[java]Problème avec instanceof button
bonsoir
en compilant mon prg j'ai pb avec instanceof button
j'ai message suivantes:
bonsoir
Exception in thread "AWT-EventQueue-0" java.lang.Error: Unresolved compilation problems: Event.get cannot be resolved Syntax error on token "instanceOf", instanceof expected at Studentfile.handleEvent(Studentfile.java:106) at java.awt.Window.postEvent(Window.java:2722) at java.awt.Component.postEvent(Component.java:5169) at java.awt.Component.dispatchEventImpl(Component.java:4876) at java.awt.Component.dispatchEvent(Component.java:4686) at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1908) at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:928) at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:560) at java.awt.Component.dispatchEventImpl(Component.java:4730) at java.awt.Component.dispatchEvent(Component.java:4686) at sun.awt.SunToolkit$4.run(SunToolkit.java:588) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:251) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:705) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:675) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:211) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:128) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:117) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:113) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:105) at java.awt.EventDispatchThread.run(EventDispatchThread.java:90) Exception in thread "AWT-EventQueue-0" java.lang.Error: Unresolved compilation problems: Event.get cannot be resolved Syntax error on token "instanceOf", instanceof expected at Studentfile.handleEvent(Studentfile.java:106) at java.awt.Window.postEvent(Window.java:2722) at java.awt.Component.dispatchEventImpl(Component.java:4876) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Window.dispatchEventImpl(Window.java:2713) at java.awt.Component.dispatchEvent(Component.java:4686) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:707) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:680) at java.awt.EventQueue$4.run(EventQueue.java:678) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:677) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:211) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:128) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:117) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:113) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:105) at java.awt.EventDispatchThread.run(EventDispatchThread.java:90) Exception in thread "AWT-EventQueue-0" java.lang.Error: Unresolved compilation problems: Event.get cannot be resolved Syntax error on token "instanceOf", instanceof expected at Studentfile.handleEvent(Studentfile.java:106) at java.awt.Window.postEvent(Window.java:2722) at java.awt.Component.postEvent(Component.java:5169) at java.awt.Component.dispatchEventImpl(Component.java:4876) at java.awt.Component.dispatchEvent(Component.java:4686) at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1908) at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:937) at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:611) at java.awt.Component.dispatchEventImpl(Component.java:4730) at java.awt.Component.dispatchEvent(Component.java:4686) at sun.awt.SunToolkit$4.run(SunToolkit.java:588) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:251) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:705) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:675) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:211) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:128) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:117) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:113) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:105) at java.awt.EventDispatchThread.run(EventDispatchThread.java:90) Exception in thread "AWT-EventQueue-0" java.lang.Error: Unresolved compilation problems: Event.get cannot be resolved Syntax error on token "instanceOf", instanceof expected at Studentfile.handleEvent(Studentfile.java:106) at java.awt.Window.postEvent(Window.java:2722) at java.awt.Component.postEvent(Component.java:5169) at java.awt.Component.dispatchEventImpl(Component.java:4876) at java.awt.Component.dispatchEvent(Component.java:4686) at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1908) at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:928) at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:560) at java.awt.Component.dispatchEventImpl(Component.java:4730) at java.awt.Component.dispatchEvent(Component.java:4686) at sun.awt.SunToolkit$4.run(SunToolkit.java:588) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:251) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:705) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:675) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:211) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:128) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:117) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:113) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:105) at java.awt.EventDispatchThread.run(EventDispatchThread.java:90) Exception in thread "AWT-EventQueue-0" java.lang.Error: Unresolved compilation problems: Event.get cannot be resolved Syntax error on token "instanceOf", instanceof expected at Studentfile.handleEvent(Studentfile.java:106) at java.awt.Window.postEvent(Window.java:2722) at java.awt.Component.postEvent(Component.java:5169) at java.awt.Component.dispatchEventImpl(Component.java:4876) at java.awt.Component.dispatchEvent(Component.java:4686) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:707) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:680) at java.awt.EventQueue$4.run(EventQueue.java:678) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:677) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:211) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:128) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:117) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:113) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:105) at java.awt.EventDispatchThread.run(EventDispatchThread.java:90) Exception in thread "AWT-EventQueue-0" java.lang.Error: Unresolved compilation problems: Event.get cannot be resolved Syntax error on token "instanceOf", instanceof expected at Studentfile.handleEvent(Studentfile.java:106) at java.awt.Window.postEvent(Window.java:2722) at java.awt.Component.postEvent(Component.java:5169) at java.awt.Component.dispatchEventImpl(Component.java:4876) at