Qui aura la solution !!!
voila mon soucis est assez chiant dans le normal mon pc plante
ecran bleu
tout se fige
ect
d'apres nod32 et avast pas de virus.
j'ai analusé les erreurs
Analysis
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Wed 07/01/2009 13:20:05 your computer crashed
This was likely caused by the following module: nv4_disp.dll
Bugcheck code: 0x10000050 (0xBAFB7000, 0x1, 0xBFAC3184, 0x0)
Error: Unknown
file path: C:\WINDOWS\system32\nv4_disp.dll
product: NVIDIA Compatible Windows 2000 Display driver, Version 180.84
company: NVIDIA Corporation
description: NVIDIA Compatible Windows 2000 Display driver, Version 180.84
On Tue 06/01/2009 23:15:41 your computer crashed
This was likely caused by the following module: yk51x86.sys
Bugcheck code: 0x40000080 (0x8A3D2A68, 0x89E0CC10, 0x80551240, 0x1)
Error: Unknown
file path: C:\WINDOWS\system32\drivers\yk51x86.sys
product: Marvell Yukon Ethernet Controller
company: Marvell
description: NDIS5.1 Miniport Driver for Marvell Yukon Ethernet Controller
On Mon 05/01/2009 10:25:44 your computer crashed
Bugcheck code: 0x40000080 (0x8A3F8130, 0x89E01C10, 0x80551240, 0x1)
Error: Unknown
company: Marvell
On Sun 04/01/2009 22:57:03 your computer crashed
Bugcheck code: 0x40000080 (0x8A3EB6B8, 0x89D31C10, 0x80551240, 0x1)
Error: Unknown
company: Marvell
On Sun 04/01/2009 22:20:46 your computer crashed
Bugcheck code: 0x40000080 (0x8A3DF130, 0x89DB0C10, 0x80551240, 0x1)
Error: Unknown
company: Marvell
On Sun 04/01/2009 18:26:33 your computer crashed
Bugcheck code: 0x40000080 (0x8A38B438, 0x89E00C10, 0x80551240, 0x1)
Error: Unknown
company: Marvell
On Sun 04/01/2009 16:36:53 your computer crashed
This was likely caused by the following module: sfhlp01.sys
Bugcheck code: 0x1000008E (0xC0000005, 0xBF801C6E, 0xB5876C48, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
file path: C:\WINDOWS\system32\drivers\sfhlp01.sys
product: StarForce Protection System
company: Protection Technology
description: StarForce Protection Helper Driver
On Sun 04/01/2009 15:28:25 your computer crashed
This was likely caused by the following module: win32k.sys
Bugcheck code: 0x1000008E (0xC0000005, 0xBF801BBD, 0xB6D1BC44, 0x0)
file path: C:\WINDOWS\system32\win32k.sys
product: Système d'exploitation Microsoft® Windows®
company: Microsoft Corporation
description: Pilote Win32 multi-utilisateurs
The crash took place in a standard Microsoft module. Likely the culprit is another driver on your system which cannot be identified.
On Sun 04/01/2009 15:06:28 your computer crashed
Bugcheck code: 0x1000008E (0xC0000005, 0x80546AD1, 0xB68CBBC0, 0x0)
On Fri 02/01/2009 17:29:36 your computer crashed
This was likely caused by the following module: memory_corruption
Bugcheck code: 0x4E (0x8F, 0x2FBFF, 0x2FAFF, 0x0)
Error: PFN_LIST_CORRUPT
This file could not be located on your computer, we suggest that you search on it with Google.
