Probleme wlm
je je vouler savoir si on pouver retrouver un mot de passe sur wlm sans le changer?
Configuration: Windows Vista
  1. C'est impossible, il faut que tu cliques sur "Mot de Passe oublié".
    Mais tu pourras remettre ton ancien mot de passe en cliquant dessus.
    1. WLM error code 5102 (connection problem with server) = WLM Database in local computer is crashed.
      1> i have vista and xp (C: = Vista, D: = XP)
      2> WLM in xp was crashed, it had sown error code 5102
      3> i deinstalled WLM and tried enough time on xp platform, but no use
      4> then i startet WLM.EXE in VISTA PARTITION ( C:\programme\windows live.........
      5> as i expected, it showed me xxx.dll error and some other errors and finaly something about "moving wlm database"
      6> i clicked OK for eveything, after some errors its closed automaticly
      7> i startet my old WLM ( xp D:\programme\windows live\.....
      8> bravooooooo... wlm has alert me " a new database was created / wlm database was moved/changed"
      after that wlm reloaded all my mails from the server and it works now perfect.
      thx...
      christian
