MACBOOK PRO SOUND ISSUE... HELP! :o/
Solved/Closed
valymax
gatsh -
gatsh -
Hello,
I carefully read the valuable advice given regarding various sound issues on MacBook Pro, but I didn't find a case similar to mine.
Since I connected external speakers (USB) to my Mac, it no longer detects any internal input and output devices.
The sound only works if I plug in headphones or external USB speakers. The headphone jack doesn't work anymore, but it doesn't emit a red light.
The sound keys on the keyboard are unresponsive. The volume bars are stuck at maximum and a prohibition symbol is displayed.
When I go to system preferences, no devices are detected and the mute box cannot be unchecked.
I tried the suggested fixes:
- delete the sound preferences (home - library - preferences - com.apple.soundpref.plist)
- repair the permissions on my hard drive
But nothing works...
I bought my Mac two months ago, and this is already the second major problem I've encountered. I made an appointment at the "Apple Store" just a week ago because it wouldn’t start... A problem that the technicians couldn't explain but was resolved by reinstalling the entire system.
I have no doubt that I still have a lot to learn about my Mac (which is a valuable work tool for me), but for now, I’m not very lucky... I hope you can help me.
Thank you in advance!!!
Valérie
Valérie
Configuration: MacBookPro5,3 Mac OS X Version 10.5.6 Safari 525.27.1
Hello.
Excerpt from an old HowItWorks topic:
"A simple toothpick is enough to unblock this problem, insert it into the headphone jack, and at the bottom is the sensor that is stuck, making the system believe that there’s a digital output connected.
Be gentle, it’s a tiny "latch" that detects the insertion of the plug, and thus gets stuck."
I had the same problem, a mini screwdriver just saved me, thank you !!!!!
In order: Manual - Google - Forum. And not the other way around.
90% of problems are due to what is between the keyboard and the chair.
