TV/DVD player connection for sound
Steph5533 Posted messages 2 Status Member -
 Steph5533 -
Good evening,
I received my box today. I plugged it in, everything is fine, I have a picture on my TV. However, there is no sound! I then decided to connect my TV to the DVD player, which is connected via several cables to various speakers.
And that's where it gets stuck: no sound.
Where should I connect my red, white, and yellow cables...? Thanks for your help
Configuration: iPhone / Safari 10.0
  1. Andy31200 Posted messages 26918 Registration date   Status Moderator Last intervention   12 207
    Hello and welcome to the forum,
    -Better quality and 5.1 surround sound:
    If your box has a digital optical audio output
    Connect to the "Optical digital IN" of the DVD with an optical cable
    -To get sound from the TV on the DVD/home theater:
    Connect the red and white RCA from the TV at the top left, next to the black cable, to the RCA AUDIO IN of the DVD/home theater and select this input, but it will be in stereo
    I call a spade a spade *
         *in French in the text
      Optical output:
      Optical cable:
    2. Steph5533
      Hello and thank you,
      Unfortunately still no sound... yet when I tune the radio I can hear it.. so the issue doesn't come from the speakers.
    3. Andy31200 Posted messages 26918 Registration date   Status Moderator Last intervention   12 207
      Did you plug in an optical cable?
  2. Steph5533
    The problem probably comes from the fact that it's a monitor and not a TV because I connected my box to the TV using an HDMI-DVI adapter...
    I can swap my two TVs, but is there no other solution?
