Display issue on mobile but not on Elementor
SolvedMobile display issue
Hello, here is the server information:
Wordpress version: 6.0.1
Theme: Astra, with Starter Template
Plugins: Elementor / Starter Templates / Duplicate Page
The site has no issues on PC, and the display in mobile or tablet mode with Elementor is fine too!
However, when I access from a real mobile, I have display problems...
No specific plugins installed....
In the header.php file, I have: "<meta name="viewport" content="width=device-width, initial-scale=1">"
Do you have any idea?
Hello,
Actually, I just realized that it happens even on PCs, as long as I access the site via its public domain name...
I have a PFSENSE with an HAPROXY on it that redirects requests based on the requested server;
test1.fr -> SRV-TEST1
test2.fr -> SRV-TEST2
The redirection works well because I can display part of the site but not everything...
No issues locally....
I don't understand xD
Best regards,
Roche Corentin -
Hello, it may not be a technical issue but sometimes even if your template is responsive you need to make some adjustments through Elementor. To visualize your site as it appears on different smartphone screens, you can use a tool like Responsinator.
