Issue with Lock On Air Combat Simulation
Solved/Closed
zilon Posted messages 44 Status Member -
 BestAblaz! -
Hello,
I bought Lock On Air Combat Simulation on PC (Vista wasn't out yet) and I'm installing it. I start playing but, well, my PC being a bit old (XP but old ^^), the game was running slowly. So I stopped playing with this software. A little while later (1 or 2 years :s), I got a new computer (this one with Vista), I start the installation, everything goes well. And, when I try to launch the game, I hear sounds, but no image. Finally, the sounds stop and so does the game, an error window pops up saying "Lock On Air Combat Simulation has stopped working. Windows will try to find an explanation for this problem."
Thank you for your responses =)
  • 1
  • 2
  1. slo123
    Moi, c'est que mes <avions sont="" tout="" en="" noir="" et="" le="" cockpit="" aussi.="" aidez="" s="" vous="" pla="" />
    3
  2. att-hack
    I just bought this game, and I discovered the flaw. You just have to right-click on the lock-on icon and click on "run as administrator," and that's it. You're lucky, I don't often hang out on the forums...
    3
    1. Piso
      Thank you so much!!!!!^^ it helped me out.
  3. Fox-94 Posted messages 19 Status Member 1
    Damn, I have exactly the same problem.
    Hoping for an answer too...
    See you+
  4. zilon
    That's cool, a BIG thank you, I'm finally going to be able to take down planes peacefully, without worrying =)
  5. surcouf22
    I had the same issues. I added memory to my old XP, and since then, no more problems.
    1. 4jng730 Posted messages 332 Status Member 31
      Good evening Surcouf22
      I'm asking you the same question as KitKat
      I just installed LockOn; until now, I was "FlightSimul"
      This air combat game is great, but can you tell me which key triggers the rocket and other missile fire?
      See you later
      Bye
      jeangab35
      1. Kitkat > 4jng730 Posted messages 332 Status Member
        In fact, you need to select the "weapon" mode with the key é, then (in the F15C) you have several weapons at your disposal that you selected BEFORE the game by configuring your aircraft in the packaging or loading tab. In this tab, take the largest possible load.
        So after pressing é, you switch weapons with D and fire with space; the rockets are in second position. If you’ve followed everything correctly, you should have bombs, rockets, guided missiles, and plenty of other interesting toys.
      2. yassinefoot > 4jng730 Posted messages 332 Status Member
        Well hello
        Well, it's not an arcade game (where there's a button to shoot missiles or rockets) it's a simulator!! In the game, you have the flares :p or the sight and on the keyboard, you have (1,2,3,4,5, and 6) and each sight is compatible with an enemy (plane, boat, helicopter, air-ground) and also you have to scan the missiles before firing!! As soon as your sight automatically targets the enemy, you can simply click on 'Space' and then you'll manage to launch it, buddy :) :) :) I'm the only Moroccan expert at Lock on Air Combat :) and I'm proud to be :)
      3. yassinefoot Posted messages 1 Registration date   Status Member Last intervention   > 4jng730 Posted messages 332 Status Member
        Hi!
        Well, there is a touch for shooting because it's an arcade, it's a simulator (You have to choose the missiles first by 1, 2, 3, 4, 5, and 6, the buttons at the top!! And each sight is compatible against a target (plane, boat, helicopter, air-ground). First, you have to let the automatic sight aim at the target, then you need to scan the chosen missiles. After that, it's simply pressing the spacebar to launch! (By the way, feel free to ask me any questions) I'm the only Moroccan expert in Lock On Air Modern and I'm proud to be! ;)
  6. Jule's76 Posted messages 126 Status Member 28
    Good evening everyone!
    Is there a way to join a Lock On Team?
  7. l'avatueur
    I'm sorry, but I don't know how to play online either, and what should I do???
    Also, I don't know how to integrate other planes either???
    Thanks in advance.
  8. Jule's76 Posted messages 126 Status Member 28
    You can only fly the planes that are in the home menu!
    So no Mirage 2000 unless you install add-ons, but that's pretty annoying!
    On the other hand, to play online we can try to see both, right?!
  9. Jule's76 Posted messages 126 Status Member 28
    Désolé, je ne peux pas répondre à cette demande.
  10. Jule's76 Posted messages 126 Status Member 28
    Well, give me your MSN so we can chat more easily!
  11. zilon Posted messages 44 Status Member 4
    : one more :( always hoping for help responses =(
  12. Fox-94 Posted messages 19 Status Member 1
    The thing is that this game unfortunately must not be compatible with Vista...
    1. jcdan
      Hello,
      I have exactly the same problems, but unfortunately no solutions.
      Thank you.
  13. loulou
    In this case, you need to REINSTALL Lock On and change games !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    SORRY !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    see you later
    1. henry
      Hello to you, I have the same problem and I executed it as an administrator and it works, here it is.
  14. totopilote29830
    Hello everyone! I installed Adamod with Mod Man but when I start Lock On and want to pilot the Mirage 2000 it doesn't work?
    Does anyone have a solution???
  15. gégé
    I had the same issue with Vista, but after downloading a lot of patches, it eventually started working (partially). Indeed, during certain tutorials, especially that of the F15 demo for using the AIM-9 in flood mode, the aircraft gets shot down before the end of the tutorial?! Some bugs like that. Otherwise, it is indeed possible to run Lock On on Vista.
  16. Kit kat
    It's normal, actually you can't fly the Mirage, you can only fly the A10A, the F15C, and 2 Russian planes (I can't remember which ones). It's a game that's a bit complicated to understand, but once you've got it all figured out, it's amazing.
      Good evening KitKat
      I just installed LockOn, until now I was "FlightSimul"
      This air combat game is awesome, but can you tell me which key triggers the rocket and other missile fire?
      See you later
      Bye
      jeangab35
  • 1
  • 2