java.awt.Component.dispatchEvent(Component.java:4686) at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1908) at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:937) at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:611) at java.awt.Component.dispatchEventImpl(Component.java:4730) at java.awt.Component.dispatchEvent(Component.java:4686) at sun.awt.SunToolkit$4.run(SunToolkit.java:588) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:251) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:705) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:675) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:211) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:128) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:117) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:113) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:105) at java.awt.EventDispatchThread.run(EventDispatchThread.java:90) Exception in thread "AWT-EventQueue-0" java.lang.Error: Unresolved compilation problems: Event.get cannot be resolved Syntax error on token "instanceOf", instanceof expected at Studentfile.handleEvent(Studentfile.java:106) at java.awt.Window.postEvent(Window.java:2722) at java.awt.Component.postEvent(Component.java:5169) at java.awt.Component.dispatchEventImpl(Component.java:4876) at java.awt.Component.dispatchEvent(Component.java:4686) at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1908) at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:928) at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:560) at java.awt.Component.dispatchEventImpl(Component.java:4730) at java.awt.Component.dispatchEvent(Component.java:4686) at sun.awt.SunToolkit$4.run(SunToolkit.java:588) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:251) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:705) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:675) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:211) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:128) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:117) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:113) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:105) at java.awt.EventDispatchThread.run(EventDispatchThread.java:90) Exception in thread "AWT-EventQueue-0" java.lang.Error: Unresolved compilation problems: Event.get cannot be resolved Syntax error on token "instanceOf", instanceof expected at Studentfile.handleEvent(Studentfile.java:106) at java.awt.Window.postEvent(Window.java:2722) at java.awt.Component.postEvent(Component.java:5169) at java.awt.Component.dispatchEventImpl(Component.java:4876) at java.awt.Component.dispatchEvent(Component.java:4686) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:707) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:680) at java.awt.EventQueue$4.run(EventQueue.java:678) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:677) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:211) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:128) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:117) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:113) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:105) at java.awt.EventDispatchThread.run(EventDispatchThread.java:90) Exception in thread "AWT-EventQueue-0" java.lang.Error: Unresolved compilation problems: Event.get cannot be resolved Syntax error on token "instanceOf", instanceof expected at Studentfile.handleEvent(Studentfile.java:106) at java.awt.Window.postEvent(Window.java:2722) at java.awt.Component.dispatchEventImpl(Component.java:4876) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Window.dispatchEventImpl(Window.java:2713) at java.awt.Component.dispatchEvent(Component.java:4686) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:707) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:680) at java.awt.EventQueue$4.run(EventQueue.java:678) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:677) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:211) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:128) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:117) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:113) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:105) at java.awt.EventDispatchThread.run(EventDispatchThread.java:90) Exception in thread "AWT-EventQueue-0" java.lang.Error: Unresolved compilation problems: Event.get cannot be resolved Syntax error on token "instanceOf", instanceof expected at Studentfile.handleEvent(Studentfile.java:106) at java.awt.Window.postEvent(Window.java:2722) at java.awt.Component.dispatchEventImpl(Component.java:4876) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Window.dispatchEventImpl(Window.java:2713) at java.awt.Component.dispatchEvent(Component.java:4686) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:707) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:680) at java.awt.EventQueue$4.run(EventQueue.java:678) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:677) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:211) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:128) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:117) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:113) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:105) at java.awt.EventDispatchThread.run(EventDispatchThread.java:90) Exception in thread "AWT-EventQueue-0" java.lang.Error: Unresolved compilation problems: Event.get cannot be resolved Syntax error on token "instanceOf", instanceof expected at Studentfile.handleEvent(Studentfile.java:106) at java.awt.Window.postEvent(Window.java:2722) at java.awt.Component.dispatchEventImpl(Component.java:4876) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Window.dispatchEventImpl(Window.java:2713) at java.awt.Component.dispatchEvent(Component.java:4686) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:707) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:680) at java.awt.EventQueue$4.run(EventQueue.java:678) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:677) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:211) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:128) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:117) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:113) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:105) at java.awt.EventDispatchThread.run(EventDispatchThread.java:90) Exception in thread "AWT-EventQueue-0" java.lang.Error: Unresolved compilation problems: Event.get cannot be resolved Syntax error on token "instanceOf", instanceof expected at