Function myFunction and $('body').on('click', function() {
Solved
Hello,
Actually, I have two functions that each have their role, but I would like to combine them because I need to
- The first function allows selecting a div called mainContainer and filtering its children:
 $('body').on('click','#mainContainer :not(.PDFPage):not(.element)', function() { alert("The child of the main container is properly filtered and not selected"); });
And I would like to do the same thing with the second function, but I don't know how to proceed; here is the code:
 function shownToolColor(x,y,width,isVisible,container) { alert("The child of the main container is properly filtered and not selected"); });
So what I want is something like:
 $('body').on('click','#mainContainer :not(.PDFPage):not(.element)', function shownToolColor(x,y,width,isVisible,container) { alert("The child of the main container is properly filtered and not selected"); });
But from what I see, it’s not how it should be done and it doesn't work, so I would like to ask if you could help me fix this last code.
Best regards,
1 answer
  1. Moderator
    Hello,
    To start.... what is the function shownToolColor called in your code?
    (what triggers it?)
    Because .... when you say you want to "merge" .. what do you mean?
    Right now you have:
    code that runs when you click on your page (which does not contain the pdf class or element)
    The code that is executed then is:
     alert("The child of the main container is well filtered and is not selected");
    Then you have a function (which we don't know how/where you call it) that executes the code
    I think I understand that you want, in your click
    to call the function shownToolColor
    In that case:
     $('body').on('click','#mainContainer :not(.PDFPage):not(.element)', function() { //------------------------------------------------------// // Variables to complete .... //------------------------------------------------------// var x = ""; var y = ""; var isVisible = ""; var container = ""; //------------------------------------------------------// // Launching the function //------------------------------------------------------// shownToolColor(x,y,width,isVisible,container); });
    It's up to you to fill in the different variables.... I don't know what values you are expecting exactly.
    Best regards,
    Jordane
    1. Yes, that’s exactly it! It works very well, I’m very happy it worked all of a sudden, thank you very much and see you next time ;-)!
