Home cinéma SONY BDV NF 7220 message "pousser protection d'alimentation"
Solved
doarp Posted messages 9 Status Member -
 Trillou -
Hello,
I just purchased a SONY BDV NF7220 home theater system.
I made the connections as indicated, everything seemed fine.
On the second use, the message "push power protect" appears, apparently the home theater is trying to start and gets stuck.
I checked all my connections, including the speakers... nothing works.
Can someone help me?
Thank you in advance.
  1. doarp Posted messages 9 Status Member 17
    Thank you, stargate43, I will try it tomorrow, I'll keep you posted.
    17
    1. STARGATE43 Posted messages 13754 Registration date   Status Contributor Last intervention   2 648
      You're welcome, my pleasure ;-)
      Alright, no problem, have a good evening and see you tomorrow ;-)
    2. doarp Posted messages 9 Status Member 17 > STARGATE43 Posted messages 13754 Registration date   Status Contributor Last intervention
      Hello Stargate43,
      I followed your advice, and here are the results:
      Test with speakers unplugged, TV unplugged, turned it on, it says "hello" then it turns off.
      Second turn on, it goes into protection mode, power protect;
      and I have no access to any commands.
      Don’t you think there’s a fundamental problem?
      I’ve only used it once to listen to a CD (sound was really nice) and then the TV for an hour before it suddenly turned off; I had the volume set normally and not too loud; in the meantime, I tried to navigate the interface but it wasn’t responding well.
      I’ve had this device since January 14, so... warranty (exchange?)
      What do you think?
