CamStudio audio/sound issue?!!!
Solved
bibo
lullu -
lullu -
Hello everyone!!
I want to record videos from the internet. I am using the CamStudio software. When I start recording, everything goes very well until I preview the video; the video copy is good, there is no problem on that side, but there is no sound. I went to (Audio Options for Speakers, I clicked on Automatic Search and I received this message: "WaveoutGetSelectControl() failed." And the second message says: "CamStudio is unable to detect the line on your system for recording sound from your speakers. You can try the manual configuration in audio options.") I tried the manual option, same result: "no sound."
PS: These are tutorial videos that are very important for my job as a Graphic Designer. If there is a solution, please help me as soon as possible!!
Thank you in advance.
Configuration: Windows XP Firefox 2.0.0.3
- 1
- 2
Next
I found this that helped me:
If you have a problem with the sound, make sure that Record Audio from speakers is selected in the Options menu.
If it still doesn't work, manually select the recording source through the Windows mixer (small speaker icon at the bottom right next to the clock, double click then Options, Properties, Recording: make sure that stereo mixer (or what you hear, depending on the sound card models) is checked in the list, then OK and ensure that this source is selected in the mixer, and that its volume as well as the overall volume are not set to zero. Then go back to the playback properties and make sure that the wave track is also not set to zero.
Available sources
Source selection
for recording
Playback volume adjustment
Black screen
Available sources
Source selection
for recording
Black screen
- 1
- 2
Next
I am also unable to record sound with CamStudio while the image is perfect. I just tried your method but I'm still at the same point. What can I do? Could it be a problem with my operating system Vista?
Thank you very much in advance.
Thanks again to Herman and goodbye.
