Echo issue on speakers
Solved
nelly -
 JOSEPH -
Hello friends,
I can't adjust the sound of my speakers and especially remove a persistent echo. I went to the volume control, I checked that there was no problem with the sound card (well, I think)... Anyway, I don't know what to do anymore. Plus, I can't find out the name of my sound card. I'm on XP Home Edition.
Can someone help me?
It's really very unpleasant in the end!
Thanks
Nelly
Configuration: windows xp home edition
  1. nelly
    You just need to go to the control panel, then other control panel options (on the left side of the page), and finally sound effects manager. When you're there, you just have to configure it as you want...
    26
    1. JOSEPH
      THANK YOU I hope that this clear explanation will help me soon
