Aide pour validation W3C
Bonjour, j'essaye de valider mon site mais il me met 4 erreurs:
1. Error Line 3, Column 7: required attribute "TYPE" not specified.
<script><endnote><head>
The attribute given above is required for an element that you've used, but you have omitted it. For instance, in most HTML and XHTML document types the "type" attribute is required on the "script" element and the "alt" attribute is required for the "img" element.
Typical values for type are type="text/css" for <style> and type="text/javascript" for <script>.
2. Error Line 21, Column 115: there is no attribute "ALIGN".
…alt="" src="warning-large.png" align="middle"> <span style="color: white
You have used the attribute named above in your document, but the document type you are using does not support that attribute for this element. This error is often caused by incorrect use of the "Strict" document type with a document that uses frames (e.g. you must use the "Transitional" document type to get the "target" attribute), or by using vendor proprietary extensions such as "marginheight" (this is usually fixed by using CSS to achieve the desired effect instead).
This error may also result if the element itself is not supported in the document type you are using, as an undefined element will have no supported attributes; in this case, see the element-undefined error message for further information.
How to fix: check the spelling and case of the element and attribute, (Remember XHTML is all lower-case) and/or check that they are both allowed in the chosen document type, and/or use CSS instead of this attribute. If you received this error when using the <embed> element to incorporate flash media in a Web page, see the FAQ item on valid flash.
3. Error Line 29, Column 3: document type does not allow element "BR" here; missing one of "P", "H1", "H2", "H3", "H4", "H5", "H6", "PRE", "DIV", "ADDRESS" start-tag.
<br>
The mentioned element is not allowed to appear in the context in which you've placed it; the other mentioned elements are the only ones that are both allowed there and can contain the element mentioned. This might mean that you need a containing element, or possibly that you've forgotten to close a previous element.
One possible cause for this message is that you have attempted to put a block-level element (such as "<p>" or "<table>") inside an inline element (such as "<a>", "<span>", or "<font>").
4. Error Line 96, Column 3: document type does not allow element "BR" here; missing one of "P", "H1", "H2", "H3", "H4", "H5", "H6", "PRE", "DIV", "ADDRESS" start-tag.
<br>
S'il vous plaît aidez-moi !!!
<br>
<br>
Configuration: Windows XP Firefox 3.0.6
Contributeursalut,
1/ il faut ajouter l'attribut par exemple :<script type="text/javascript">
2/ il faut virer çaalign="middle"
3/ et 4/ il faut connaitre le contexte donne nous le bout de code (5 lignes avant, 5 lignes après).
Contributeur@| ^ - ^ |bienvenue chez XHTML, il faut le faire en CSS !
@DalidaMerci KompoZer ^^
Contributeur
Bref, si tu peux m'aider et tans pis si tu veux pas je comprendrais très bien:
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<script></script>
<meta content="text/html; charset=ISO-8859-1"
http-equiv="content-type">
<title>Accueil</title>
<link rel="stylesheet" media="screen" type="text/css"
title="Design" href="design.css">
</head>
<body>
var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");
document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E"));
</script>
try {
var pageTracker = _gat._getTracker("UA-7306569-1");
pageTracker._trackPageview();
} catch(err) {}</script>
<div style="text-align: center;"><big><img
style="width: 48px; height: 48px;" alt=""
src="warning-large.png"> <span
style="color: white;">Vous
devez naviguez obligatoirement avec Firefox sur ce site. Si vous ne le
possédez pas encore, téléchargez-le:</span> <a
href="Firefox%20Setup%203.0.6.zip"><img
style="border: 0px solid ; width: 110px; height: 32px;" alt=""
src="get_firefox.png" align="middle"></a><br>
<img style="width: 48px; height: 51px;" alt=""
src="info.gif" align="middle"><span
style="color: white;">Pour profiter
pleinement de ce site, vous êtes invités à cliquer sur la petite croix
un peu plus haut (</span><img
style="width: 15px; height: 16px; color: white;" alt=""
src="close.PNG"><span style="color: white;">)pour
fermer la publicité.</span><br style="font-family: Papyrus;">
</big></div>
<br>
<div style="text-align: center;"><big><big
style="font-family: Papyrus;"><big><span
style="font-weight: bold;"><img
style="width: 797px; height: 57px;" alt=""
src="Title.PNG" align="middle"></span></big></big></big><br>
</div>
<table style="text-align: left; width: 1216px; height: 348px;"
border="1" cellpadding="2" cellspacing="2">
<tbody>
<tr>
<td style="width: 548px; text-align: left; color: white;"><img
style="width: 24px; height: 24px;" alt=""
src="Cooliris/cooliris_icon.png" align="middle">
