Include un gros problème
Moi aussi j ai un probleme ac include:
Warning: include(include/mysql_connect.php) [function.include]: failed to open stream: No such file or directory in C:\wamp\www\index.php on line 4
Warning: include() [function.include]: Failed opening 'include/mysql_connect.php' for inclusion (include_path='.;C:\php5\pear') in C:\wamp\www\index.php on line 4
Warning: mysql_query() [function.mysql-query]: Access denied for user 'SYSTEM'@'localhost' (using password: NO) in C:\wamp\www\index.php on line 10
Warning: mysql_query() [function.mysql-query]: A link to the server could not be established in C:\wamp\www\index.php on line 10
Warning: mysql_fetch_array() expects parameter 1 to be resource, boolean given in C:\wamp\www\index.php on line 16
Ajouter un dvd
Warning: mysql_query() [function.mysql-query]: Access denied for user 'SYSTEM'@'localhost' (using password: NO) in C:\wamp\www\index.php on line 39
Warning: mysql_query() [function.mysql-query]: A link to the server could not be established in C:\wamp\www\index.php on line 39
Warning: mysql_fetch_array() expects parameter 1 to be resource, boolean given in C:\wamp\www\index.php on line 45
Ajouter un genre
Warning: mysql_query() [function.mysql-query]: Access denied for user 'SYSTEM'@'localhost' (using password: NO) in C:\wamp\www\index.php on line 65
Warning: mysql_query() [function.mysql-query]: A link to the server could not be established in C:\wamp\www\index.php on line 65
Warning: mysql_fetch_array() expects parameter 1 to be resource, boolean given in C:\wamp\www\index.php on line 71
Ajouter un realisateur
Warning: mysql_close(): no MySQL-Link resource supplied in C:\wamp\www\index.php on line 85
Et voilà mon code index .php:
<?php
//inclusion du fichier de connexion à la base de données
include("include/mysql_connect.php");
//préparation de la requête sql que l'on stocke dans une variable $query
$query = "SELECT * FROM dvd JOIN genre ON dvd.genre = genre.id JOIN realisateur ON dvd.realisateur = realisateur.id" ;
//requête auprès de la db, le résultat est stocké dans une variable $sql
$sql = mysql_query($query);
<table border="10"><!-- ouvre le tableau -->
<?php
//résultat dans variable tableau $rec et boucle pour lire ligne par ligne.
while ($rec = mysql_fetch_array($sql)){
<tr> <!-- nouvelle ligne -->
<td><?php echo $rec["titre"]; // affiche la date ?></td> <!-- nouvelle cellule -->
<td><?php echo $rec["genre"]; //affiche titre news ?></td> <!-- nouvelle cellule -->
<td><?php echo $rec["realisateur"]; // affiche la date ?></td> <!-- nouvelle cellule -->
<td><?php echo $rec["pret"]; // affiche la date ?></td> <!-- nouvelle cellule -->
<td><a href="dvd_del.php?id=<?php echo $rec["id"]; ?>">Supprimer</a></td> <!-- nouvelle cellule, lien activé plus tard -->
</tr> <!-- fin de ligne -->
<?php
} // fin de boucle
<a href="dvd_add.php">Ajouter un dvd</a>
<?php
$query = "SELECT * FROM genre" ;
<?php
<td><a href="genre_del.php?id=<?php echo $rec["id"]; ?>">Supprimer</a></td> <!-- nouvelle cellule, lien activé plus tard -->
<?php
} // fin de boucle
<a href="genre_add.php">Ajouter un genre</a>
<?php
$query = "SELECT * FROM realisateur" ;
<?php
<td><?php echo $rec["pays"]; // affiche la date ?></td> <!-- nouvelle cellule -->
<td><a href="realisateur_del.php?id=<?php echo $rec["id"]; ?>">Supprimer</a></td> <!-- nouvelle cellule, lien activé plus tard -->
<?php
} // fin de boucle
<a href="realisateur_add.php">Ajouter un realisateur</a>
<?php
//déconnexion de la base de données
mysql_close();
  1. Est-tu sûr d'avoir un fichier nommé "mysql_connect.php" dans un dossier appelé "include" à la racine de ton site ?
