Search settings meme probleme que Altif
Bonjour, j'ai le meme probleme que Altif et voila le rapport généré TB.txt :
-----------\\ ToolBar S&D 1.2.8 XP/Vista
Microsoft Windows XP Édition familiale ( v5.1.2600 ) Service Pack 3
X86-based PC ( Multiprocessor Free : Intel(R) Core(TM)2 CPU T5500 @ 1.66GHz )
BIOS : Phoenix ROM BIOS PLUS Version 1.10 A05
USER : baouche rafik ( Administrator )
BOOT : Normal boot
Antivirus : Kaspersky Anti-Virus 6.0.3.837 (Activated)
Firewall : Kaspersky Anti-Virus 6.0.3.837 (Activated)
C:\ (Local Disk) - NTFS - Total:69 Go (Free:15 Go)
D:\ (CD or DVD)
F:\ (Local Disk) - FAT32 - Total:232 Go (Free:55 Go)
"C:\ToolBar SD" ( MAJ : 21-12-2008|20:47 )
Option : [1] ( 03/06/2009|15:14 )
-----------\\ Recherche de Fichiers / Dossiers ...
C:\Program Files\AskSBar
C:\Program Files\AskSBar\bar
C:\Program Files\AskSBar\bar\1.bin
C:\Program Files\AskSBar\bar\Cache
C:\Program Files\AskSBar\bar\History
C:\Program Files\AskSBar\bar\Settings
C:\Program Files\AskSBar\bar\1.bin\A2FFXTBR.JAR
C:\Program Files\AskSBar\bar\1.bin\A2FFXTBR.MANIFEST
C:\Program Files\AskSBar\bar\1.bin\A2HIGHIN.EXE
C:\Program Files\AskSBar\bar\1.bin\A2NTSTBR.JAR
C:\Program Files\AskSBar\bar\1.bin\A2NTSTBR.MANIFEST
C:\Program Files\AskSBar\bar\1.bin\A2PLUGIN.DLL
C:\Program Files\AskSBar\bar\1.bin\NPASKSBR.DLL
C:\Program Files\AskSBar\bar\Cache\0003544B
C:\Program Files\AskSBar\bar\Cache\0057292B
C:\Program Files\AskSBar\bar\Cache\02603D88
C:\Program Files\AskSBar\bar\Cache\026066FA.bin
C:\Program Files\AskSBar\bar\Cache\02608158.bin
C:\Program Files\AskSBar\bar\Cache\0260927E.bin
C:\Program Files\AskSBar\bar\Cache\files.ini
C:\Program Files\AskSBar\bar\History\search2
C:\Program Files\AskSBar\bar\Settings\prevcfg2.htm
C:\DOCUME~1\BAOUCH~1\Cookies\baouche_rafik@dnl.crawler[2].txt
C:\DOCUME~1\BAOUCH~1\APPLIC~1\Dealio
C:\DOCUME~1\BAOUCH~1\APPLIC~1\Dealio\res
C:\DOCUME~1\BAOUCH~1\APPLIC~1\Dealio\temp
C:\DOCUME~1\BAOUCH~1\APPLIC~1\Dealio\res\widgets.xml
C:\DOCUME~1\BAOUCH~1\APPLIC~1\Dealio\temp\http___www_dealio_com_rss_coupons-deals_dotd_.xml
C:\WINDOWS\Prefetch\SEARCHSETTINGS.EXE-30EFBC20.pf
C:\DOCUME~1\BAOUCH~1\APPLIC~1\Search Settings
C:\DOCUME~1\BAOUCH~1\APPLIC~1\Search Settings\kb128
C:\DOCUME~1\BAOUCH~1\APPLIC~1\Search Settings\kb128\temp
C:\DOCUME~1\BAOUCH~1\APPLIC~1\Search Settings\kb128\temp\ws-14395.log
C:\DOCUME~1\BAOUCH~1\APPLIC~1\Search Settings\kb128\temp\ws-14396.log
C:\DOCUME~1\BAOUCH~1\APPLIC~1\Search Settings\kb128\temp\ws-14397.log
C:\DOCUME~1\BAOUCH~1\APPLIC~1\Search Settings\kb128\temp\ws-14398.log
C:\Program Files\Search Settings
C:\Program Files\Search Settings\kb128
C:\Program Files\Search Settings\SearchSettings.exe
C:\Program Files\Search Settings\kb128\SearchSettings.dll
C:\Program Files\Search Settings\kb128\SearchSettingsRes409.dll
Merci pour votre aide
BOOT : Normal boot
D:\ (CD or DVD)
Contributeur sécuritéslt
