La batterie RTC est faible, appuyez sur F2.
alg1
Posted messages
161
Status
Member
Papounet17000 Posted messages 26460 Registration date Status Member Last intervention -
Hello,
I have the issue of "RTC battery is low" when starting my Toshiba laptop. Thank you for any help in finding a solution to this problem. Thanks in advance to everyone.
Configuration: Windows / Chrome 62.0.3202.94
Hi,
It's the motherboard battery that's dead.
Go to a tobacco shop and ask for a button cell model 2032.
You just need to replace the one on the motherboard with the new one. -
I hope so because now it’s stuck on a blue screen with a message saying "rtc battery is low."
Hello once again, I've changed the battery but still facing the same problem. Does anyone have an idea, please?
The problem is that there's no access to the BIOS. I press F2 at startup but always get a blue screen and RTC battery.
here we go, it's always the same, nothing works. By the way, he did this to me already a year ago, but I don't remember how I got past this problem.
The PC still does not respond, it is stuck on this message: Rtc battery is low.
So you need to see if you can do a Clear CMOS on the motherboard.
You just need to move a small jumper for a few seconds.
Check here to know what I’m talking about.
I don’t know if your motherboard has this feature, but you never know.
I finally found the problem; I had to plug in another keyboard and it worked. It was the function key F2 on my built-in keyboard that wasn't working. Thanks, bro, for your help.
Will it be necessary to flash the BIOS after changing the battery?
