How to type the number 0 for the car radio code
Solved
Penhat Posted messages 3 Status Member -
letotof Posted messages 2149 Status Member -
Good evening,
I have the code for my car radio, but after reconnecting the battery, when I wanted to enter the code, for the number 0 which is in the 3rd position, I only have a dash, and it's impossible to display the zero.
A big THANK YOU for your help!
Have a good evening
P
  1. letotof Posted messages 2149 Status Member 482
    Hi
    can you give us the reference of your car radio, thanks
    6
    1. Penhat Posted messages 3 Status Member
      Hello letotof,
      Thank you very much for your reply, that's nice.
      I finally managed to enter the number 0, it was after the 9.
      I hadn't dared to try multiple times at first due to the risk of the car radio getting locked.
      Thanks again and Merry Christmas
      P
  2. MPMP10 Posted messages 47564 Registration date   Status Member Last intervention   19 070
    Hello,
    most of the time for zero, it shows a line instead of the "0", so try entering the following number to see...
    The youth idol has left, he will leave me with a great void...
    3
      it won't work because he won't have entered any figures.
      "<b>it's not going to work</b> and if you start from the principle that it's not going to work without even having tried..."
    3. letotof Posted messages 2149 Status Member 482
      we need the car radio reference.
    4. Penhat Posted messages 3 Status Member
      Hello MPMP10,
      Thank you very much for your response, that's nice.
      I hadn't dared to try several times at first because of the risk of blocking the car radio.
      P
    5. letotof Posted messages 2149 Status Member 482
      To you too, Merry Christmas and happy end of year celebrations, best wishes for 2018.
