Problème Opengl.
Bonjour à tous,
Je vais vous expliquer mon problème.
J'ai un petit pc qui tourne bien mais j'ai un problème avec minecraft.
Voici ma config:
Toshiba satellite c850-19D sous intel celeron. Carte graphique intel HD Graphics et Windows 10.
Avant j'arrivais à jouer à Minecraft mais j'ai activer une option opengl je ne connais plus le nom précis et depuis, impossible de lancer Minecraft. A chaque fois, il est affiché:
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 18/11/15 19:01
-- System Details --
Details:
Minecraft Version: 1.5.2
Operating System: Windows 10 (x86) version 10.0
Java Version: 1.8.0_66, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 453352816 bytes (432 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
JVM Flags: 2 total; -Xms512m -Xmx1024m
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: ~~ERROR~~ NullPointerException: null
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: Default
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:235)
at avv.a(SourceFile:56)
at net.minecraft.client.Minecraft.run(SourceFile:507)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT 37f8ef4f ----------
Voilà, merci de votre aide!
Bien à vs,
gugu312
  1. Salut,
    As-tu essayé de réinitialiser les réglages du jeu ?
    Rends-toi dans le dossier du jeu :
    • clique sur "Démarrer"
    • écrit "%appdata%" dans la zone de recherche puis clique dessus lorsqu'il te l'affiche dans les résultats de la recherche (voir capture)
    • dans la fenêtre qui s'ouvre, rends-toi dans le dossier .minecraft
    Il te suffit ensuite de supprimer le fichier nommé "options" puis de relancer le jeu.
    1. Merci mais j'ai carrément supprimé tous les fichiers! je l'ai réinstallé par la suite mais ça n'a rien change \:.
      Merci bcp,
      gugu312
  2. Modérateur
    --> Télécharge et installe 7-Zip :
    https://www.7-zip.org/download.html
    --> Télécharge ce pilote :
    http://support1.toshiba-tro.de/tedd-files2/0/display-20131016101804.zip
    --> Clique droit sur le fichier "display-20131016101804", choisis "7-Zip" puis "Extraire vers "display-20131016101804". Tu obtiens un dossier nommé "display-20131016101804", ouvre-le.
    --> Clique droit sur le fichier "TC00576000C", choisis "7-Zip" puis "Extraire vers "TC00576000C". Tu obtiens un dossier nommé "TC00576000C".
    --> Ouvre le gestionnaire de périphériques.
    --> Clique droit sur "la carte graphique" et choisis "Mettre à jour le pilote...".
    --> Choisis "Rechercher un pilote sur mon ordinateur".
    --> Clique sur "Choisir parmi une liste de pilotes..." puis sur "Disque fourni".
    --> Sélectionne le fichier kit54495.inf présent dans display-20131016101804 > TC00576000C > SNB > Graphics et valide.
    --> Clique sur "Suivant".
    1. Je l'ai fait mais il indique: "Le meilleur pilote est déjà installé".
      Je crois que c'est plutôt un problème de configuration.
      Merci quand même (:
    2. Modérateur
      La procédure proposée permet de choisir le pilote utilisé pour la carte graphique même si celui-ci est plus ancien. Vu le message indiqué, tu as dû te tromper à partir de cette étape :
    3. Oui mais je ne vois pas le dossier spécifié.
      Je n'ai que HSW-IVB=> "Display audio" ou "graphics" ou "autorun.inf" puis dans "Display audio" il y a ça: "IntcDAud.inf" et dans "graphics", il n'y a rien.
      Merci de vos réponses,
      gugu312
    4. Modérateur
      SNB et non HSW_IVB :
    5. Destrio5 j'ai un probleme similaire sauf que j'ai ce probleme depuis que j'ai instalé Windows 10
  3. Modérateur
    Finalement, j'ai besoin du numéro d'identification du chipset graphique Intel pour vérifier.
    https://www.commentcamarche.net/faq/35597-trouver-le-numero-d-identification-d-un-peripherique
    1. PCI\VEN_8086&DEV_0106&SUBSYS_FB301179&REV_09
      voilà j'espère que avec ça, ça ira (:
  4. Modérateur
    https://www.commentcamarche.net/faq/9265-identifier-son-materiel-avec-aida64
    Copie-colle le résumé généré par AIDA64 dans ton prochain message.
    1. voilà désolé pour le retard.
