Run.vbs et problème de script
Bonjour, je rencontre le même problème help me svp
  1. voila le message après redémarrage
    Résultats de correction de Farbar Recovery Scan Tool (x64) Version:05-03-2016 01
    Exécuté par sylvain (2016-03-17 20:15:30) Run:1
    Exécuté depuis C:\Users\sylvain\Desktop
    Profils chargés: sylvain (Profils disponibles: sylvain)
    Mode d'amorçage: Normal
    fixlist contenu:
    Task: {D5E2CEB3-D54B-4920-8D37-854ADF13DF51} - System32\Tasks\{D5333B26-E9A8-49ED-950B-FF3773BA666B} => pcalua.exe -a "C:\Users\sylvain\AppData\Roaming\1H1Q1V0B1L1G1N1V0M1P1Q1L1T0D1P1E2Z\Windows Movie Maker Packages\uninstaller.exe" -c /Uninstall /NM="Windows Movie Maker Packages" /AN="1H1Q1V0B1L1G1N1V0M1P1Q1L1T0D1P1E2Z" /MBN="Windows Movie Maker Packages"
    Task: {8B840480-C98F-4FA7-BC87-FD8AFA2290A8} - System32\Tasks\7IsWtBCDfB78m0h => C:\Users\sylvain\AppData\Roaming\JBIG2eo\Qmsa3H2.exe
    Task: {8C7EEF11-170F-4C9A-91EE-69D205BE706C} - System32\Tasks\q8GJZJ3EF2PxdDJ => C:\Users\sylvain\AppData\Roaming\eiUgyUJ\wslQJZz.exe
    HKLM-x32\...\Run: [ospd_us_013010265] => [X]
    HKLM-x32\...\Run: [sun2] => [X]
    HKLM-x32\...\Run: [rec_fr_228] => "C:\Program Files (x86)\rec_fr_228\rec_fr_228.exe"
    HKLM-x32\...\Run: [sun21] => [X]
    HKLM-x32\...\Run: [mbot_en_037050270] => "C:\Program Files (x86)\mbot_en_037050270\mbot_en_037050270.exe"
    HKLM\...\RunOnce: [WINDOWS_SCREEN_MANAGER_UPDATER] => C:\Program Files\Windows Screen Manager\Windows screen manage updater.exe [15360 2016-03-17] (Wizzservices)
    HKLM\...\Winlogon: [Userinit] wscript C:\Windows\run.vbs,
    HKLM-x32\...\Winlogon: [Userinit] wscript C:\Windows\run.vbs, [X]
    Startup: C:\Users\sylvain\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Download.lnk [2015-02-26]
    ShortcutTarget: Download.lnk -> C:\ProgramData\{917249e7-6960-7e9a-9172-249e7696279d}\Download.exe (Pas de fichier)
    2016-03-17 19:06 - 2016-03-17 19:06 - 00000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MPC
    2016-03-17 18:46 - 2016-03-17 19:06 - 00001703 _____ C:\Users\Public\Desktop\MPC Cleaner.lnk
    2016-03-17 18:43 - 2016-03-17 18:43 - 00000000 ____D C:\Users\sylvain\AppData\Roaming\MCorp
    2016-03-17 18:18 - 2016-03-17 18:18 - 00000000 ____D C:\Users\sylvain\AppData\Local\app
    2016-03-17 18:16 - 2016-03-17 18:38 - 00000000 ____D C:\Program Files (x86)\MPC Cleaner
    2016-03-17 18:16 - 2016-03-17 18:16 - 00060136 ____N (DotC United Inc) C:\Windows\system32\Drivers\MPCKpt.sys
    2016-03-17 18:10 - 2016-03-17 18:10 - 00000000 ____D C:\Users\sylvain\AppData\Local\3810282D-6C19-47B0-8283-5C6C29A7E108
    2016-03-17 18:00 - 2016-03-17 18:00 - 00000000 ____D C:\Windows\system32\SSL
    2016-03-17 17:58 - 2016-03-17 17:59 - 00000000 ____D C:\Users\Public\Documents\dmp
    2016-03-17 17:58 - 2016-03-17 17:58 - 00000000 ____D C:\Program Files\Windows Screen Manager
    2016-03-12 18:21 - 2016-03-12 18:21 - 00000000 ____D C:\Windows\Tasks\ImCleanDisabled
    2016-03-12 18:21 - 2016-03-12 18:21 - 00000000 ____D C:\Users\sylvain\AppData\Roaming\ProductData
    2016-03-12 18:21 - 2016-03-12 18:21 - 00000000 ____D C:\Users\sylvain\AppData\LocalLow\IObit
    2016-03-12 18:21 - 2016-03-12 18:21 - 00000000 ____D C:\ProgramData\ProductData
    2016-03-12 18:21 - 2016-03-12 18:21 - 00000000 ____D C:\ProgramData\IObit
    2016-03-12 18:21 - 2016-03-12 18:21 - 00000000 ____D C:\ProgramData\{FD6F83C0-EC70-4581-8361-C70CD1AA4B98}
    2016-03-12 18:21 - 2016-03-12 18:21 - 00000000 ____D C:\ProgramData\{BAF091CA-86C4-4627-ADA1-897E2621C1B0}
    2016-03-12 18:20 - 2016-03-12 18:24 - 00000000 ____D C:\Program Files (x86)\IObit
    2016-03-12 18:20 - 2016-03-12 18:22 - 00000000 ____D C:\Users\sylvain\AppData\Roaming\IObit
