Freebox fiber connection and communication cabinet
Romain5454 -
brupala Posted messages 4 Registration date   Status Member Last intervention   -
Hello everyone,
I'm reaching out because I'm completely lost. I have a new house with RJ45 sockets in the bedrooms. I'm confused about the connections to get the RJ45 sockets working. They are not working currently. When the technician came by, he made the connections as follows:
In the garage, there is a gray junction box under the communication cabinet. Two wires come out of it. I imagine it is connected to the same gray junction box located in the living room.
In the living room, the Freebox server and Freebox TV are connected together. The Freebox server is connected to a black box, which in turn is connected to a gray box (the same as the gray box underneath the communication cabinet).
It should be noted that there is no RJ45 socket in the living room.
It works, but the RJ45 sockets in the bedrooms do not work.
I thought about connecting the Freebox server to an RJ45 socket in a bedroom, but there is no gray box.
I also considered placing the Freebox server in the garage, but I can't visualize the connections to make.
There are also RJ45 cables paired in twos in the communication cabinet that come from the master filter (1 and 2) but are not connected to anything at the end. This leaves me perplexed...
I'm a bit lost. Embarassed
https://drive.google.com/file/d/1nkvXbSbPmM6iRO_D-Yy9XkEcbRASD9Cd/view?usp=sharing
https://drive.google.com/file/d/1AMtEznWkrLylYKi3zpsVoVl0Uz47MhIO/view?usp=sharing
https://drive.google.com/file/d/1oY9u9pKKbYD8m90ihgem7ZYS1_oNxqmu/view?usp=sharing
https://drive.google.com/file/d/1jhpiJUBTj1QVj1edWxlQmMLW2EWjVL-T/view?usp=sharing
Thank you for your help,
Romain
  1. brupala Posted messages 4 Registration date   Status Member Last intervention   14 454
    Hi,
    there's quite a distance from the communication box where I see they installed the fiber PTO (in the small hole) to the Freebox and its ONT that you showed, is the fiber patch cable long?
    How come you have RJ45s in the bedrooms and not in the living room, that's abnormal.
    How many RJ45s are connected to the patch panel?
    The idea is to do something like this:
    and ... there you go!
