previous pages when applicable
function magazino_content_nav( $nav_id ) {
global $wp_query;
<nav id="<?php echo $nav_id; ?>">
<h1 class="assistive-text section-heading"><?php _e( 'Post navigation', 'magazino' ); ?></h1>
<?php if ( is_single() ) : // navigation links for single posts ?>
<?php previous_post_link( '<div class="nav-previous">%link</div>', '<span class="meta-nav">' . _x( '← Previous', 'Previous post link', 'magazino' ) . '</span>' ); ?>
<?php next_post_link( '<div class="nav-next">%link</div>', '<span class="meta-nav">' . _x( 'Next →', 'Next post link', 'magazino' ) . '</span>' ); ?>
<?php elseif ( $wp_query->max_num_pages > 1 && ( is_home() || is_archive() || is_search() ) ) : // navigation links for home, archive, and search pages ?>
<?php if ( get_next_posts_link() ) : ?>
<div class="nav-previous"><?php next_posts_link( __( '<span class="meta-nav">←</span> Older posts', 'magazino' ) ); ?></div>
<?php endif; ?>
<?php if ( get_previous_posts_link() ) : ?>
<div class="nav-next"><?php previous_posts_link( __( 'Newer posts <span class="meta-nav">→</span>', 'magazino' ) ); ?></div>
<?php endif; ?>
<?php endif; ?>
</nav><!-- #<?php echo $nav_id; ?> -->
<?php
endif;
if ( ! function_exists( 'magazino_comment' ) ) :
* Template for comments and pingbacks.
function magazino_comment( $comment, $args, $depth ) {
$GLOBALS['comment'] = $comment;
switch ( $comment->comment_type ) :
case 'pingback' :
case 'trackback' :
<li class="post pingback">
<p><?php _e( 'Pingback:', 'magazino' ); ?> <?php comment_author_link(); ?><?php edit_comment_link( __( '(Edit)', 'magazino' ), ' ' ); ?></p>
<?php
break;
default :
<li <?php comment_class(); ?> id="li-comment-<?php comment_ID(); ?>">
<article id="comment-<?php comment_ID(); ?>">
<footer class="clearfix comment-head">
<div class="comment-author vcard">
<?php echo get_avatar( $comment, 40 ); ?>
<?php printf( __( '%s', 'magazino' ), sprintf( '<cite class="fn">%s</cite>', get_comment_author_link() ) ); ?>
</div><!-- .comment-author .vcard -->
<?php if ( $comment->comment_approved == '0' ) : ?>
<em><?php _e( 'Your comment is awaiting moderation.', 'magazino' ); ?></em>
<br />
<?php endif; ?>
<div class="comment-meta commentmetadata">
<a href="<?php echo esc_url( get_comment_link( $comment->comment_ID ) ); ?>"><time pubdate datetime="<?php comment_time( 'c' ); ?>">
<?php
/* translators: 1: date, 2: time */
printf( __( '%1$s at %2$s <span class="bsep">•</span> ', 'magazino' ), get_comment_date(), get_comment_time() ); ?>
</time></a>
<?php edit_comment_link( __( '(Edit) <span class="bsep">•</span> ', 'magazino' ), ' ' );
<?php comment_reply_link( array_merge( $args, array( 'depth' => $depth, 'max_depth' => $args['max_depth'] ) ) ); ?>
</div><!-- .comment-meta .commentmetadata -->
</footer>
<div class="comment-content"><?php comment_text(); ?></div>
</article><!-- #comment-## -->
<?php
break;
endswitch;
endif;
if ( ! function_exists( 'magazino_posted_on' ) ) :
* Prints HTML with meta information for the current post-date/time and author.
function magazino_posted_on() {
printf( __( '<span class="sep">Posted on </span><a href="%1$s" title="%2$s" rel="bookmark"><time class="entry-date" datetime="%3$s">%4$s</time></a><span class="byline"> <span class="sep"> by </span> <span class="author vcard"><a class="url fn n" href="%5$s" title="%6$s" rel="author">%7$s</a></span></span>', 'magazino' ),
esc_url( get_permalink() ),
esc_attr( get_the_time() ),
esc_attr( get_the_date( 'c' ) ),
esc_html( get_the_date() ),
esc_url( get_author_posts_url( get_the_author_meta( 'ID' ) ) ),
esc_attr( sprintf( __( 'View all posts by %s', 'magazino' ), get_the_author() ) ),
esc_html( get_the_author() )
endif;
* Adds custom classes to the array of body classes.