le rapport est incomplet! mets en un complet SVP ou en deux fois -
voila le rapport complet est là et MERCIIIIIIIIIIIIIIII beaucoup :
BOOT : Normal boot
D:\ (CD or DVD)
-----------\\ [..\Internet Explorer\Main]
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main]
"Local Page"="C:\\WINDOWS\\system32\\blank.htm"
"Start Page"="https://fr.yahoo.com/"
"Search Bar"="http://www.crawler.com/search/dispatcher.aspx?tp=aus&qkw=%s&tbid=60446"
[HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Main]
"Default_Page_URL"="https://www.msn.com/fr-fr/?ocid=iehp"
"Default_Search_URL"="https://www.bing.com/?toHttps=1&redig=5FC791212101479BAFBE1A679848B1AF"
"Start Page"="https://www.msn.com/fr-fr/?ocid=iehp"
"SearchAssistant"="http://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch"
"CustomizeSearch"="http://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch"
"Home_Page"="https://www.dell.com/fr-fr?c=fr&l=fr&s=gen&redirect=1"
"Help_Page"="http://support.euro.dell.com/segment.asp?country=FR&language=FR"
--------------------\\ Recherche d'autres infections
C:\WINDOWS\Pack.epk
[b]==> EGDACCESS <==/b
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\Tcpip\Parameters]
NameServer REG_SZ 85.255.115.61,85.255.112.97
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\Tcpip\Parameters]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\..\{78551670-04C0-4819-A32C-2DF685E39483}]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\..\{78551670-04C0-4819-A32C-2DF685E39483}]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\..\{78551670-04C0-4819-A32C-2DF685E39483}]
[b]==> WAREOUT <==/b
--------------------\\ Cracks & Keygens ..
C:\DOCUME~1\BAOUCH~1\Bureau\NeuraLog.v2008.05-NULL\Crack
C:\DOCUME~1\BAOUCH~1\Bureau\NeuraLog.v2008.05-NULL\Crack\NDSLOG.EXE
C:\DOCUME~1\BAOUCH~1\Cookies\baouche_rafik@crackdb[1].txt
C:\DOCUME~1\BAOUCH~1\Cookies\baouche_rafik@www.dongle-crack-download[2].txt
C:\DOCUME~1\BAOUCH~1\Local Settings\Temporary Internet Files\Content.IE5\0K7EYZPV\tank_2.5_with_crack[1].htm
C:\DOCUME~1\BAOUCH~1\Recent\crack.lnk
C:\DOCUME~1\BAOUCH~1\Recent\keygen.lnk
1 - "C:\ToolBar SD\TB_1.txt" - 03/06/2009|15:17 - Option : [1]
-----------\\ Fin du rapport a 15:17:31,95 -
Contributeur sécuritécela fait mal un rapport comme celui la!
tu n'as pas que cela dans ton ordi!!!!!!
fais l'option 2 de toolbar sd
puis
scan avec malwarebyte , fais un scan rapide et colle le rapport obtenu et vire ce qui est trouvé:
https://www.malekal.com/tutoriel-malwarebyte-anti-malware/
______________________
télécharger sur le bureau
Navilog.zip (IL MAFIOSO)
http://perso.orange.fr/il.mafioso/Navifix/Navilog1.exe
= Double-Clic navilog1.zip
= Extraire tout sur le bureau
= Double-Clic navilog1 qui est sur le bureau
= Appuyer sur une touche jusqu' arriver aux options
= Choisir option 1
un rapport : fixnavi.txt dans C : va se creer
le copier/coller dans ton prochain message.
