Help minecraft
Bonjour, j'ai décidé de me lancer dans Minecraft, mais j'ai eu un problème ( rencontré par beaucoup ), celui du " bad video card drivers ... "
Voilà ma " config' " :
System Information
Time of this report: 10/9/2012, 19:17:13
Machine name: FRANKCLAES-PC
Operating System: Windows 7 Édition Intégrale 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110622-1506)
Language: French (Regional Setting: French)
System Manufacturer: INTEL
System Model: DG43NB
BIOS: BIOS Date: 08/15/08 15:04:09 Ver: 08.00.10
Processor: Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz (4 CPUs), ~2.3GHz
Memory: 2048MB RAM
Available OS Memory: 2028MB RAM
Page File: 1171MB used, 2885MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 8800 GTS (Microsoft Corporation - WDDM v1.1)
Manufacturer: NVIDIA
Chip type: GeForce 8800 GTS
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0193&SUBSYS_042010DE&REV_A2
Display Memory: 1055 MB
Dedicated Memory: 297 MB
Shared Memory: 758 MB
Current Mode: 1440 x 900 (32 bit) (60Hz)
Monitor Name: Algemeen PnP-beeldscherm
Monitor Model: Acer AL1916W
Monitor Id: ACRAD52
Native Mode: 1440 x 900(p) (59.887Hz)
Output Type: HD15
Driver Name: nvd3dumx.dll,nvd3dum,nvwgf2umx.dll, nvwgf2um
Driver File Version: 8.15.0011.8593 (English)
Driver Version: 8.15.11.8593
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 7/14/2009 03:41:53, 9443840 bytes
WHQL Logo'd: Yes
Merci d'avance pour votre aide..
System Information
Memory: 2048MB RAM
DxDiag Notes
Display Devices
Monitor Id: ACRAD52
Output Type: HD15
DDI Version: 10
WHQL Logo'd: Yes
bonjour,
tu devrais réinstaller les pilotes pour ta carte graphique.
"Driver Date/Size: 7/14/2009" ceux ci on l'air obsolete.
-telecharge les dernier pilotes pour ta 8800 GTS
-desinstalle tes pilotes
-installe les derniers pilotes que t a téléchargé chez nvidia-
Ok donc je vais là : https://www.nvidia.fr/Download/index.aspx?lang=fr
Puis je fais la recherche auto, puis je télécharge.
Puis j'ai pas compris avec " désinstalle tes pilotes " -
Ah ok j'ai fait la recherche auto puis ils me mettent : " Produit Pilote actuellement installé Dernière mise à jour du pilote
GeForce 8800 GTS -- GeForce 306.23 Driver
Version: 306.23 WHQL
Date d'introduction: 13.9.2012 "
A lire dans l'ordre, donc ils disent " Pilote actuellement installé : -- " Ok xD Y a aucun pilote installé ^^ -
desinstalle tes pilotes :
tu va dans ton panneau de config "desinstaller prog"
tu cherche nvidia puis desinstaller, cherche pas a enlever que les drivers graphique vire tout le nouveau pilote va tout te remmettre après. -
Modérateur
Ca marche pas Destrio ça me (re)met ça :( :
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 9/10/12 19:47
- Minecraft Version: 1.3.2
- Operating System: Windows 7 (x86) version 6.1
- Java Version: 1.7.0_07, Oracle Corporation
- Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
- Memory: 428189640 bytes (408 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
- JVM Flags: 2 total; -Xms512m -Xmx1024m
- LWJGL: 2.4.2
- OpenGL: ~ERROR~ NullPointerException: null
- Is Modded: Probably not
- Type: Client
- Texture Pack: ~ERROR~ NullPointerException: null
- Profiler Position: N/A (disabled)[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:233)
at net.minecraft.client.Minecraft.run(SourceFile:516)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT 1b568541 ---------- -
ModérateurTélécharge et installe ce pilote :
https://www.nvidia.fr/Download/driverResults.aspx/48836/fr
