Language issue need for speed undercover
Hello,
I bought Need for Speed Undercover on PC and the language is in German.....
How can I change it ??????
Urgent!!!!!!!!
Configuration: Windows Vista
  1. Hello,
    You must have a language selection in the menu
    otherwise if you bought and I mean bought (not downloaded) from a French store, bring your game back to get it exchanged or contact the game's technical support.
    If you downloaded the game online, it's illegal and so it's well deserved.
    1. But in which menu???
  2. Well, you must have a menu of options (I know it's hard to find in German)
    I can't help you more; I don't speak German at all.
    1. Thank you very much, but I found something else!!!
  3. What did you find?
    1. The thing is that in the settings, you go to region and language and you set your region and when you install the game, it’s usually automatically in French... But you have to reinstall all the games that you can't get to run in French...
  4. Hello, I wanted to know if the game Need For Speed Undercover is as good as Need For Speed Carbon?
    1. Create your topic. This one concerns an issue encountered in the game.
      1. Hello,
        I have a problem; I was given NSF Undercover for Xbox 360, and it’s in German. If anyone has a solution, that would be great, before I put it in the oven, run it through the toaster, and finish it in the centrifuge...
        Thanks in advance for your explicit responses ;o)
