HP laptop: Plugged in, not charging
Solved
dav24 -
 dav24 -
Hello,
I bought a HP Pavilion 17 laptop with Windows 8 a year ago. But for some time now, I’ve been having a problem with the battery. It has been displaying "plugged in, not charging" for a few days, and since it is at 0%, I can’t work without the cable.
I have done some research online, and the solutions I found (like removing the battery and putting it back) did not work for me.
I wanted to know what solutions there are to fix this problem?
Thank you in advance,
Configuration: Windows / Chrome 45.0.2454.93
1 answer
  1. tribun Posted messages 64900 Registration date   Status Member Last intervention   12 687
    Hello
    Your battery is no longer charging and is out of order, which is why you have this message.
    If you want to use your laptop without the power supply, you need to replace the battery with a new one.
    Who loves instruction! finds the knowledge that comes from reflection!
    P.S. Frequently create a restore point! It solves a lot of problems.
    1. dav24
      Hello,
      Thank you for the response.
      Is there no way for it to charge at least a little, so that it is no longer at 0%, while waiting to buy a new one?
    2. tribun Posted messages 64900 Registration date   Status Member Last intervention   12 687
      No! The battery cells are damaged and you can't do anything anymore.
      1. dav24 > tribun Posted messages 64900 Registration date   Status Member Last intervention
        Alright, I’m going to try to buy it. Is the price around 100 € or more?
        Could working with a faulty battery cause a problem for the computer?
    3. tribun Posted messages 64900 Registration date   Status Member Last intervention   12 687
      No! It just isn't charging anymore.
      But you can remove it if your PC starts up without the battery.
        Alright.
        I can use the PC without the battery if it's already on. (I haven't tried turning it on without the battery).
        Okay, I still think I’ll buy a battery, it's better...
        Thank you for the answers.
