Devialet Gemini Audio Right Sound Volume Very Low
Closed
Paoloo__ -
bazfile Posted messages 58524 Registration date   Status Moderator Last intervention   -
Hello
So since yesterday, (I don't know how it happened) my right earbud is very quiet compared to the left one which is normal as usual.
I checked on the Devialet Gemini app the equalizer and the balance between left and right, and everything seems normal. Same with the phone settings…
Does anyone have any idea what's going on? And if maybe we can fix it at home?
Thanks ^^
1 answer
  1. bazfile Posted messages 58524 Registration date   Status Moderator Last intervention   20 280
    Hello,
    reset your earbuds see this page check if your earbuds are up to date see this page and if it’s still not better contact Devialet support
    bazfile
    Moderator/Security Contributor.
    a hello, a reply, a thank you are always appreciated.
    1. Geedirt
      Same problem, up
    2. bazfile Posted messages 58524 Registration date   Status Moderator Last intervention   20 280 > Geedirt
      Same answer.
    3. Pong > bazfile Posted messages 58524 Registration date   Status Moderator Last intervention
      Insufficient response.
    4. bazfile Posted messages 58524 Registration date   Status Moderator Last intervention   20 280 > Pong
      This answer is sufficient as it has already been said to discuss this with the support of Devialet.
      2
    5. Kablansy
      Have you found a solution to this problem?
