Doom 3 , probleme OpenGL
Comme pas mal de monde j'ai un problème avec l'open GL , en lancant le jeu j'ai ce message :
DOOM 1.0.1282 win-x86 Sep 16 2004 16:45:51
2210 MHz AMD CPU with MMX & 3DNow! & SSE & SSE2 & SSE3 & HTT
2048 MB System Memory
512 MB Video Memory
Winsock Initialized
Hostname: thiery-k0z56t60
IP: 5.166.148.11
IP: 192.168.1.177
doom using MMX & SSE & SSE2 & SSE3 for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Loaded pk4 C:\Program Files\Doom 3\base\game00.pk4 with checksum 0x7dafc4d4
Loaded pk4 C:\Program Files\Doom 3\base\pak000.pk4 with checksum 0x28d208f1
Loaded pk4 C:\Program Files\Doom 3\base\pak001.pk4 with checksum 0x40244be0
Loaded pk4 C:\Program Files\Doom 3\base\pak002.pk4 with checksum 0xc51ecdcd
Loaded pk4 C:\Program Files\Doom 3\base\pak003.pk4 with checksum 0xcd79d028
Loaded pk4 C:\Program Files\Doom 3\base\pak004.pk4 with checksum 0x765e4f8b
Loaded pk4 C:\Program Files\Doom 3\base\pak005.pk4 with checksum 0x8ffc3621
Loaded pk4 C:\Program Files\Doom 3\base\zpak000.pk4 with checksum 0x9ffadfa3
Loaded pk4 C:\Program Files\Doom 3\base\zpak001.pk4 with checksum 0x2f57868f
Current search path:
C:\Program Files\Doom 3/base
C:\Program Files\Doom 3\base\zpak001.pk4 (70 files)
C:\Program Files\Doom 3\base\zpak000.pk4 (961 files)
C:\Program Files\Doom 3\base\pak005.pk4 (63 files)
C:\Program Files\Doom 3\base\pak004.pk4 (5137 files)
C:\Program Files\Doom 3\base\pak003.pk4 (4676 files)
C:\Program Files\Doom 3\base\pak002.pk4 (6120 files)
C:\Program Files\Doom 3\base\pak001.pk4 (8972 files)
C:\Program Files\Doom 3\base\pak000.pk4 (2698 files)
C:\Program Files\Doom 3\base\game00.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
file system initialized.
----- Initializing Decls -----
------- Initializing renderSystem --------
using ARB renderSystem
renderSystem initialized.
5151 strings read from strings/english.lang
Couldn't open journal files
execing editor.cfg
execing default.cfg
"" isn't a valid key
couldn't exec DoomConfig.cfg
couldn't exec autoexec.cfg
5151 strings read from strings/french.lang
----- Initializing Sound System ------
sound system initialized.
----- R_InitOpenGL -----
Initializing OpenGL subsystem
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' ): succeeded
Couldn't find proc address for: wglGetExtensionsStringARB
Couldn't find proc address for: wglSwapIntervalEXT
Couldn't find proc address for: wglGetPixelFormatAttribivARB
Couldn't find proc address for: wglGetPixelFormatAttribfvARB
Couldn't find proc address for: wglChoosePixelFormatARB
Couldn't find proc address for: wglCreatePbufferARB
Couldn't find proc address for: wglGetPbufferDCARB
Couldn't find proc address for: wglReleasePbufferDCARB
Couldn't find proc address for: wglDestroyPbufferARB
Couldn't find proc address for: wglQueryPbufferARB
Couldn't find proc address for: wglBindTexImageARB
Couldn't find proc address for: wglReleaseTexImageARB
Couldn't find proc address for: wglSetPbufferAttribARB
...calling CDS: ok
...created window @ 0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...PIXELFORMAT 7 selected
...creating GL context: succeeded
...making context current: succeeded
------- Input Initialization -------
Initializing DirectInput...
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
sound: STEREO
X..GL_ARB_multitexture not found
X..GL_ARB_texture_env_combine not found
X..GL_ARB_texture_cube_map not found
X..GL_ARB_texture_env_dot3 not found
X..GL_ARB_texture_env_add not found
X..GL_ARB_texture_non_power_of_two not found
X..GL_ARB_texture_compression not found
X..GL_EXT_texture_filter_anisotropic not found
X..GL_EXT_texture_lod not found
X..GL_1.4_texture_lod_bias not found
X..GL_EXT_shared_texture_palette not found
X..GL_EXT_texture3D not found
X..GL_EXT_stencil_wrap not found
X..GL_NV_register_combiners not found
X..GL_EXT_stencil_two_side not found
X..GL_ATI_separate_stencil not found
X..GL_ATI_fragment_shader not found
X..GL_ARB_vertex_buffer_object not found
X..GL_ARB_vertex_program not found
X..GL_ARB_fragment_program not found
ERROR: Votre combinaison de carte graphique et pilote ne prend pas en charge les paramètres nécessaires.
Error during initialization
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
Bref j'ai lu qu'il fallait mettre à jour ces pilotes mais ca ne change rien du tout , ce serait plus un problème de patch de mise à jour Pour l'openGL
J'ai une Ggorce 8500 gt et mon pote une 8800 gtx
Merci d'avance
Firefox 1.5.0.12
  1. http://www.clubic.com/lancer-le-telechargement-41034-0-doom-3-patch-v1-31-version-windows.html
    1. Salut,
      après avoir rencontré le même problème que toi
      j'ai installé le patch 1.31 (arrivé plus tard sûrement)
      et bingo, ça marche
      1. Salut. Simplement pour savoir comment ouvrir le patch 1.31 de Doom 3 sur mac. j'ai le jeu et tt mais j'arrive pas à lancer le patch. merci d'avance.
