Problème avec Minecraft
Bonjour je ne suis pas très qualifié en informatique, mais pourriez-vous m'aider à enlever ce message quand je veux aller sur Minecraft ?
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 10/02/13 20:10
-- System Details --
Details:
Minecraft Version: 1.4.7
Operating System: Windows XP (x86) version 5.1
Java Version: 1.7.0_13, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 453456488 bytes (432 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
JVM Flags: 2 total; -Xms512m -Xmx1024m
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: ~~ERROR~~ NullPointerException: null
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: Default
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:232)
at asq.a(SourceFile:56)
at net.minecraft.client.Minecraft.run(SourceFile:515)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT e01b0c48 ----------
J'éspère avoir de l'aide au plus vite ! (De l'aide utile)
8 réponses
    ---> Télécharge et installe 7-Zip :
    https://www.commentcamarche.net/telecharger/utilitaires/2197-7-zip/
    ---> Clique droit sur le fichier "6-11-pre-r300_xp-2k_dd_ccc_wdm_38185", choisis "7-Zip" puis "Extraire vers "6-11-pre-r300_xp-2k_dd_ccc_wdm_38185/". Tu obtiens un dossier nommé "6-11-pre-r300_xp-2k_dd_ccc_wdm_38185".
    --> Va dedans, exécute le fichier Setup.exe pour lancer l'installation.
      "ATI Radeon 9250"
      --> Installe ce pilote :
      http://www2.ati.com/drivers/6-11-pre-r300_xp-2k_dd_ccc_wdm_38185.exe
      1. --------[ AIDA64 Extreme Edition ]--------------------------------------------------------------------------------------
        Version AIDA64 v2.80.2300/fr
        Module de test 3.0.492-x32
        Site web http://www.aida64.com/
        Type de rapport Rapport rapide [ TRIAL VERSION ]
        Ordinateur A6-9736E67B8B2D
        Générateur Romain
        Système d'exploitation Microsoft Windows XP Professional 5.1.2600 (WinXP RTM)
        Date 2013-02-10
        Heure 20:24
        --------[ Résumé ]------------------------------------------------------------------------------------------------------
        Ordinateur:
        Type de système PC multiprocesseur ACPI
        Service Pack du système [ TRIAL VERSION ]
        Internet Explorer 8.0.6001.18702 (IE 8.0)
        DirectX 4.09.00.0904 (DirectX 9.0c)
        Nom du système A6-9736E67B8B2D
        Nom de l'utilisateur Romain
        Domaine de connexion [ TRIAL VERSION ]
        Date / Heure 2013-02-10 / 20:24
        Carte mère:
        Type de processeur Intel Pentium 4, 3000 MHz (15 x 200)
        Nom de la carte mère IBM ThinkCentre A50
        Chipset de la carte mère Intel Springdale-G i865G
        Mémoire système [ TRIAL VERSION ]
        DIMM1: Samsung M3 68L6423FTN-CCC 512 Mo PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
        DIMM2: Samsung M3 68L6423FTN-CCC [ TRIAL VERSION ]
        Type de Bios Phoenix (10/26/04)
        Port de communication Port de communication (COM1)
        Port de communication Port imprimante ECP (LPT1)
        Moniteur:
        Carte vidéo ATI Radeon 9250 (RV280)
        Accélérateur 3D ATI Radeon 9250 (RV280)
        Multimédia:
        Carte audio Analog Devices 1981B(L) @ Intel 82801EB ICH5 - AC'97 Audio Controller [A-2/A-3]
        Stockage:
        Contrôleur IDE Intel(R) 82801EB Ultra ATA Storage Controllers
        Lecteur de disquettes Lecteur de disquettes
        Disque dur Hitachi HDS721616PLA380 (160 Go, 7200 RPM, SATA-II)
        Disque dur SAMSUNG SP0411N (40 Go, 7200 RPM, Ultra-ATA/133)
        Lecteur optique SAMSUNG DVD-ROM SD-616E (16x/48x DVD-ROM)
        État des disques durs SMART OK
        Partitions:
        C: (NTFS) [ TRIAL VERSION ]
        D: (NTFS) 148.9 Go (138.5 Go libre)
        Taille totale [ TRIAL VERSION ]
        Entrée:
        Clavier Clavier standard 101/102 touches ou clavier Microsoft Natural Keyboard PS/2
        Clavier Périphérique clavier PIH
        Souris Souris HID
        Réseau:
        Adresse IP principale [ TRIAL VERSION ]
        Adresse MAC principale 00-11-25-4E-26-D1
        Carte réseau Hamachi Network Interface (25.1 [ TRIAL VERSION ])
        Carte réseau Intel(R) PRO/100 VE Network Connection (192. [ TRIAL VERSION ])
        Modem Modem standard 9600 bps
        Périphériques:
        Imprimante Microsoft XPS Document Writer
        Contrôleur USB1 Intel 82801EB ICH5 - USB Controller [A-2/A-3]
        Contrôleur USB2 Intel 82801EB ICH5 - Enhanced USB2 Controller [A-2/A-3]
        Périphérique USB Périphérique d'interface utilisateur USB
        Périphérique USB Périphérique USB composite
        DMI:
        Distributeur du Bios IBM
        Version du Bios 2CKT20AFR
        Fabricant du système IBM
        Nom du système 808578G
        Version du système ThinkCentre A50
        N° de série du système [ TRIAL VERSION ]
        UUID du système [ TRIAL VERSION ]
        Fabricant de la carte mère Intel
        Nom de la carte mère D865GKD
        Version de la carte mère
        N° de série de la carte mère [ TRIAL VERSION ]
        Fabricant du châssis IBM
        Version du châssis
        N° de série du châssis [ TRIAL VERSION ]
        Identifiant du châssis [ TRIAL VERSION ]
        Type du châssis Mini Tower
        1. Voilà tiens
        2. J'éspère que tu vas me répondre au plus vite possible, merci.
      2. Modérateur
        Tout est expliqué dans le tutoriel.
        Avec le résumé, je pourrais te proposer un pilote pour ta carte graphique.
          https://www.commentcamarche.net/faq/9265-identifier-son-materiel-avec-aida64
          Copie-colle le résumé généré par AIDA64 dans ton prochain message.
