Garmin Edge 830 - problème de sélection de langue
sam1212 -
Hello,
I purchased the Garmin Edge 830 GPS.
After setting it up, it suddenly switched to English after a reboot.
I tried to change it back to English in the system>language> section, but French is no longer on the list.
There are only English / Danish / Dutch / Slovak.
I attempted a reset, but it didn't work.
I don't know how to solve the problem.
Thank you in advance for your response and your help ????
Hello.
You need to go to the Garmin website with "Garmin Express" connected GPS to the PC and look for the language that is missing in the menus.
Hello
Where did you buy it, from whom?
https://www.alltricks.fr/surl/quisommesnous_v2
just ask them since they are:
"Experts at your service
At your disposal from Monday to Friday from 9 AM to 7 PM and Saturday from 10 AM to 7 PM
We answer all your inquiries, from the simplest to the most complex assembly."
https://www.youtube.com/watch?v=qM5_WIePkmg
https://www8.garmin.com/manuals/webhelp/edge830/FR-FR/Edge_830_OM_FR-FR.pdf
the setup doesn't seem complicated, except on a device that has a software defect
Hello.
Of course, if you have doubts then it will be difficult to switch back to French; however, that's what I did with a GPS that lacked the language and it works very well.
It's up to you to choose!
Thank you cpmr!
I had the same problem as you (no French in the list of languages) and after installing Garmin Express and updating the GPS by connecting it to the PC with this software, French came back.
