Display issues/graphics bugs on Chrome on Android
Narell Posted messages 4 Status Member -
Hello, I've been having some display issues on Chrome on my phone for a few days. Everything is up to date and other apps work perfectly. What could cause this kind of problem?
I should mention that it only lasts a few seconds each time and it just takes a touch on the screen to return to normal, but it happens quite frequently.
1 answer
  1. Panth33ra Posted messages 23253 Registration date   Status Member Last intervention   Ambassador 2 366
    Hello,
    I see only one solution... A reset of the smartphone (brand and model) running Android!
    ASUS ROG G752 VSK | QuadCore Intel i7 7700HQ | 32 GB-DDR4 | 2 SSD M.2 500 GB | 2 HDD Seagate 2TB | GeForce GTX 1070M 8 GB | 17.3" Screen (120 Hz) | DirectX 12 | Windows 10 (x64)
    1. Narell Posted messages 4 Status Member
      Thank you for the response. It's an Alcatel One Touch Go Play. I have a bit of a suspicion that it might need to be reset, but I would like to know where this problem comes from.
      1. BunoCS Posted messages 436 Registration date   Status Moderator Last intervention   3 931 > Narell Posted messages 4 Status Member
        Uh... resetting the phone seems like a bit of an extreme solution, doesn't it?
        Have you tried clearing the app's cache?
      2. Narell Posted messages 4 Status Member > BunoCS Posted messages 436 Registration date   Status Moderator Last intervention
        I don't have much on it, so it's not a big deal if I have to get there.
        Yes, I cleared the caches and cookies and the problem persists.