    C:\Users\sylvain\AppData\Local\Temp\1EMCFVSEPE.exe
    C:\Users\sylvain\AppData\Local\Temp\9D45.tmp.exe
    C:\Users\sylvain\AppData\Local\Temp\C37.tmp.exe
    C:\Users\sylvain\AppData\Local\Temp\D2JMSC3XYD.exe
    C:\Users\sylvain\AppData\Local\Temp\G00JP25P49.exe
    C:\Users\sylvain\AppData\Local\Temp\ose00000.exe
    C:\Users\sylvain\AppData\Local\Temp\Quarantine.exe
    C:\Users\sylvain\AppData\Local\Temp\S2AVQFA45X.exe
    C:\Users\sylvain\AppData\Local\Temp\sqlite3.dll
    C:\Users\sylvain\AppData\Local\Temp\TRSUAG4JQS.exe
    C:\Users\sylvain\AppData\Local\Temp\XS6QD0MPR3.exe
    ProxyEnable: [.DEFAULT] => Proxy est activé.
    ProxyServer: [.DEFAULT] => http=127.0.0.1:63780;https=127.0.0.1:63780
    "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{D5E2CEB3-D54B-4920-8D37-854ADF13DF51}" => clé supprimé(es) avec succès
    "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{D5E2CEB3-D54B-4920-8D37-854ADF13DF51}" => clé supprimé(es) avec succès
    C:\Windows\System32\Tasks\{D5333B26-E9A8-49ED-950B-FF3773BA666B} => déplacé(es) avec succès
    "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\{D5333B26-E9A8-49ED-950B-FF3773BA666B}" => clé supprimé(es) avec succès
    "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon\{8B840480-C98F-4FA7-BC87-FD8AFA2290A8}" => clé supprimé(es) avec succès
    "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{8B840480-C98F-4FA7-BC87-FD8AFA2290A8}" => clé supprimé(es) avec succès
    C:\Windows\System32\Tasks\7IsWtBCDfB78m0h => déplacé(es) avec succès
    "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\7IsWtBCDfB78m0h" => clé supprimé(es) avec succès
    "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon\{8C7EEF11-170F-4C9A-91EE-69D205BE706C}" => clé supprimé(es) avec succès
    "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{8C7EEF11-170F-4C9A-91EE-69D205BE706C}" => clé supprimé(es) avec succès
    C:\Windows\System32\Tasks\q8GJZJ3EF2PxdDJ => déplacé(es) avec succès
    "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\q8GJZJ3EF2PxdDJ" => clé supprimé(es) avec succès
    HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Run\\ospd_us_013010265 => valeur supprimé(es) avec succès
    HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Run\\sun2 => valeur supprimé(es) avec succès
    HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Run\\rec_fr_228 => valeur supprimé(es) avec succès
    HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Run\\sun21 => valeur supprimé(es) avec succès
    HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Run\\mbot_en_037050270 => valeur supprimé(es) avec succès
    HKLM\Software\Microsoft\Windows\CurrentVersion\RunOnce\\WINDOWS_SCREEN_MANAGER_UPDATER => valeur supprimé(es) avec succès
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\\Userinit => valeur restauré(es) avec succès
    HKLM\Software\WOW6432Node\Microsoft\Windows NT\CurrentVersion\Winlogon\\Userinit => valeur restauré(es) avec succès
    C:\Users\sylvain\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Download.lnk => déplacé(es) avec succès
    C:\ProgramData\{917249e7-6960-7e9a-9172-249e7696279d}\Download.exe => non trouvé(e).
    C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MPC => déplacé(es) avec succès
    C:\Users\Public\Desktop\MPC Cleaner.lnk => déplacé(es) avec succès
    C:\Users\sylvain\AppData\Roaming\MCorp => déplacé(es) avec succès
    C:\Users\sylvain\AppData\Local\app => déplacé(es) avec succès
    "C:\Program Files (x86)\MPC Cleaner" => non trouvé(e).
    Impossible de déplacer "C:\Windows\system32\Drivers\MPCKpt.sys" => Planifié pour déplacement au redémarrage.