Cooliris 1.9.1 - Visualisez des milliers d'images sur un mur en 3D. -
<a href="Cooliris/cooliris.html">Plus de détails</a></td>
<td style="width: 665px; text-align: left; color: white;"><img
style="height: 34px; width: 38px;" alt=""
src="Download%20Statusbar/downloadstatusbar_icon.PNG"
align="middle"> Download Statusbar 0.9.6.3 - Gérez
vos téléchargements depuis une barre
d'état. - Plus de détails</td>
</tr>
<tr>
style="width: 32px; height: 32px;" alt=""
src="FireFTP/fireftp_icon.png" align="middle">
FireFTP 1.0.3 - Transférez vos fichiers en FTP en toute simplicité -
src="Flagfox/flagfox_icon.png" align="middle">
Flagfox 3.3.7 - Affichez des informations détaillées des sites internet
que vous visitez. - Plus de détails</td>
</tr>
<tr>
src="ImageTweak/imagetweak_icon.png" align="middle">
ImageTweak 0.17.1 - Améliore le visionnage d'images directes - Plus de
détails</td>
style="width: 28px; height: 32px;" alt=""
src="PDF%20Download/pdfdownload_icon.png" align="middle">
PDF Download 2.1.0.1 - Visualise les fichiers PDF rapidement sans Adobe
Reader - Plus de détails</td>
</tr>
<tr>
src="Sage/sage_icon.png" align="middle"> Sage 1.4.2 -
Un léger lecteur de flux RSS et de flux ATOM - Plus de détails</td>
src="WebMail%20Notifier/webmailnotifier_icon.png" align="middle">
WebMail Notifier 1.1.7 - Vous informe si vous avez reçu des mails
(paramétrable) - Plus de détails</td>
</tr>
<tr>
src="TimeTracker/timetracker_icon.png" align="middle">TimeTracker
1.2.4 - Compte le temps que vous passez sur Internet - Plus de détails</td>
src="Speed%20Dial/speeddial_icon.png" align="middle">
Speed Dial 0.7.2.11 - Donne un accès direct à vos pages Web
favorites - Plus de détails</td>
</tr>
<tr>
<td style="width: 548px; color: white;"><span
style="font-size: 10pt; font-family: "Verdana","sans-serif";"
lang="EN-US"><img style="width: 32px; height: 32px;"
alt=""
src="Google%20Toolbar%20for%20Firefox/googletoolbar_icon.png"
align="middle"> Google Toolbar for Firefox 3.1.20081010W -
Barre Google - Plus de détails<br>
</span><span
lang="EN-US"></span></td>
<td style="width: 665px; color: white;"><img
src="Forecastfox%20%20l10n/forecastfox_icon.png" align="middle">
Forecastfox l10n 0.7.2008093001 - Affiche les prévisions météo du monde
entier - Plus de détails<br>
</td>
</tr>
<tr>
<td style="color: white;"><img
style="width: 32px; height: 30px;" alt=""
src="Screengrab%21/screengrab_icon.png" align="middle">
Screengrab! 0.95 - Enregistre les pages Web - Plus de détails</td>
src="Interclue/interclue_icon.png" align="middle">
Interclue 1.5.8.1 - Affiche un aperçu de la page où va diriger un lien
</tr>
<tr align="center">
<td colspan="2" rowspan="1"><span
lang="EN-US"><img style="width: 37px; height: 34px;"
alt=""
src="RealPlayer%20Browser%20Record%20Plugin/realplayer_icon.PNG"
align="middle"> <span style="color: white;">RealPlayer
Browser Record Plugin 1.0</span></span><span
style="font-size: 10pt; font-family: "Verdana","sans-serif"; color: white;"
lang="EN-US"> - Détecte et télécharge du contenu de
n'importe quel site (Vous devez installer RealPlayer pour l'avoir) -
Plus de détails</span></td>
</tr>
</tbody>
</table>
<br>
<div style="text-align: center;"><a
title="Document made with KompoZer" href="http://kompozer.net/"><img
style="border: 0px solid ; width: 80px; height: 15px;"
alt="Document made with KompoZer"
src="http://kompozer.sourceforge.net/images/kompozer_80x15.png"
align="middle"></a> <a
href="http://www.mozilla-europe.org/fr/firefox/"><img
style="border: 0px solid ; width: 80px; height: 15px;" alt=""
src="ff3.gif" align="middle"></a> <a
href="http://www.photofiltre-studio.com/download.htm"><img
src="photofiltre_icon.png" align="middle"></a> <a
href="https://notepad-plus-plus.org/"><img
src="notepad.png" align="middle"></a> <a
href="http://jigsaw.w3.org/css-validator/#validate_by_uri"><img
src="css.gif" align="middle"></a> <a
href="http://validator.w3.org/feed/#validate_by_uri"><img
src="rssvalid.gif" align="middle"></a> <a
href="http://validator.w3.org/#validate_by_uri"><img
src="html401.gif" align="middle"></a> <a
href="http://standblog.org/blog/post/2008/04/19/10-raisons-de-choisir-Firefox-3"><img
src="stopie.png" align="middle"></a><br>
<span style="color: white;">Copyright © Tout droits
réservés - Il est interdit de copier une information de ce site. </span><img
style="color: white; width: 34px; height: 34px;" alt=""
src="warning.png"><span style="color: white;">
Le webmaster peut savoir si vous le faites !!!</span><br>
</div>
</body>
</html>
J'aimerais de l'aide pour aligner verticalement centré par rapport au teste avec le CSS -
Contributeuraligner verticalement c'est pas dans la nature de HTML.
regarde cet article, il y a plusieurs solutions possibles.
Contributeur@| ^ - ^ |Dans tout le code que j'ai donné, tu peux corriger les erreurs W3C stp ?
c'est un forum d'entraide pas de sous traitance.
te voila un validateur en français si tu préfères.
