USB storage problem PS4 need help please
Solved
Hello,
Here is my issue. I have a PS4 that is performing a system storage check. Then it says it is impossible to start the PS4. After that, it says to connect a USB storage device. I did this with an external hard drive formatted as exFAT with the update, and it doesn’t recognize it. It says it’s impossible to access the USB storage device. How should I proceed? Maybe I'm doing it wrong. Thank you for your help.
