Problème avec Minecraft
Bonjour je ne suis pas très qualifié en informatique, mais pourriez-vous m'aider à enlever ce message quand je veux aller sur Minecraft ?
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 10/02/13 20:10
-- System Details --
Details:
Minecraft Version: 1.4.7
Operating System: Windows XP (x86) version 5.1
Java Version: 1.7.0_13, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 453456488 bytes (432 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
JVM Flags: 2 total; -Xms512m -Xmx1024m
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: ~~ERROR~~ NullPointerException: null
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: Default
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:232)
at asq.a(SourceFile:56)
at net.minecraft.client.Minecraft.run(SourceFile:515)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT e01b0c48 ----------
J'éspère avoir de l'aide au plus vite ! (De l'aide utile)
8 réponses
    https://www.commentcamarche.net/faq/9265-identifier-son-materiel-avec-aida64
    Copie-colle le résumé généré par AIDA64 dans ton prochain message.
      Tout est expliqué dans le tutoriel.
      Avec le résumé, je pourrais te proposer un pilote pour ta carte graphique.
      1. --------[ AIDA64 Extreme Edition ]--------------------------------------------------------------------------------------
        Version AIDA64 v2.80.2300/fr
        Module de test 3.0.492-x32
        Site web http://www.aida64.com/
        Type de rapport Rapport rapide [ TRIAL VERSION ]
        Ordinateur A6-9736E67B8B2D
        Générateur Romain
        Système d'exploitation Microsoft Windows XP Professional 5.1.2600 (WinXP RTM)
        Date 2013-02-10
        Heure 20:24
        --------[ Résumé ]------------------------------------------------------------------------------------------------------
        Ordinateur:
        Type de système PC multiprocesseur ACPI
        Service Pack du système [ TRIAL VERSION ]
        Internet Explorer 8.0.6001.18702 (IE 8.0)
        DirectX 4.09.00.0904 (DirectX 9.0c)
        Nom du système A6-9736E67B8B2D
        Nom de l'utilisateur Romain
        Domaine de connexion [ TRIAL VERSION ]
        Date / Heure 2013-02-10 / 20:24
        Carte mère:
        Type de processeur Intel Pentium 4, 3000 MHz (15 x 200)
        Nom de la carte mère IBM ThinkCentre A50
        Chipset de la carte mère Intel Springdale-G i865G
        Mémoire système [ TRIAL VERSION ]
        DIMM1: Samsung M3 68L6423FTN-CCC 512 Mo PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
        DIMM2: Samsung M3 68L6423FTN-CCC [ TRIAL VERSION ]
        Type de Bios Phoenix (10/26/04)
        Port de communication Port de communication (COM1)
        Port de communication Port imprimante ECP (LPT1)
        Moniteur:
        Carte vidéo ATI Radeon 9250 (RV280)
        Accélérateur 3D ATI Radeon 9250 (RV280)
        Multimédia:
        Carte audio Analog Devices 1981B(L) @ Intel 82801EB ICH5 - AC'97 Audio Controller [A-2/A-3]
        Stockage:
        Contrôleur IDE Intel(R) 82801EB Ultra ATA Storage Controllers
        Lecteur de disquettes Lecteur de disquettes
        Disque dur Hitachi HDS721616PLA380 (160 Go, 7200 RPM, SATA-II)
        Disque dur SAMSUNG SP0411N (40 Go, 7200 RPM, Ultra-ATA/133)
        Lecteur optique SAMSUNG DVD-ROM SD-616E (16x/48x DVD-ROM)
        État des disques durs SMART OK
        Partitions:
        C: (NTFS) [ TRIAL VERSION ]
        D: (NTFS) 148.9 Go (138.5 Go libre)
        Taille totale [ TRIAL VERSION ]
        Entrée:
        Clavier Clavier standard 101/102 touches ou clavier Microsoft Natural Keyboard PS/2
        Clavier Périphérique clavier PIH
        Souris Souris HID
        Réseau:
        Adresse IP principale [ TRIAL VERSION ]
        Adresse MAC principale 00-11-25-4E-26-D1
        Carte réseau Hamachi Network Interface (25.1 [ TRIAL VERSION ])
        Carte réseau Intel(R) PRO/100 VE Network Connection (192. [ TRIAL VERSION ])
        Modem Modem standard 9600 bps
        Périphériques:
        Imprimante Microsoft XPS Document Writer
        Contrôleur USB1 Intel 82801EB ICH5 - USB Controller [A-2/A-3]
        Contrôleur USB2 Intel 82801EB ICH5 - Enhanced USB2 Controller [A-2/A-3]
        Périphérique USB Périphérique d'interface utilisateur USB
        Périphérique USB Périphérique USB composite
        DMI:
        Distributeur du Bios IBM
        Version du Bios 2CKT20AFR
        Fabricant du système IBM
        Nom du système 808578G
        Version du système ThinkCentre A50
        N° de série du système [ TRIAL VERSION ]
        UUID du système [ TRIAL VERSION ]
        Fabricant de la carte mère Intel
        Nom de la carte mère D865GKD
        Version de la carte mère
        N° de série de la carte mère [ TRIAL VERSION ]
        Fabricant du châssis IBM
        Version du châssis
        N° de série du châssis [ TRIAL VERSION ]
        Identifiant du châssis [ TRIAL VERSION ]
        Type du châssis Mini Tower
        1. Voilà tiens
        2. J'éspère que tu vas me répondre au plus vite possible, merci.
      2. Modérateur
        "ATI Radeon 9250"
        --> Installe ce pilote :
        http://www2.ati.com/drivers/6-11-pre-r300_xp-2k_dd_ccc_wdm_38185.exe
          ---> Télécharge et installe 7-Zip :
          https://www.commentcamarche.net/telecharger/utilitaires/2197-7-zip/
          ---> Clique droit sur le fichier "6-11-pre-r300_xp-2k_dd_ccc_wdm_38185", choisis "7-Zip" puis "Extraire vers "6-11-pre-r300_xp-2k_dd_ccc_wdm_38185/". Tu obtiens un dossier nommé "6-11-pre-r300_xp-2k_dd_ccc_wdm_38185".
          --> Va dedans, exécute le fichier Setup.exe pour lancer l'installation.