if ( ! function_exists( 'magazino_body_classes' ) ) :
function magazino_body_classes( $classes ) {
// Adds a class of single-author to blogs with only 1 published author
if ( ! is_multi_author() ) {
$classes[] = 'single-author';
return $classes;
endif;
add_filter( 'body_class', 'magazino_body_classes' );
* Returns true if a blog has more than 1 category
if ( ! function_exists( 'magazino_categorized_blog' ) ) :
function magazino_categorized_blog() {
if ( false === ( $all_the_cool_cats = get_transient( 'all_the_cool_cats' ) ) ) {
// Create an array of all the categories that are attached to posts
$all_the_cool_cats = get_categories( array(
'hide_empty' => 1,
// Count the number of categories that are attached to the posts
$all_the_cool_cats = count( $all_the_cool_cats );
set_transient( 'all_the_cool_cats', $all_the_cool_cats );
if ( '1' != $all_the_cool_cats ) {
// This blog has more than 1 category so magazino_categorized_blog should return true
return true;
} else {
// This blog has only 1 category so magazino_categorized_blog should return false
return false;
endif;
* Flush out the transients used in magazino_categorized_blog
if ( ! function_exists( 'magazino_category_transient_flusher' ) ) :
function magazino_category_transient_flusher() {
// Like, beat it. Dig?
delete_transient( 'all_the_cool_cats' );
endif;
add_action( 'edit_category', 'magazino_category_transient_flusher' );
add_action( 'save_post', 'magazino_category_transient_flusher' );
* Filter in a link to a content ID attribute for the next/previous image links on image attachment pages
if ( ! function_exists( 'magazino_enhanced_image_navigation' ) ) :
function magazino_enhanced_image_navigation( $url ) {
global $post, $wp_rewrite;
$id = (int) $post->ID;
$object = get_post( $id );
if ( wp_attachment_is_image( $post->ID ) && ( $wp_rewrite->using_permalinks() && ( $object->post_parent > 0 ) && ( $object->post_parent != $id ) ) )
$url = $url . '#main';
return $url;
endif;
add_filter( 'attachment_link', 'magazino_enhanced_image_navigation' );
if ( ! function_exists( 'magazino_pagination' ) ) :
function magazino_pagination($pages = '', $range = 4)
$showitems = ($range * 2)+1;
global $paged;
if(empty($paged)) $paged = 1;
if($pages == '')
global $wp_query;
$pages = $wp_query->max_num_pages;
if(!$pages)
$pages = 1;
if(1 != $pages)
printf( __( '<div class="pagination"><span>Page %1$s of %2$s</span>', 'magazino'), $paged, $pages );
if($paged > 2 && $paged > $range+1 && $showitems < $pages) printf( __( '<a href="%1$s">« First</a>', 'magazino' ), get_pagenum_link(1) );
if($paged > 1 && $showitems < $pages) printf( __( '<a href="%1$s">‹ Previous</a>', 'magazino' ), get_pagenum_link($paged - 1) );
for ($i=1; $i <= $pages; $i++)
if (1 != $pages &&( !($i >= $paged+$range+1 || $i <= $paged-$range-1) || $pages <= $showitems ))
echo ($paged == $i)? "<span class=\"current\">".$i."</span>":"<a href='".get_pagenum_link($i)."' class=\"inactive\">".$i."</a>";
if ($paged < $pages && $showitems < $pages) printf( __( '<a href="%1$s">Next ›</a>', 'magazino' ), get_pagenum_link($paged + 1) );
if ($paged < $pages-1 && $paged+$range-1 < $pages && $showitems < $pages) printf( __( '<a href="%1$s">Last »</a>', 'magazino' ), get_pagenum_link($pages) );
echo "</div>\n";
endif;
if ( ! function_exists( 'magazino_excerpt' ) ) :
function magazino_excerpt($limit) {
$excerpt = explode(' ', get_the_excerpt(), $limit);
if (count($excerpt)>=$limit) {
array_pop($excerpt);
$excerpt = implode(" ",$excerpt).'...';
} else {
$excerpt = implode(" ",$excerpt);
$excerpt = preg_replace(''\[[^\]]*\]'','',$excerpt);
return $excerpt;
endif;
if ( ! function_exists( 'magazino_content' ) ) :
function magazino_content($limit) {
$content = explode(' ', get_the_content(), $limit);
if (count($content)>=$limit) {
array_pop($content);
$content = implode(" ",$content).'...';
} else {
$content = implode(" ",$content);
$content = preg_replace('/\[.+\]/','', $content);
$content = apply_filters('the_content', $content);
$content = str_replace(']]>', ']]>', $content);
return $content;
endif;
if ( ! function_exists( 'magazino_w3c_valid_rel' ) ) :
function magazino_w3c_valid_rel( $text ) {
$text = str_replace('rel="category tag"', 'rel="tag"', $text); return $text;
endif;
add_filter( 'the_category', 'magazino_w3c_valid_rel' );
if ( ! function_exists( 'magazino_modernizr_addclass' ) ) :
function magazino_modernizr_addclass($output) {
return $output . ' class="no-js"' );
endif;
add_filter('language_attributes', 'magazino_modernizr_addclass');
if ( ! function_exists( 'magazino_modernizr_script' ) ) :
function magazino_modernizr_script() {
wp_enqueue_script( 'modernizr', get_template_directory_uri() . '/library/js/modernizr-2.6.2.min.js', false, '2.6.2');
endif;
add_action('wp_enqueue_scripts', 'magazino_modernizr_script');
if ( ! function_exists( 'magazino_custom_scripts' ) ) :
function magazino_custom_scripts() {
wp_enqueue_script( 'magazino_cycle_js', get_template_directory_uri() . '/library/js/jquery.cycle2.min.js', array( 'jquery' ), '20130202' );
wp_enqueue_script( 'magazino_cycle_tile_js', get_template_directory_uri() . '/library/js/jquery.cycle2.tile.min.js', array( 'jquery' ), '20121120' );
wp_enqueue_script( 'magazino_cycle_scrollvert_js', get_template_directory_uri() . '/library/js/jquery.cycle2.scrollVert.min.js', array( 'jquery' ), '20121120' );
wp_enqueue_script( 'magazino_custom_js', get_template_directory_uri() . '/library/js/scripts.js', array( 'jquery' ), '1.0.0' );
wp_enqueue_style( 'magazino_style', get_stylesheet_uri() );
endif;
add_action('wp_enqueue_scripts', 'magazino_custom_scripts');
    Il y a 697 lignes dans le code que tu donnes et tu signales un message faisant mention de la ligne 704. Donc j'en déduis qu'il manque quelque chose dans ce que tu as copié
    Sinon le message me semble clair quand même
    Signifie qu'à la ligne 704 il a un } inattendu alors qu'il attendait un ) .
