Realtek RTL8723BE Wireless LAN 802.11n PCI-E NIC network card issue
Littlelynx
Posted messages
12
Status
Member
Littlelynx Posted messages 12 Status Member -
Hello,
about a month ago, I fixed my computer with the answer to a post on this site (screenshot post below). Since then, there were still internet connectivity issues over Wi-Fi, but clicking on "troubleshoot" would fix it. For your information: all various updates for my computer are done.
For the past 3 days, I have had nothing at all.
Do I need to redo the process?
I remind you I have an ASUS laptop with Windows 10 and all the other connected devices in my house are working fine on Wi-Fi.
I work in networking, so this is very penalizing for me and urgent, help please.
Thank you for your response
Have a nice day.
Have a nice day.
Related links:
- 802.11n Pilote de carte LAN sans fil
- Realtek RTL 8168/8111 Family PCI-E Gigabit Ethernet Card
- Realtek RTL8723BE WiFi Issues Wireless LAN 802.11n PCI-E NIC
- Ralink 802.11n carte LAN sans fil pour Windows 10
- Realtek RTL8723BE WIRELESS LAN 802.11 n PCI-E NIC issue
- Realtek 8822ce Wireless LAN 802.11ac PCI-E NIC Network Card
Keep only the unzipped driver's one 85b4512f.......
Put it in your documents
If everything is correct, mark the subject as resolved.
Have a nice day.
Human beings are at their best when things are at their worst. -
Hello,
Press Windows + R
Type --> devmgmt.msc and OK.
What do you have under network adapters?
Give the hardware ID of the realtek card
Look at this --> Find a device's identification number
Post the number in your next message.
What's the model number of Asus?
Is Windows 10 in 32 or 64-bit?
Download and install --> 7Zip 64 bits
Download this driver --> Realtek
Right-click on the driver --> 85b4512f.......
Select --> 7Zip
Choose --> extract to "85b4512f.......\"
Go to Device Manager
Right-click on the device
Update driver
Browse my computer ......
Choose from a list of drivers...
Have disk
Browse
Go to the unzipped driver folder --> 85b4512f.......
Select the file --> netrtwlane02.inf and OK.
Restart.
Disconnect the network cable (Ethernet) and Wi-Fi from the PC
Device Manager
Go to network adapters
Right-click on --> the Realtek wireless card
Uninstall
Check --> delete the device
Uninstall
Windows + R
Type --> control panel and OK
Programs and Features
Uninstall --> Realtek wireless, if present
Restart the PC.
Right-click on the device (network controller)
Update driver
Select from a list of drivers...
Provided disk
Browse
Go to the folder of the unzipped driver --> 85b4512f.......
Restart.
It just came back, my network card had disappeared from the device manager. After restarting, it came back... Too weird
Have a nice day -
Hello, should I restart the computer right away or click on "next" first??
What do you have in --> Other devices?
The Realtek wireless is no longer alert, what does it mean for the wifi?
Try a USB wifi adapter.