Click here to do a Google search on memory_corruption
On Fri 02/01/2009 11:05:41 your computer crashed
This was likely caused by the following module: ntoskrnl.exe
Bugcheck code: 0x1000000A (0x10, 0x2, 0x1, 0x805172D6)
Error: Unknown
file path: C:\WINDOWS\system32\ntoskrnl.exe
description: Noyau et système NT
On Tue 30/12/2008 21:14:45 your computer crashed
This was likely caused by the following module: npfs.sys
Bugcheck code: 0x1000000A (0x145, 0x1C, 0x1, 0x80502CCC)
Error: Unknown
file path: C:\WINDOWS\system32\drivers\npfs.sys
product: Microsoft® Windows® Operating System
description: NPFS Driver
On Mon 29/12/2008 15:49:39 your computer crashed
Bugcheck code: 0x40000080 (0x8A3C7700, 0x89DB6C10, 0x80551240, 0x2)
Error: Unknown
company: Marvell
On Mon 29/12/2008 11:03:34 your computer crashed
This was likely caused by the following module: eamon.sys
Bugcheck code: 0x1000008E (0xC0000005, 0x805A3A0E, 0xB77B87E4, 0x0)
Click here to do a Google search on eamon.sys
On Mon 29/12/2008 10:42:11 your computer crashed
Bugcheck code: 0x40000080 (0x8A3A1130, 0x89D34C10, 0x80551240, 0x2)
Error: Unknown
company: Marvell
On Sat 27/12/2008 15:05:51 your computer crashed
This was likely caused by the following module: jgogo.sys
Bugcheck code: 0x1000008E (0xC0000005, 0xBF856A72, 0xB6F0CC3C, 0x0)
file path: C:\WINDOWS\system32\drivers\jgogo.sys
product: SCSI Port upper filter driver
company: JMicron
description: SCSI Port upper filter driver
Conclusion
16 crash dumps have been found and analyzed. Note that it's not always possible to state with certainty whether a reported driver is really responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
merci de votre aide, et que la force soit avec vous
Firefox 3.0.5
12 réponses
    Essayes de trouver une mise a jour pour ton pilote de carte réseau (Marvell yukon) c'est lui qui à le plus d'erreur
    les autres n'interviennent qu'une fois
    1. NOD32 et Avast sont tous les 2 installés sur ton PC avec protection en temps réel activée ???????
      1. nan j'ai desinstallé nod32 et j'ai mis avast je c pas pk mais j'aime mieu celui la
        1. okii je mes a jour marvell
            @pifoulien interessant, je le mets en favoris , merci ^^
        2. la j'ai, just fait la mise a jour de marvell on verra bien se qui se passe
          1. sa a crashé apres que je joué a far cry 2
            On Thu 08/01/2009 21:06:11 your computer crashed
            Bugcheck code: 0x1000007F (0x8, 0x80042000, 0x0, 0x0)
            Error: UNEXPECTED_KERNEL_MODE_TRAP_M
            On Thu 08/01/2009 21:05:07 your computer crashed
            Bugcheck code: 0x1000000A (0xC70B2A5C, 0x2, 0x1, 0x8052271B)
            Error: Unknown
              ah M...
              starforce... bah c'est pas étonnant alors , je l'avais pas vu le premier coup
              1. Ça sert à quoi ce truc à la base ?
            2. mon logiciel sert a dterminé ce qui a fait crashé mon ordi
              deja apres quelques modification il plante vraiment moin qu'avant
              1. En fait, je parlais de Starforce. C'est ça ton logiciel de diagnostique ?
            3. Contributeur
              Starforce est une protection anti copie pour jeux assez lourde et qui fait planter pas mal de bécane... beacuoup de communauté de joueurs se sont plaintes de ses effets négatifs (de même que la derniere version de Securom)
              1. On Thu 15/01/2009 09:16:55 your computer crashed
                Bugcheck code: 0x1A (0x781, 0xC06B7E08, 0x0, 0xE39BE010)
                Error: MEMORY_MANAGEMENT
                  hmm la c'est carrément le noyau qui plante, je te conseille de sauvegarder tes données et de formater
                  1. StarForce Protection Helper Driver
                    ce qui peut expliquer tes pannes si ton cd est un pirate via daemon tolls par exemple, voir même si c'est un original selon ta config.
                    une erreur dans ton genre peut aussi arrivé après défaillance d'une barette mémoire ou si tu es en nforce via la gestion xp du bus et du logiciel nforce de ta marque (carte mère qui gère)ce qui génère un conflict.
                    la premiere étape est de tester tes barettes mémoire en en remplacant par une dont tu sois sur qu'elle fonctionne.
                    la deuxieme étape est de vérifier que tu n'as bien qu'un seul antivirus(donc désinstallation totale de l'ancien), à titre personnel conserve nod32 qui est beaucoup plus évolué,donc moins lourd et plus efficace.
                    la troisieme étape est la désactivation de ton pare feu, vu que l'antivirus gère l'ensemble et la vérification que ton pc soit propre'sans spyware, vers,etc...
                    mais vu l'explication que tu as fourni pour ta panne je penche pour starforce lié à piratage.