Studentfile.handleEvent(Studentfile.java:106) at java.awt.Window.postEvent(Window.java:2722) at java.awt.Component.dispatchEventImpl(Component.java:4876) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Window.dispatchEventImpl(Window.java:2713) at java.awt.Component.dispatchEvent(Component.java:4686) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:707) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:680) at java.awt.EventQueue$4.run(EventQueue.java:678) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:677) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:211) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:128) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:117) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:113) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:105) at java.awt.EventDispatchThread.run(EventDispatchThread.java:90) Exception in thread "AWT-EventQueue-0" java.lang.Error: Unresolved compilation problems: Event.get cannot be resolved Syntax error on token "instanceOf", instanceof expected at Studentfile.handleEvent(Studentfile.java:106) at java.awt.Window.postEvent(Window.java:2722) at java.awt.Component.dispatchEventImpl(Component.java:4876) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Window.dispatchEventImpl(Window.java:2713) at java.awt.Component.dispatchEvent(Component.java:4686) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:707) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:680) at java.awt.EventQueue$4.run(EventQueue.java:678) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:677) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:211) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:128) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:117) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:113) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:105) at java.awt.EventDispatchThread.run(EventDispatchThread.java:90) Exception in thread "AWT-EventQueue-0" java.lang.Error: Unresolved compilation problems: Event.get cannot be resolved Syntax error on token "instanceOf", instanceof expected at Studentfile.handleEvent(Studentfile.java:106) at java.awt.Window.postEvent(Window.java:2722) at java.awt.Component.postEvent(Component.java:5169) at java.awt.Component.dispatchEventImpl(Component.java:4876) at java.awt.Component.dispatchEvent(Component.java:4686) at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1908) at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:937) at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:611) at java.awt.Component.dispatchEventImpl(Component.java:4730) at java.awt.Component.dispatchEvent(Component.java:4686) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:707) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:680) at java.awt.EventQueue$4.run(EventQueue.java:678) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:677) at java.awt.SentEvent.dispatch(SentEvent.java:70) at java.awt.DefaultKeyboardFocusManager$DefaultKeyboardFocusManagerSentEvent.dispatch(DefaultKeyboardFocusManager.java:206) at java.awt.DefaultKeyboardFocusManager.sendMessage(DefaultKeyboardFocusManager.java:233) at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:677) at java.awt.Component.dispatchEventImpl(Component.java:4730) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Window.dispatchEventImpl(Window.java:2713) at java.awt.Component.dispatchEvent(Component.java:4686) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:707) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:680) at java.awt.EventQueue$4.run(EventQueue.java:678) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:677) at java.awt.SequencedEvent.dispatch(SequencedEvent.java:116) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:705) at java.awt.EventQueue.access$000(EventQueue.java:101) at java.awt.EventQueue$3.run(EventQueue.java:666) at java.awt.EventQueue$3.run(EventQueue.java:664) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:680) at java.awt.EventQueue$4.run(EventQueue.java:678) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:677) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:211) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:128) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:117) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:113) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:105) at java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
import java.io.*;
import java.awt.*;
public class Studentfile extends Frame
TextField number, name,marks;
Button enter,done;
Label numLabel, nameLabel,markLabel;
DataOutputStream dos;
public Studentfile()
super("Create Student File");
public void setup()
resize(400,200);
setLayout(new GridLayout(4,2));
number=new TextField(25);
numLabel=new Label("Roll Number");
name=new TextField(25);
nameLabel=new Label("Student name");
marks=new TextField(25);
markLabel=new Label("Marks");
enter=new Button("ENTER");
done=new Button("DONE");
add(numLabel);
add(number);
add(nameLabel);
add(name);
add(markLabel);
add(marks);
add(enter);
add(done);
show();
try
dos=new DataOutputStream(new FileOutputStream("Student.dat"));
catch(IOException e)
System.err.println(e.toString());
System.exit(1);
public void addRecord()
int num;
Double d;
num=(new Integer(number.getText())).intValue();
try
dos.writeInt(num);
dos.writeUTF(name.getText());
d=new Double(marks.getText());
dos.writeDouble(d.doubleValue());
number.setText("");
name.setText("");
marks.setText("");
public void cleanup()
if(!number.getText().equals(""))
addRecord();
try
dos.flush();
dos.close();
public boolean action(Event event,Object o)
if(Event.get instanceOf Button)
if(event.arg.equals("Enter"))
addRecord();
return true;
return super.action(event, o);
public boolean handleEvent(Event event)
if(event.arg.equals("DONE"))
cleanup();
System.exit(0);
return true;
return super.handleEvent(event);
public static void main(String[]args)
Studentfile student=new Studentfile();
student.setup();
ModérateurIl faut le lire le message d'erreur ! Et pas besoin d'aller à la ligne 45, la ligne 2 suffit.
Il faut remplacer tous tes "instanceOf" par "instanceof" car c'est ça la bonne syntaxe. -
if(event instanceof Button)
je l'ai déjà essayé mais pb reste toujours -
Modérateurevent est un Event, ça ne peut pas être un Button, il faut tester event.target
if(event.target instanceof Button)
Mais après tu dois faire attention parce que event.arg pouvant valoir null on ne peut pas toujours utiliser equals :
if(event.arg!=null && event.arg.equals("DONE")) -
ok ça marche merci beaucoup