    C:\Users\sylvain\AppData\Local\3810282D-6C19-47B0-8283-5C6C29A7E108 => déplacé(es) avec succès
    C:\Windows\system32\SSL => déplacé(es) avec succès
    C:\Users\Public\Documents\dmp => déplacé(es) avec succès
    C:\Program Files\Windows Screen Manager => déplacé(es) avec succès
    C:\Windows\Tasks\ImCleanDisabled => déplacé(es) avec succès
    C:\Users\sylvain\AppData\Roaming\ProductData => déplacé(es) avec succès
    C:\Users\sylvain\AppData\LocalLow\IObit => déplacé(es) avec succès
    C:\ProgramData\ProductData => déplacé(es) avec succès
    C:\ProgramData\IObit => déplacé(es) avec succès
    C:\ProgramData\{FD6F83C0-EC70-4581-8361-C70CD1AA4B98} => déplacé(es) avec succès
    C:\ProgramData\{BAF091CA-86C4-4627-ADA1-897E2621C1B0} => déplacé(es) avec succès
    C:\Program Files (x86)\IObit => déplacé(es) avec succès
    C:\Users\sylvain\AppData\Roaming\IObit => déplacé(es) avec succès
    C:\Users\sylvain\AppData\Local\Temp\1EMCFVSEPE.exe => déplacé(es) avec succès
    C:\Users\sylvain\AppData\Local\Temp\9D45.tmp.exe => déplacé(es) avec succès
    C:\Users\sylvain\AppData\Local\Temp\C37.tmp.exe => déplacé(es) avec succès
    C:\Users\sylvain\AppData\Local\Temp\D2JMSC3XYD.exe => déplacé(es) avec succès
    C:\Users\sylvain\AppData\Local\Temp\G00JP25P49.exe => déplacé(es) avec succès
    C:\Users\sylvain\AppData\Local\Temp\ose00000.exe => déplacé(es) avec succès
    C:\Users\sylvain\AppData\Local\Temp\Quarantine.exe => déplacé(es) avec succès
    C:\Users\sylvain\AppData\Local\Temp\S2AVQFA45X.exe => déplacé(es) avec succès
    C:\Users\sylvain\AppData\Local\Temp\sqlite3.dll => déplacé(es) avec succès
    C:\Users\sylvain\AppData\Local\Temp\TRSUAG4JQS.exe => déplacé(es) avec succès
    C:\Users\sylvain\AppData\Local\Temp\XS6QD0MPR3.exe => déplacé(es) avec succès
    HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings\\ProxyEnable => valeur supprimé(es) avec succès
    HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Internet Settings\\ProxyServer => valeur supprimé(es) avec succès
    Résultats du déplacement planifié des fichiers (Mode d'amorçage: Normal) (Date&Heure: 2016-03-17 20:17:31)
    "C:\Windows\system32\Drivers\MPCKpt.sys" => Impossible de déplacer
    Fin de Fixlog 20:17:31
      ok fais la suite =)
    2. je fai quoi une foi
      que hitman pro a fini??
    3. c'est fait
    4. merci beaucoup de ton aide je la recomanderais!!!!!!
  2. Modérateur
    Désinstalle Spybot
    Voici la correction à effectuer avec FRST. Tu peux t'aider de cette note explicative avec des captures d'écran.
    Ouvre le bloc-notes : Touche Windows + R,
    Dans le champs "Exécuter", saisir notepad et OK.
    Copie/Colle dedans ce qui suit :
    Une fois, le texte collé dans le Bloc-notes,
    Menu "Fichier" puis "Enregistrer sous",
    A gauche, place toi sur le Bureau,
    Dans le champs en bas, nom du fichier mets : fixlist.txt
    Clique sur "Enregistrer", cela va créer fixlist.txt sur le Bureau.
    Relance FRST et clique sur le bouton "Corriger / Fix"
    Un redémarrage sera peut-être nécessaire ( pas obligatoire )
    Un fichier texte apparait, copie/colle le contenu ici dans un nouveau message.
    2/ Fais un nettoyage Hitman Pro
    3/
    Réinitialise tes navigateurs et/ou re-paramètre manuellement tes navigateurs WEB ( page de démarrage, moteur de recherche, etc ) mais aussi supprimer/désactiver les extensions inutiles/parasites.
    Pour t'aider à effectuer ce ménage, clique ci-dessous sur le nom du navigateur WEB que tu utilises :
    4/ Refais un scan FRST et donne les nouveaux rapports via pjjoint.
    1. http://pjjoint.malekal.com/files.php?id=FRST_20160317_m6z12f13l6r5
      http://pjjoint.malekal.com/files.php?id=20160317_z5z9n11z5g7
        Bcp d'adwares, je te fais le rapport de correction.
