Help minecraft
Bonjour, j'ai décidé de me lancer dans Minecraft, mais j'ai eu un problème ( rencontré par beaucoup ), celui du " bad video card drivers ... "
Voilà ma " config' " :
System Information
Time of this report: 10/9/2012, 19:17:13
Machine name: FRANKCLAES-PC
Operating System: Windows 7 Édition Intégrale 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.110622-1506)
Language: French (Regional Setting: French)
System Manufacturer: INTEL
System Model: DG43NB
BIOS: BIOS Date: 08/15/08 15:04:09 Ver: 08.00.10
Processor: Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz (4 CPUs), ~2.3GHz
Memory: 2048MB RAM
Available OS Memory: 2028MB RAM
Page File: 1171MB used, 2885MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 8800 GTS (Microsoft Corporation - WDDM v1.1)
Manufacturer: NVIDIA
Chip type: GeForce 8800 GTS
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0193&SUBSYS_042010DE&REV_A2
Display Memory: 1055 MB
Dedicated Memory: 297 MB
Shared Memory: 758 MB
Current Mode: 1440 x 900 (32 bit) (60Hz)
Monitor Name: Algemeen PnP-beeldscherm
Monitor Model: Acer AL1916W
Monitor Id: ACRAD52
Native Mode: 1440 x 900(p) (59.887Hz)
Output Type: HD15
Driver Name: nvd3dumx.dll,nvd3dum,nvwgf2umx.dll, nvwgf2um
Driver File Version: 8.15.0011.8593 (English)
Driver Version: 8.15.11.8593
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 7/14/2009 03:41:53, 9443840 bytes
WHQL Logo'd: Yes
Merci d'avance pour votre aide..
    Installe la version 64 bits de Java :
    https://www.java.com/fr/download/manual.jsp
    1. Euh ça prend plein de temps pour télécharger mais j'essaie, au pire je supprime si ça prend trop de place...
    2. Voilà je l'ai téléchargé, je dois l'ouvrir ?
    3. quand t aura fini d installer ta carte ne faite pas tout en meme temps, java 64 bits va te permettre d exploiter minecraft a fond.
    4. Ca marche pas Destrio ça me (re)met ça :( :
      Bad video card drivers!
      Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
      This can usually be fixed by updating the video card drivers.
      --- BEGIN ERROR REPORT 7fe0271 --------
      Generated 9/10/12 19:47
      - Minecraft Version: 1.3.2
      - Operating System: Windows 7 (x86) version 6.1
      - Java Version: 1.7.0_07, Oracle Corporation
      - Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
      - Memory: 428189640 bytes (408 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
      - JVM Flags: 2 total; -Xms512m -Xmx1024m
      - LWJGL: 2.4.2
      - OpenGL: ~ERROR~ NullPointerException: null
      - Is Modded: Probably not
      - Type: Client
      - Texture Pack: ~ERROR~ NullPointerException: null
      - Profiler Position: N/A (disabled)[failed to get system properties (java.lang.NullPointerException)]
      org.lwjgl.LWJGLException: Pixel format not accelerated
      at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
      at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
      at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
      at org.lwjgl.opengl.Display.createWindow(Display.java:311)
      at org.lwjgl.opengl.Display.create(Display.java:856)
      at org.lwjgl.opengl.Display.create(Display.java:784)
      at org.lwjgl.opengl.Display.create(Display.java:765)
      at net.minecraft.client.Minecraft.a(SourceFile:233)
      at net.minecraft.client.Minecraft.run(SourceFile:516)
      at java.lang.Thread.run(Unknown Source)
      --- END ERROR REPORT 1b568541 ----------
  2. desinstalle tes pilotes :
    tu va dans ton panneau de config "desinstaller prog"
    tu cherche nvidia puis desinstaller, cherche pas a enlever que les drivers graphique vire tout le nouveau pilote va tout te remmettre après.
    1. Le truc c'est que en supprimant j'ai peur de faire une bêtise et en téléchargent idem...
    2. ouais mais si tu met pas ta carte a jour pas de minecraft, la manip est simple :
      tu desinstalle ca redemarre tu prend ton fichier telecharge chez nvidia tu lance et ta des pilotes bien installé
    3. Ca prend blindé de mémoire...
      Si j'achète Minecraft j'aurai le même problème ?
  3. bonjour,
    tu devrais réinstaller les pilotes pour ta carte graphique.
    "Driver Date/Size: 7/14/2009" ceux ci on l'air obsolete.
    -telecharge les dernier pilotes pour ta 8800 GTS
    -desinstalle tes pilotes
    -installe les derniers pilotes que t a téléchargé chez nvidia
    1. Ah ok j'ai fait la recherche auto puis ils me mettent : " Produit Pilote actuellement installé Dernière mise à jour du pilote
      GeForce 8800 GTS -- GeForce 306.23 Driver
      Version: 306.23 WHQL
      Date d'introduction: 13.9.2012 "
      A lire dans l'ordre, donc ils disent " Pilote actuellement installé : -- " Ok xD Y a aucun pilote installé ^^
    2. ok regarde quand meme dans ton panneau de config pour eviter d avoir d ancien morceau de pilote qui pourrai rentrer en conflit avec les nouveaux
