Problème de requête SQL
je ne vois pas l'erreur:
$message =  mysql_real_escape_string(htmlspecialchars($_POST['message']));
			mysql_query("UPADTE topic1 SET message = '" . $message . "' WHERE id='" . $id . "'") or die(mysql_error());
Configuration: Windows Vista
Firefox 3.0.5
  1. erreur :
    You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'UPADTE topic1 SET message = ' Ca vt dire koi floooooood ?! :)' WHERE id='104' at line 1
      salut!
      			mysql_query("UPADTE topic1 SET message = '" . $message . "' WHERE id='$id' ") or die(mysql_error());
      Peut être,je ne suis pas si sur!
