Home Cinema- TV- Canal+ Decoder Connection Issue
Solved
CoralieB
Whitexs11 Posted messages 1 Status Member -
Hello,
I would like to detail my problem here because I've been going around in circles for several weeks.
I recently bought a home theater system (Sony) and I'm trying to connect it to my television (also Sony). I have a Canal+ decoder and two HDMI cables.
I have tried different connections but every time a problem arises (no sound, no video...)
My latest attempt was going quite well except that I had no sound.
I connected my television (in HDMI in) to my decoder (in HDMI out) and I connected my decoder (single HDMI output) to my home theater (in HDMI1 in).
I don’t know if you need more details to help me.
Thank you in advance!
It seems to me that that's what I did, Benji!
So for the references:
The television: Sony, model Bravia, KDL-37P3000
The home cinema: Sony, BDV N9100W
I hope these are the details you wanted! -
Thank you very much! Everything is working perfectly!
Thanks to you Stargate, I saved time and money! -
Hello CoralieB,
Here are the connections I recommend:
For the image;
1) HC* SONY <-- HDMI CABLE --> HDMI 1 TV.
2) CANAL+ DECODER <-- HDMI CABLE --> HDMI 2 TV.
This allows you to leave the 2 HDMI IN inputs of the home cinema for any other devices.
For the sound;
1) TV RCA OUT <-- RCA CABLE (Red and White) --> AUDIO IN RCA HC*.
* HOME-CINEMA
And here it all is in image form:
Best regards ;-)
--> NO PROBLEMS, ONLY...SOLUTIONS <--
My answers are based on the degree of flexibility of a cow's tail between the bars of a chair in foggy weather ;-)-
- Hello, may I intervene in this conversation, please stargate43? I also have a Canalsat decoder but not the cube model; this one is very small, black, and has 2 outputs: a SCART and AV, connected to a Sony Bravia home cinema and a Samsung LED screen, but I always have trouble connecting the image to the home cinema and finally to the screen. Could I please have some help?
Hello,
generally with a home cinema with HDMI port.
All your devices must connect to your home cinema (IN) and a single cable (OUT) goes to your television. -
Good evening,
Could you please provide me with the brand and the EXACT MODEL of EACH DEVICE? This is so I can better inform you about the connections to be made; the references are generally indicated on the back of the devices.
PS: no indications like "Samsung 102cm", that's not a reference, but more like this example: "SAMSUNG UE40C5100 - 102 cm"
Best regards and thank you for your understanding.
My answers are made according to the degree of flexibility of a cow's tail between the rungs of a chair in foggy weather ;-) -
No problem, with pleasure ;-)
I suppose we can mark the topic as resolved; if that's the case, confirm it to me and I'll take care of it.
Regards, good luck, and have a nice evening ;-)
My responses are based on the flexibility of a cow's tail between the rungs of a chair in foggy weather ;-) -
Hello, allow me to intervene in this interesting conversation STARGATE 13, I have a Canal Sat decoder, not a cube but a small, compact black model, with 2 outputs, Peritel and AV, and I still have trouble connecting it to my Sony Bravia home cinema Blu-ray BDVE880W, could I please get some help?
Hello Khascom,
Could you please give me the brand and the EXACT MODEL of EVERY DEVICE? This is so I can better inform you about the connections to be made, the references are generally indicated on the back of the devices.
PS: no indication like "Samsung 102cm", that's not a reference, but rather like this example: "SAMSUNG UE40C5100 - 102 cm"
Alcohol doesn’t solve anything, that said, water and milk don’t either ;-)
