Problème Minecraft
J'ai un problème.
Lorsque que j'essaye de joué à Minecraft un message sur fond bleu apparait :
___________________________
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 03/09/12 20:42
- Minecraft Version: 1.3.2
- Operating System: Windows XP (x86) version 5.1
- Java Version: 1.7.0_06, Oracle Corporation
- Java VM Version: Java HotSpot(TM) Client VM (mixed mode, sharing), Oracle Corporation
- Memory: 4713112 bytes (4 MB) / 26873856 bytes (25 MB) up to 259522560 bytes (247 MB)
- JVM Flags: 1 total; -Xbootclasspath/a:C:\PROGRA~1\Java\jre7\lib\deploy.jar;C:\PROGRA~1\Java\jre7\lib\javaws.jar;C:\PROGRA~1\Java\jre7\lib\plugin.jar
- LWJGL: 2.4.2
- OpenGL: ~ERROR~ NullPointerException: null
- Is Modded: Probably not
- Type: Client
- Texture Pack: ~ERROR~ NullPointerException: null
- Profiler Position: N/A (disabled)[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:233)
at net.minecraft.client.Minecraft.run(SourceFile:516)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT ff53526f ----------
Merci pour ce qui essayerons de m'aider.
J'ai un problème.
- LWJGL: 2.4.2
- Type: Client
met à jour ta carte graphique
--> https://www.touslesdrivers.com/ -
Alors, effacez le fichier minecraft de votre ordinateur ainsi que .Minecraft
Cordialement Monday1999 -
Version payer
Bonsoir Milkshake221,
Vous jouez en version non payer ou en version payer ?