    Un conseil : la fonction "compter" dans la recherche de notepad++ (et surrement de la plupart des éditeurs de texte), tu y verras que tu as :
    - 407 ouvertures de parenthèses et 408 fermetures de parenthèses
    - 46 ouvertures de crochets et bien 46 fermetures de crochets.
    Donc tu sais maintenant que l'erreur provient d'un oubli d'ouverture de parenthèse ou d'une parenthèse fermée en double ;) .
      Si la ligne 704 est la dernière ce n'est pas forcément elle qui a une erreur, ça veut dire qu'il attend un truc et ne le trouvant toujours pas en arrivant à la dernière ligne c'est là qu'il signale l'erreur.
      En tout cas il y a une parenthèse fermée de plus que d'ouverte donc il faut trouver où.
      1. Ok je dois la chercher à l'oeil ? notepad n'a pas d'outils pour je veux
        merci de ton aide
        1. J'ai trouvé le function.php de base du thème. Quand je remplace il m'affiche quand même l'erreur. Pourquoi si ça viendrait de la paranthèse, il planterait même avec ces commandes
          C'est celui-çi :
          <?php
          add_editor_style();
          array(
          'link', /* A link to another site. Themes may wish to use the first <a href=Ã"Ã"> tag in the post content as the external link for that post. An alternative approach could be if the post consists only of a URL, then that will be the URL and the title (post_title) will be the name attached to the anchor for it */
          endif;
          * Title filter
          } else {
          // else
          else $num = NULL;
          /* logo option */
          'priority' => 31,
          'label' => __( 'Choose your logo (ideal width is 100-300px and ideal height is 40-100px)', 'restaurateur' ),
          'priority' => 32,
          'priority' => 33,
          'type' => 'select',
          'choices' => array(
          <style>
          a, a:visited,
          #site-title a,
          .colortxt,
          #container,
          #sidebar {
          #search-box-wrap,
          #social-media a,
          #search-icon,
          .go-button a,
          .grnbar,
          #respond #submit {
          .post_content pre {
          </style>
          <?php
          $out = '';
          else
          $out = $val;
          return $out;
          wp_nav_menu(
          array(
          endif;
          endif;
          return $args;
          global $wp_query;
          <?php endif; ?>
          <?php endif; ?>
          <?php endif; ?>
          <?php
          endif;
          case 'pingback' :
          case 'trackback' :
          <?php
          break;
          default :
          <br />
          <?php endif; ?>
          <?php
          </time></a>
          </footer>
          <?php
          break;
          endswitch;
          endif;
          endif;
          return $classes;
          'hide_empty' => 1,
          return true;
          } else {
          return false;
          return $url;
          global $paged;
          if($pages == '')
          global $wp_query;
          if(!$pages)
          $pages = 1;
          if(1 != $pages)
          echo "</div>\n";
          endif;
          } else {
          return $excerpt;
          } else {
          return $content;
          return $output . ' class="no-js"';
            Il t'affiche le même message ? Si c'est le cas c'est que le thème a un soucis, si tu as un lien vers le thème et qu'il est gratuit je veux bien tester demain soir si il marche chez moi.
            1. Oui le même message. J'ai le dossier du thème. J'ai vraiment remplacé le function.php sur la commande. Enfait j'ai accés qu'au modifications graphiques (j'entends par là, que je peux que me connecter sur le site pour modifier, je n'ai pas le ftp le site ne m'appartient pas). Malheureusement même après avoir modifier et enregistrer il m'affiche cette ereur (que je me connecte au /admin ou non). Je ne peux rien faire, j'ai essayé de cliquer sur les différents onglets sans succès