      --------[ AIDA64 Extreme ]----------------------------------------------------------------------------------------------
      Version AIDA64 v5.50.3600/fr
      Module de test 4.1.643-x64
      Site web https://www.aida64.com/
      Type de rapport Générateur de rapports [ TRIAL VERSION ]
      Ordinateur USER_PC
      Générateur nbvcZQJYF
      Système d'exploitation Microsoft Windows 10 Home 10.0.10240.16590 (Win10 RTM)
      Date 2015-11-22
      Temps 17:06
      --------[ Résumé ]------------------------------------------------------------------------------------------------------
      Ordinateur:
      Type de système ACPI x64-based PC (Mobile)
      Service Pack du système [ TRIAL VERSION ]
      Internet Explorer 11.0.10240.16590
      Edge 20.10240.16384.0
      DirectX DirectX 12.0
      Nom du système USER_PC
      Nom de l'utilisateur nbvcZQJYF
      Domaine de connexion [ TRIAL VERSION ]
      Date / Heure 2015-11-22 / 17:06
      Carte mère:
      Type de processeur Mobile DualCore Intel Celeron B830, 1800 MHz (18 x 100)
      Nom de la carte mère Toshiba Satellite C850
      Chipset de la carte mère Intel Panther Point HM70, Intel Sandy Bridge
      Mémoire système [ TRIAL VERSION ]
      DIMM1: Elpida EBJ41UF8BCS0-DJ-F 4 Go DDR3-1333 DDR3 SDRAM (10-9-9-24 @ 666 MHz) (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 609 MHz) (7-7-7-20 @ 533 MHz) (6-6-6-17 @ 457 MHz) (5-5-5-14 @ 380 MHz)
      DIMM3: Samsung M471B5173BH0-CK0 [ TRIAL VERSION ]
      Type de Bios Unknown (10/01/2013)
      Moniteur:
      Carte vidéo Intel(R) HD Graphics (2108 Mo)
      Accélérateur 3D Intel HD Graphics 2000
      Moniteur Samsung 156AT24-T01 [15.6" LCD]
      Multimédia:
      Carte audio Intel Panther Point HDMI @ Intel Panther Point PCH - High Definition Audio Controller [C-1]
      Carte audio Realtek ALC269 @ Intel Panther Point PCH - High Definition Audio Controller [C-1]
      Stockage:
      Contrôleur IDE Intel(R) 7 Series Chipset Family SATA AHCI Controller
      Contrôleur de stockage Contrôleur des espaces de stockage Microsoft
      Disque dur TOSHIBA MQ01ABD032 (320 Go, 5400 RPM, SATA-II)
      Lecteur optique HL-DT-ST DVDRAM GT80N (DVD+R9:6x, DVD-R9:6x, DVD+RW:8x/8x, DVD-RW:8x/6x, DVD-RAM:5x, DVD-ROM:8x, CD:24x/24x/24x DVD+RW/DVD-RW/DVD-RAM)
      État des disques durs SMART OK
      Partitions:
      C: (NTFS) [ TRIAL VERSION ]
      Taille totale [ TRIAL VERSION ]
      Entrée:
      Clavier Clavier standard PS/2
      Souris Synaptics PS/2 Port TouchPad
      Réseau:
      Adresse IP principale [ TRIAL VERSION ]
      Adresse MAC principale
      Carte réseau Microsoft Wi-Fi Direct Virtual Adapter
      Carte réseau Realtek PCIe FE Family Controller
      Carte réseau Realtek RTL8188CE Wireless LAN 802.11n PCI-E NIC (192. [ TRIAL VERSION ])
      Carte réseau TeamViewer VPN Adapter
      Carte réseau VirtualBox Host-Only Ethernet Adapter (169. [ TRIAL VERSION ])
      Périphériques:
      Imprimante Canon MP270 series
      Imprimante Canon MP495 series Printer WS
      Imprimante Fax
      Imprimante Microsoft Print to PDF
      Imprimante Microsoft XPS Document Writer
      Imprimante Send To OneNote 16
      Contrôleur USB2 Intel Panther Point PCH - USB 2.0 EHCI Controller #1 [C-1]
      Contrôleur USB2 Intel Panther Point PCH - USB 2.0 EHCI Controller #2 [C-1]
      Contrôleur USB3 Intel Panther Point PCH - USB 3.0 xHCI Controller [C-1]
      Périphérique USB Generic USB Hub
      Périphérique USB Périphérique USB composite
      Périphérique USB TOSHIBA Web Camera - HD
      Batterie Adaptateur secteur Microsoft
      Batterie Batterie à méthode de contrôle compatible ACPI Microsoft
      DMI:
      Distributeur du Bios Insyde Corp.
      Version du Bios 6.80
      Fabricant du système TOSHIBA
      Nom du système SATELLITE C850-19D
      Version du système PSCBWE-03200UBT
      N° de série du système [ TRIAL VERSION ]
      UUID du système [ TRIAL VERSION ]
      Fabricant de la carte mère Intel
      Nom de la carte mère PLCSF8
      Version de la carte mère Type2 - Board Version
      N° de série de la carte mère [ TRIAL VERSION ]
      Fabricant du châssis OEM Chassis Manufacturer
      Version du châssis OEM Chassis Version
      N° de série du châssis [ TRIAL VERSION ]
      Identifiant du châssis [ TRIAL VERSION ]
      Type du châssis Notebook
      Sockets mémoire (Total/Libres) 2 / 0
