Solve TV and DTT reception issues
LaRedaction Posted messages 889 Registration date   Status Administrator Last intervention   -
berbere17 Posted messages 58 Registration date   Status Member Last intervention   -
Dmitriy Baranov
When your television no longer displays TNT channels and shows that it is not receiving any signal, it may be due to incorrect settings or a malfunction. Possible causes include an issue with the television itself, a wiring problem, an issue with the antenna, or even a problem with the transmitter. You can perform various checks to identify the cause of the problem, and in some cases, a simple reset of your television or a new channel search may be enough to resolve the issue. Have you ever encountered reception problems with TNT? What was your solution?
Source
  1. Xileh Posted messages 19446 Registration date   Status Moderator Last intervention   6 568
    Hello,
    Once the various checks suggested in the article have been made.... and with no results the best option (besides asking the neighbors if they are in the same situation) is to consult this site =>
    https://www.recevoirlatnt.fr/particuliers
    Buying an indoor antenna is really the last recommendation to make... they only work in direct line of sight to the transmitter and with no obstacles in between...
    So if it's the "last resort". make sure you can return it if it brings nothing, which is very likely!.....
    And beware of the "miraculous" ads regarding this kind of product.... they are all highly overrated if not completely rigged!
    My mission is to kill time, and hers is to kill me in turn.
    We feel completely at ease among assassins. (E.Cioran)
    1. berbere17 Posted messages 58 Registration date   Status Member Last intervention   8
      Hello, thank you for the website, I didn't know it.
  2. Mamoune
    No signal for 2 hours on my Thomson television, everything is well connected (I am not connected) to an operator for now I only have DTT it was working fine and suddenly nothing anymore,
    For your information, there is a lot of wind outside
  3. Carla
    I no longer receive the R4 multiplex maineetloire 49
  4. Fritz
    Is it a general outage? I have 3 televisions at home with no signal!!!
  5. Telemateur
    No signal, no TNT in Nantes since this morning, June 15, 2025
  6. Vaudon
    All my TNT channels are working fine but channel 26 is not working, is that normal?
    1. baladur13 Posted messages 47413 Registration date   Status Moderator Last intervention   14 416
      Hello;
      Paris Première, channel 26 of DTT, is a paid channel with free time slots every day between 6 PM and 9 PM.
      -1
