Problème script .vbs
Quelqu'un peurrait me dire pourquoi ce script ne fonctionne pas merci d'avance
Dim oShell
dim i
Dim arrTouches1, arrTouches2, arrTouches3, arrTouches4, arrTouches5, arrTouches6, arrTouches7, arrTouches8, arrTouches9, arrTouches10, arrTouches11, arrTouches12, arrTouches13, arrTouches14, arrTouches15, arrTouches16, arrTouches17, arrTouches18, arrTouches19, arrTouches20, arrTouches21, arrTouches22, arrTouches23, arrTouches24, arrTouches25, arrTouches26, arrTouches27, arrTouches28, arrTouches29, arrTouches30, arrTouches31, arrTouches32, arrTouches33, arrTouches34, arrTouches35, arrTouches36, arrTouches37, arrTouches38, arrTouches39, bActivate, bExec
arrTouches1 = Array("s")
arrTouches3 = Array("a")
arrTouches4 = Array("l")
arrTouches5 = Array("u")
arrTouches6 = Array("t")
arrTouches7 = Array(" ")
arrTouches8 = Array("j")
arrTouches9 = Array("'")
arrTouches10 = Array("a")
arrTouches11 = Array("i")
arrTouches12 = Array(" ")
arrTouches13 = Array("p")
arrTouches14 = Array("r")
arrTouches15 = Array("i")
arrTouches16 = Array("s")
arrTouches17 = Array(" ")
arrTouches18 = Array("l")
arrTouches19 = Array("e")
arrTouches20 = Array(" ")
arrTouches21 = Array("c")
arrTouches22 = Array("o")
arrTouches23 = Array("n")
arrTouches24 = Array("t")
arrTouches25 = Array("r")
arrTouches26 = Array("o")
arrTouches27 = Array("l")
arrTouches28 = Array("e")
arrTouches29 = Array(" ")
arrTouches30 = Array("d")
arrTouches31 = Array("e")
arrTouches32 = Array(" ")
arrTouches33 = Array("t")
arrTouches34 = Array("o")
arrTouches35 = Array("n")
arrTouches36 = Array(" ")
arrTouches37 = Array("P")
arrTouches38 = Array("C")
Set oShell = CreateObject("WScript.Shell")
bExec = oShell.Run("notepad.exe")
WScript.Sleep 2000
bActivate = oShell.AppActivate("Notepad")
For i=0 To UBound(arrTouches1, arrTouches2, arrTouches3, arrTouches4, arrTouches5, arrTouches6, arrTouches7, arrTouches8, arrTouches9, arrTouches10, arrTouches11, arrTouches12, arrTouches13, arrTouches14, arrTouches15, arrTouches16, arrTouches17, arrTouches18, arrTouches19, arrTouches20, arrTouches21, arrTouches22, arrTouches23, arrTouches24, arrTouches25, arrTouches26, arrTouches27, arrTouches28, arrTouches29, arrTouches30, arrTouches31, arrTouches32, arrTouches33, arrTouches34, arrTouches35, arrTouches36, arrTouches37, arrTouches38, arrTouches39)
WScript.Sleep 100
oShell.SendKeys arrTouches1, arrTouches2, arrTouches3, arrTouches4, arrTouches5, arrTouches6, arrTouches7, arrTouches8, arrTouches9, arrTouches10, arrTouches11, arrTouches12, arrTouches13, arrTouches14, arrTouches15, arrTouches16, arrTouches17, arrTouches18, arrTouches19, arrTouches20, arrTouches21, arrTouches22, arrTouches23, arrTouches24, arrTouches25, arrTouches26, arrTouches27, arrTouches28, arrTouches29, arrTouches30, arrTouches31, arrTouches32, arrTouches33, arrTouches34, arrTouches35, arrTouches36, arrTouches37, arrTouches38, arrTouches39(i)
Next
Set oShell = Nothing
merci d'avoir répondu mais sa ne marche toujours pas, le message d'erreur est type incompatible sendkeys.
@jordane45J'ai bien copier collé en complétant avec le début de mon script
Le notepad s'ouvre
Je ne sais pas c'est quoi un OS -
Le notepad s'ouvre
@jordane45Le notepad s'ouvre
J'ai bien copié/collé le script en le complétant avec le début du mien
Je ne sais pas se que c'est qu'un OS
Dsl -
ModérateurBonjour,
Je pense que ton souci vient de ton UBOUND....
http://www.w3schools.com/vbscript/func_ubound.asp
Cela vient aussi de ta logique.. pourquoi déclarer un tableau par Lettre... alors que tu pourrais faire UN TABLEAU pour TOUTES les lettres ??
Dim arrTouches(37) arrTouches(0) = "s" arrTouches(1) = "a" arrTouches(2) = "l" arrTouches(3) = "u" arrTouches(4) = "t" ' etc... 'la boucle deviendrait alors... For i=0 To UBound(arrTouches) WScript.Sleep 100 oShell.SendKey arrTouches(i) Next
Modérateur@DamDC91Le souci.. c'est que....
sa ne marche pas
ne nous permet pas de trouver l'erreur.....
Lorsque tu as un message d'erreur (et c'etait forcément le cas avec mon code...) tu dois le lire et essayer de le comprendre pour le corriger.... et /ou au moins.. nous le donner !!!!
Donc.. une fois le message d'erreur lu... tu t'aperçois que j'ai écrit : Sendkey .. au lieu de Sendkeys ....
Voici le code corrigé =>>Dim oShell dim i Dim arrTouches(5) arrTouches(0) = "s" arrTouches(1) = "a" arrTouches(2) = "l" arrTouches(3) = "u" arrTouches(4) = "t" ' etc... Set oShell = CreateObject("WScript.Shell") bExec = oShell.Run("notepad.exe") WScript.Sleep 2000 bActivate = oShell.AppActivate("Notepad") 'la boucle deviendrait alors... For i=0 To UBound(arrTouches) WScript.Sleep 200 oShell.SendKeys arrTouches(i) Next Set oShell = Nothing
NB: Pour ajouter des lettres supplémentaires...n'oublies pas qu'il faut ausi que tu modifies aussi la variable (5) qui se trouve dans le dim du arrTouches...
