Avertissement : Un problème avec le système de refroidissement a été détecté
MrRomZy
Posted messages
2
Status
Member
Guimond -
Guimond -
Hello, I’m on a Toshiba Satellite and, you’re going to tell me that this topic has already been raised but, a window keeps opening, too often actually since I disconnected my motherboard fan to power it externally 0!) (don't judge me okay!) I’d like to know if we could disable this message because it causes unpleasant Windows pop-ups even though my cooling system is working fine.
Thank you very much in advance!
Related links:
- Capacité de stockage de la batterie très faible
- Avertissement, l'organisation de vos modules dimm1 et dimm2 n'est pas identique.
- Pas de dispositif amorçable, veuillez redémarrer le système [AIDE]
- Warning message problem!!! your dimm1 and dimm'2 module organization is not s
- NVIDIA graphics update issue HP Omen 17
- Laptop connected to a TV (HDMI) shuts down when the lid is closed
1 answer
Hello,
This message indicates that the cooling system is not working or not detected.
The reason is that you unplugged it for external ventilation.
You cannot disable this message except by reconnecting the fan (which I recommend).
If you have a ventilation issue, you can always completely clean your heatsink and replace the thermal paste. Then you can invest in a ventilated stand in addition to the original fan. If it's a noise issue, you can just replace the original fan.
My best friend is called Google. My worst enemy is called Apple.
If you're not happy, give yourself thumbs up.
