Torrent problem "Connection to Peers" stuck
Solved
BobbySponger Posted messages 30 Status Member -
 michpom -
Hello,
I have a problem with uTorrent but also with BitTorrent.
I downloaded files with uTorrent without any issues, but since yesterday, I can't download anything.
The message "Finding Peer" (for uTorrent) and "Connecting to Peers" (for BitTorrent) keeps appearing, with the orange logo in the bottom right indicating "No Incoming Connections" from time to time.
I tested the bandwidth, but no issues appeared.
Help I don't know what to do anymore.
Thanks in advance.
  1. Materio Posted messages 806 Status Member 142
    This comes from the torrent in general; if you test your bandwidth and you get about 3 to 4 Mbps stable, then it's that the torrent is dead (well, the torrent link is dead, whether it's a magnetic link or a direct link). Otherwise, it could come from uTorrent install the latest version, or if it’s already up to date, reinstall it and uninstall it. If it still doesn't work, then change the torrent link.
    19
    1. michpom
      well yes
