Need help with a math problem
Solved
Leo
Nic00 Posted messages 1751 Status Member -
Hello,
I have to solve a problem for my son that's quite tricky ...
Here's the statement:
My number of thousands is 399
The thousands digit is the same as the units digit
If you add a hundred, I stay below 400,000, but if you add two, I become above 400,000
The sum of all my digits is a number that ends with 1
Who am I???
Honestly, I'm stuck .... I need help!!!
Thanks in advance ....
Who am I???
Configuration: Mac OS X Firefox 3.0.1
My thousands digit is 399: so 399 xxx
The thousands digit is the same as the units digit: so 399 xx9
If you add a hundred, I remain below 400,000, but if you add two, I become above 400,000: so 399 8x9
The sum of all my digits is a number that ends in 1: so 3 for the tens.
So: 399 839!
PS: don't tell your teacher or your parents that you got help!!! -
Good evening,
Your question should be asked on another forum, as it has absolutely nothing to do with the Mac OS forum...
But, it was found too quickly, so... the answer is 399839
Have a nice evening.
Sanspseudo - Francis
iMac G5 2ghz 2Go - OS 10.5.4 -
399 856 399
or 399 865 399 ?
Best regards,
Pierre -
Ouch, I really need to make up my mind to read the messages completely myself :D
Best regards,
Pierre -
Sorry Léo, I mixed up the 3 and the 9 ^^ so this time I'm 100% sure.
Note: You are indeed on a MAC OS site that has nothing to do with math.....
