Probleme java
je compile un code java qui fait appel a une ontologie, et quand je fait un run j'ai ça comme resultat dans le output:
INFO [AWT-EventQueue-0] (OWLConsumer.java:778) - Start model http://127.0.0.1:8081/ontology/elect.owl
INFO [AWT-EventQueue-0] (OWLConsumer.java:809) - Ontologies: 1
INFO [AWT-EventQueue-0] (OWLConsumer.java:887) - Classes: 3
INFO [AWT-EventQueue-0] (OWLConsumer.java:926) - ObjectProperties: 0
INFO [AWT-EventQueue-0] (OWLConsumer.java:997) - DataProperties: 0
INFO [AWT-EventQueue-0] (OWLConsumer.java:1205) - AnnotationProperties: 0
INFO [AWT-EventQueue-0] (OWLConsumer.java:1221) - 5 AnnotationProperties present.
INFO [AWT-EventQueue-0] (OWLConsumer.java:1224) - Datatypes: 0
INFO [AWT-EventQueue-0] (OWLConsumer.java:1242) - Imports: 0
INFO [AWT-EventQueue-0] (OWLConsumer.java:1257) - Defining Classes
INFO [AWT-EventQueue-0] (OWLConsumer.java:1450) - Processing 0 Inverses
INFO [AWT-EventQueue-0] (OWLConsumer.java:1462) - Processing 0 Domains
INFO [AWT-EventQueue-0] (OWLConsumer.java:1474) - Processing 0 Ranges
INFO [AWT-EventQueue-0] (OWLConsumer.java:1486) - Processing 0 SubClass
INFO [AWT-EventQueue-0] (OWLConsumer.java:1536) - Processing 0 EquivalentClass
INFO [AWT-EventQueue-0] (OWLConsumer.java:1717) - Processing 0 DisjointWith
INFO [AWT-EventQueue-0] (OWLConsumer.java:1953) - Processing 0 SubProperty
INFO [AWT-EventQueue-0] (OWLConsumer.java:1969) - Processing 0 EquivalentProperty
INFO [AWT-EventQueue-0] (OWLConsumer.java:1990) - Processing 31 Types
INFO [AWT-EventQueue-0] (OWLConsumer.java:2040) - Processing 0 AllDifferent
INFO [AWT-EventQueue-0] (OWLConsumer.java:2109) - Processing 0 SameAs
INFO [AWT-EventQueue-0] (OWLConsumer.java:2123) - Processing 0 DifferentFrom
INFO [AWT-EventQueue-0] (OWLConsumer.java:5335) - Doing Extra Stuff
INFO [AWT-EventQueue-0] (OWLConsumer.java:2217) - 0 Triples left
INFO [AWT-EventQueue-0] (OWLConsumer.java:2345) - 0 Data Triples left
WARN [AWT-EventQueue-0] (OWLConsumer.java:666) - Untyped Class: http://www.w3.org/2002/07/owl#NamedIndividual
INFO [AWT-EventQueue-0] (OWLConsumer.java:2460) - Parsing Complete
le code marche bien mais il me derange en affichant toute ces ligne la
aidez moi s'il vous plait pour les enlever
    De quel programme il s'agit ? Tu peux afficher le code source ?
