Installation issue with IDT high definition audio codec
SolvedHello,
For the past few days, I have not had an audio driver and I cannot find and install the IDT high definition audio codec driver for the Toshiba Satellite C50-A12K. In the device manager, I tried uninstalling the driver and then restarting, but to no avail. The Windows (10) diagnostic finds the issue but cannot install the driver.
Do you have a solution?
Thank you in advance
Olivier
- High Definition Bus Audio Device
- High Definition Bus Audio Peripheral Prob
- Audio device driver download for high definition audio bus
- Potentially Unwanted Software - Realtek High Definition Audio Driver
- Realtek High Definition Audio not working
- Realtek High Definition Audio Missing from Device Manager
Hello,
Reinstall the Audio driver... https://fr.dynabook.com/support/drivers/ If your PC is 64 Bits, install the 64 Bits version.
Moderator
Hello,
If you can't find the driver:
Windows + R
Type --> devmgmt.msc and OK.Provide the hardware identification number of the IDT high definition audio codec
Check this --> Find the device identification number
Post the number in your next message.
Sample image:
Thank you for this link, but I can't find an audio driver. The abbreviated reference for my laptop is PSCG6E, which doesn't appear in the list provided by the site. The closest number is PSCG7E, but there is only the Health or video driver, not audio.
Thank you Kaneagle,
Here are the 2 identification numbers found:
HDAUDIO\FUNC_01&VEN_111D&DEV_7695&SUBSYS_1179FA30&REV_1001
Moderator
Download and install --> 7Zip 64 bits
Download this driver --> IDT audio
Right-click on the driver --> Sigmatel_IDT_Audio_6.10.6504.0_x64.zip
Select --> 7Zip
Choose --> extract to "Sigmatel_IDT_Audio_6.10.6504.0_x64\"Go to Device Manager
Right-click on the device
Update driver
Browse my computer for drivers
Choose from a list of drivers...
Have Disk
Browse
Go to the extracted driver folder --> Sigmatel_IDT_Audio_6.10.6504.0_x64
Select the file --> STWRT64.INF and OK.
Restart. -
Thank you very much, it works!
Moderator
You're welcome.
Have a nice day.
